KyoRi Posté(e) 14 juin 2011 Share Posté(e) 14 juin 2011 Swype v3.0 BETA released!Here are the details: Swype v3 introduces two major new features: Tap Correction and Horizontal Word Choice List Our Tap Correction engine utilizes many of the concepts that make swyping so accurate. Seamlessly go from typing to swyping and back without missing a beat! The Horizontal Word Choice List replaces our popup word choice window, giving users an experience more in-line with evolving Android standards. It also makes dictionary control and word selection faster and easier. Swype v3 is available for devices with HVGA, WVGA, FWVGA, QVGA, WQVGA, WSVGA, qHD screen sizes Introducing a special Honeycomb-only WXGA version for Android tablets, with features like "moveable keyboard" that you won't find anywhere else! To see which languages are supported on your device, check the language and resolution table Improved licensing: Swype will no longer be disabled after a reboot on some devices; added support for devices that don't have a cellular radio (wifi-only tablets); no more license failures for CDMA devices in airplane mode. Simplified registration by allowing users to authenticate their email address directly through the installer Too many other improvements to list! Download Swype v3 NOW to explore everything the next generation of Swype has to offer! Limited End User Support - mostly via our forum If your phone came pre-installed with Swype DO NOT download this beta (it won't work) Bon et bien... après avoir regarder la vidéo, je suis retourner vers le clavier Swype :D En gros, ce qui me plait dans cette nouvelle version, c'est la possibilité de choisir les mots proposés à la vertical, ce qui donne une impression de prédiction. Et ça se rapproche un peu plus de Swiftkey qui est l'un des meilleurs claviers du market. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hadelino Posté(e) 16 juin 2011 Share Posté(e) 16 juin 2011 je trouve ce clavier meilleur que celui d'android par défaut et swiftkey mais je ne trouve pas comment mettre les accents... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 16 juin 2011 Share Posté(e) 16 juin 2011 il a l'air bien on le trouve ou ? merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KyoRi Posté(e) 18 juin 2011 Auteur Share Posté(e) 18 juin 2011 je trouve ce clavier meilleur que celui d'android par défaut et swiftkey mais je ne trouve pas comment mettre les accents... Je trouve que Swiftkey et Swype se valent. Les deux ont des avantages et des inconvénients :) Pour les accents sur Swype, il faut maintenir assez longtemps sur un caractère et les accents seront affiché par lettre. :) il a l'air bien on le trouve ou ? merci Il faut que tu t'inscrive en tant que beta testeur dans le lien ci-dessous: http://beta.swype.com/ Lorsque c'est fait, il faut que tu attendes que Swype t'envoi un mail de validation pour que tu puisses accèder au service de beta testeur. Mais c'est pas confirmer que tu puisses recevoir ce mail. Car si je me rappelle bien, il y a des sessions d'ouverture au nouveau beta testeur. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 18 juin 2011 Share Posté(e) 18 juin 2011 si enfait j'étais déjà inscrit suffit juste d'avoir "swype_installer.apk" et quand tu le lance il t'installe la dernière version de swype. J'ai testé j'aime pas trop.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KyoRi Posté(e) 19 juin 2011 Auteur Share Posté(e) 19 juin 2011 Après, ça dépends des goûts de chacun :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
higgins Posté(e) 22 août 2011 Share Posté(e) 22 août 2011 (modifié) je pige pas comment l'installer... je suis beta testeur depuis plusieurs versions pourtant.... :mad: je suis à l'étape enable swype, je coche puis back bouton mais là je n'ai pas le choix de swype "select swype" est toujours grisé et n'apparaît pas dans le clavier sms.... :emo_im_undecided: Modifié 22 août 2011 par higgins Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 28 août 2011 Share Posté(e) 28 août 2011 Je trouve flexT9 mieux. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
umibuzu Posté(e) 28 août 2011 Share Posté(e) 28 août 2011 C'est l'apli du siècle. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BiV Posté(e) 1 septembre 2011 Share Posté(e) 1 septembre 2011 Bonjour à tous, Je me suis enregistré pour la beta, je l'ai téléchargé et installé. Elle fonctionnait bien mais disparaissait à chaque reboot. J'ai donc pas insisté avec regret. J'ai fais une nouvelle installation de ROM. Du coup, j'ai voulu testé à nouveau Swype. Problème, mon compte semble inactif. Swype Installation FailedLogin Failed. Check your username and your password. You must have an ACTIVE Beta account to login. J'ai bien entendu vérifié et revérifié mon login/password. J'ai regardé sur le site de Swype et j'ai cliqué sur le lien réactivé mon compte. Il m'a été répondu que mon compte été toujours actif. Je me suis fais renvoyer le mail de confirmation. J'ai envoyé un mail. Pas de réponse. J'ai crée un nouveau compte. Même message d'erreur. Merci pour votre aide. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
