daderman34 Posté(e) 17 août 2011 Share Posté(e) 17 août 2011 (modifié) Voici la Rom Modaco pour Galaxy S II basé sur le dernier firmware XXKH1 : Features Included (many optional) : Based on the XXKH1 release Include a customised version of CF-Root Packaged for ClockworkMod Rebuilt using the MoDaCo MCR optimisation scripts Full up to date Google experience + additional apps (including new look Market) 'Stock Gingerbread' iconset 'Stock Gingerbread' versions of almost every app available HSPA icon differentiation ('H' icon when transferring data via HSPA) Connected icon differentiation (green when connected to Google services) 'CRT effect' on screen off Camera without battery limitations Ugly progress bar fix su / Superuser.apk root Busybox Semi-transparent notification pull-down Optional SIP over 3G Modified build.prop to show full Market catalogue sicopat's advanced power menu / battery percentage mod Options to mute many of the annoying system sounds Option to mute camera sounds De-odex Browser lag fix (thanks brightidea!) Bluetooth enhacements (thanks stevenz) AppWidgetPicker Additional application stores Google Voice and Video talk SIP calling over 3G De-odexed Many, MANY optional and additional apps in the kitchen Much much much more! Changelog: Changelog 17 Aug 17:00 Updated to XXKH1 Added optional Browser with changeable user agent 16 Aug 17:00 Updated to MCK r3 Fixed init.d script running 16 Aug 09:30 Gr2 release 16 Aug 09:00 Added CSC regions 15 Aug 20:00 Updated to MoDaCo Custom Kernel r2 in BLN and no-BLN flavours 15 Aug 14:00 Added MoDaCo Custom Kernel r1 in BLN and no-BLN flavours Added terminfo support to boot image (MCK only) Added tmpfs Market download configuration (MCK only) Added SIP XML in permissions directory (user request) Added patched E-Mail APK (administrator removal) by gauner1986 (user request) Added patched SQLIte library (sync removal) as discussed by ownhere (user request) Added app_process smoothness patch by nikademus (user request) Fixed 'CRT effect blockiness' issue 12 Aug 15:30 Modified build.prop to solve problem with apps not appearing in the Market (masquerade as Nexus S, option to revert) Added Google Videos Added sicopat's advanced power menu / battery percentage mod as an option 12 Aug 13:25 Added option to mute camera sounds 12 Aug 13:15 Added stock Gingerbread Email application Updated kitchen text to note dependency on Social Hub for Samsung email application 12 Aug 11:40 Browser lag fix (thanks brightidea!) 12 Aug 10:00 Shell script fixes (thanks stevenz) Bluetooth enhancement option (thanks stevenz) AppWidgetPicker added (user request) GetJar app added 11 Aug 16:10 Updated Google Talk to the latest release (with voice and video chat) 11 Aug 15:20 Corrected icon resource in stock Google Messaging APK 11 Aug 15:00 Added BLN compatible services / lights files from montymintypie - http://mdc.gd/o06cQV (requires you to flash a BLN compatible kernel and the BLN app) 11 Aug 14:50 Added stock Google Calendar option 11 Aug 14:15 Added sound options (boot, battery full, charger disconnect) 11 Aug 12:45 Initial Release Installation de la rom : - Telecharger le zip de la rom sur votre carte SD - Démarrer votre telephone en mode Recovery -Faites un nandroid backup ( fortement conseillé ) -Flashez la rom ! =) Telechargements : Gr3 (Defaults options) Download Gr3 (Vanilla edition) Download Gr3 BLN patch ( Pour compatiblité BLN) - Download A Priori pas mal , a tester =) XDA : http://forum.xda-developers.com/showthread.php?t=1215020 Sources : http://android.modaco.com/topic/344911-17-aug-gr3-xxkh1-modaco-custom-rom-for-the-samsung-galaxy-s-ii-stock-stylevanilla-with-online-kitchen Modifié 18 août 2011 par daderman34 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Maxime95k_13100 Posté(e) 17 août 2011 Share Posté(e) 17 août 2011 Dommage que le SGS2 ne soit pas présent dans ce bench... ça ne veut rien dire... surtout si on compare plusieurs ROM (et leurs versions qui divergent !)... Impossible de dire "telle ROM est mieux que telle ROM..." ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 18 août 2011 Share Posté(e) 18 août 2011 Si puisque tu peux comparer leurs résultats entres elles... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
daderman34 Posté(e) 18 août 2011 Auteur Share Posté(e) 18 août 2011 (modifié) On peut pas comparé une rom à une autre avec un benchmark ^^ ça ne veut rien dire Modifié 18 août 2011 par daderman34 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyruko Posté(e) 18 août 2011 Share Posté(e) 18 août 2011 Question : il a pris quel lockscreen ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Maxime95k_13100 Posté(e) 18 août 2011 Share Posté(e) 18 août 2011 Si puisque tu peux comparer leurs résultats entres elles... Pour commencer, ce score est plus ou moins aléatoire... Le résultat dépend des tâches de fond, et de ce qu'elles font. Tu n'as aucun référentiel, aussi imprécis soit-il... L'idéal (toujours imprécis car aléatoire), c'est d'avoir une référence basée sur le même smartphone, sur la ROM de base (ou sur plusieurs ROM différentes, sur le même matériel), et basées sur la même version (comparer des KG6 à des KG1 est un non-sens total !) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
daderman34 Posté(e) 18 août 2011 Auteur Share Posté(e) 18 août 2011 Question : il a pris quel lockscreen ? Le lockscreen est celui de base samsung =) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyruko Posté(e) 18 août 2011 Share Posté(e) 18 août 2011 ok merci :( Vais peut etre me faire celle la tien :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 18 août 2011 Share Posté(e) 18 août 2011 Pour commencer, ce score est plus ou moins aléatoire... Le résultat dépend des tâches de fond, et de ce qu'elles font. Tu n'as aucun référentiel, aussi imprécis soit-il... L'idéal (toujours imprécis car aléatoire), c'est d'avoir une référence basée sur le même smartphone, sur la ROM de base (ou sur plusieurs ROM différentes, sur le même matériel), et basées sur la même version (comparer des KG6 à des KG1 est un non-sens total !) Oui, enfin je te parlais de comparer des roms issues de la même base... Après c'est sur que ce n'est pas "garantie", mais cela permet déjà d'avoir une idée, sachant que je suis partisant de dire que ce n'est pas parce que le score est élevé, que la rom est fluide... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
