Yvory Posté(e) 27 juillet 2011 Share Posté(e) 27 juillet 2011 Bonsoir les amis, je cherche une âme charitable pour pourvoir expliquer les effets et l'installation de ceci: CHANGES Lowmemorykiller values -Values which mainly affect your multitask and free memory. Values of my script were made for combination of using multitask and still have enough free memory. VM values -Very important values which affect your battery consumption, system speed and speed of launching apps. INSTALLATION 1. Method for creating 1) Make file and add this code to it, if you make this script on Windows, set EOL to UNIX, then save file and name it for example “S97ramscript”, if you have in your init.d other file with “S97″ in name so use “S98″ or “S96″, etc., the name of file must be without extension 2) Then put your file to /system/etc/init.d with Root Explorer and set perm to 777 (rwxrwxrwx), if you have in your init.d other script for RAM management for example Darky’s rambooster, so delete it 3) Reboot your phone 2. Method for creating 1) Download attached file (Juwe_RAM_Script.zip) unzip it and put it to /system/etc/init.d with Root Explorer and set perm to 777 (rwxrwxrwx), if you have in your init.d other script for RAM management for example Darky’s rambooster, so delete it 2) Reboot your phone 3. Method for creating 1) Download attached file (Juwe_RAM_Script-CWM.zip) and install it with CWM HOW TO CHECK IF SCRIPT WORKS Download app Galaxy Tuner or AutoKiller Memory Optimizer and check values: LMK values 10MB, 16MB, 24MB, 48MB, 56MB, 72MB VM values 50, 10, 5, 10, 90, 5 ROM devs can use my script in their ROMs, but give the proper credit. Ceci provient de la :) Je crois comprendre que sa pourrait être pas mal et je suis une pine en anglais meme si gogole est ton ami... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yvory Posté(e) 27 juillet 2011 Auteur Share Posté(e) 27 juillet 2011 Je crois avoir aperçu un lien de téléchargement avec écrit CWM donc instalable en recovery ??? (Sur le post original) Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yvory Posté(e) 28 juillet 2011 Auteur Share Posté(e) 28 juillet 2011 Aucun des geeks du gt540 peut m'aider ??? :P Lien vers le commentaire Partager sur d’autres sites More sharing options...
Spoke_ Posté(e) 28 juillet 2011 Share Posté(e) 28 juillet 2011 @Yvory (mon heros du KDZ, LoL) : Je vais chercher ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Spoke_ Posté(e) 28 juillet 2011 Share Posté(e) 28 juillet 2011 @Yvory : Le voila ton lien de DL, apres cinq minutes de recherche. J'ai tapé Juwe11 sur Google, et, PAF, voila ton lien. http://www.mygt540.com/downloads/Juwe_RAM_Script-CWM.zip Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yvory Posté(e) 29 juillet 2011 Auteur Share Posté(e) 29 juillet 2011 Il est présent la je l'avais vu je recherche surtout les effets. Je vais l'installer pis je vais bien voir. Apperement y'a des modifs apparement sa joue sur pas mal de chose: CHANGES Lowmemorykiller values -Values which mainly affect your multitask and free memory. Values of my script were made for combination of using multitask and still have enough free memory. VM values -Very important values which affect your battery consumption, system speed and speed of launching apps. Sa jouerai sur la consommation de batterie, la mémoire libre, la vitesse du system et la vitesse de lancement des applications. Je crois comprendre que sa laisse au system android plus de place pour travaillé donc c'est l'inverse des "taskiller de la mort qui need free memory a fond alors que sa sert à rien". Retour en fin de journée je pense. Lien vers le commentaire Partager sur d’autres sites More sharing options...
