Tpcforever Posté(e) 4 octobre 2011 Share Posté(e) 4 octobre 2011 Je suis bien d'accord avec toi vivement l'alpha car j'en peux plus de WebOs ! Il me fait délirer avec son accent ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
facil Posté(e) 5 octobre 2011 Share Posté(e) 5 octobre 2011 (modifié) On se rapproche du portage !!! Build Progress [updated 10/4] CyanogenMod - Currently ~70% done to a ALPHA RELEASE (Please understand that this does not mean nightly status, or even beta, This means pre-nightly status) What currently works: COMPLETE Booting into Android COMPLETE ADB commands via ADB COMPLETE Power, back/home and volume button layout COMPLETE Touchscreen support (Multi-touch, 10 fingers) COMPLETE GPU Acceleration (2D Acceleration doesn't work, but not a release blocker) COMPLETE Dual CPU Processor (Both cores are enabled) COMPLETE Bluetooth (Fixed 9/24) COMPLETE Sound COMPLETE Accelerometer COMPLETE Power Management (Fixed 10/4) COMPLETE Battery Reporting (Fixed 9/29) COMPLETE Vibration (Fixed 9/26) COMPLETE Backlight (Confirmed in IRC) COMPLETE LED (Confirmed in IRC) COMPLETE Multiboot (Confirmed in IRC) COMPLETE Clockwork Recovery (Fixed 9/30) COMPLETE Fast Switch Boot COMPLETE Fake SD card Mount (Fixed 9/26) COMPLETE Light Sensor (Confirmed in IRC) COMPLETE Softkeys 90% Complete Wifi(Still needs to be fixed for reconnecting to wifi, needs to be verified) Partially Compass (Bugs need to be worked out) What does not currently work: Gyroscope What currently being worked on: Camera (Has video feedback VIA overlay, can't capture to disk) (Work started 9/23) What can possibly work: HDMI through Micro USB (The System-on-a-Chip has the required hardware, but the required input pins may not be there) GPS (Does not seem possible to implement because hardware seems to be lacking GPS functionality) Modifié 5 octobre 2011 par facil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tpcforever Posté(e) 5 octobre 2011 Share Posté(e) 5 octobre 2011 Merci facil pour la màj, carrément on est bien proche de l'alpha ! et une petite faute, à la fin c'est ce qui ne pourra jamais marcher : "What can not possibly work" Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
facil Posté(e) 12 octobre 2011 Share Posté(e) 12 octobre 2011 (modifié) Ca sent bon: Build Progress [updated 10/11] CyanogenMod - (A Project that goal is to be able to dual-boot android and webOS) What currently works: COMPLETE Wifi (Fixed 10/9) COMPLETE Camera (Fixed 10/7) COMPLETE Touchstone Support (Fixed 10/6) COMPLETE Power Management (Fixed 10/4) COMPLETE Clockwork Recovery (Fixed 9/30) COMPLETE Battery Reporting (Fixed 9/29) COMPLETE Fake SD card Mount (Fixed 9/26) COMPLETE Vibration (Fixed 9/26) COMPLETE Bluetooth (Fixed 9/24) COMPLETE Dual CPU Processor (Fixed 9/23) COMPLETE Fast Switch Boot (Appears fixed to me Video Update 9/23) COMPLETE Booting into Android COMPLETE ADB commands via ADB COMPLETE Power, back/home and volume button layout COMPLETE Touchscreen support (Multi-touch, 10 fingers) COMPLETE GPU Acceleration (2D Acceleration doesn't work, but not a release blocker) COMPLETE Sound COMPLETE Accelerometer COMPLETE Backlight (Confirmed in IRC) COMPLETE LED (Confirmed in IRC) COMPLETE Multiboot (Confirmed in IRC) COMPLETE Light Sensor (Confirmed in IRC) COMPLETE Accessing webOS files from Android and vice versa COMPLETE Softkeys PARTIALLY Compass (Bugs need to be worked out) What does not currently work: See issues below What's currently being worked on: Gyroscope Beating Metal Gear Solid 4 under 5 hours. Bugs and Issues, see below. What can possibly work: HDMI through Micro USB (The System-on-a-Chip has the required hardware, have to find which pin #) (webOS 3.0.4 may have HDMI support, and if so we can reverse engineer the process, stay tuned) GPS (Does not seem possible to implement because hardware seems to be lacking GPS functionality) Issues: High Priority Cannot record sound, unless sound is already playing [Accepted] High Priority Battery Drains while sleeping and active [Accepted] High Priority Plugging in headphones does not mute external speakers [Accepted] Medium Priority Apps in market are being filtered [Accepted] Medium Priority Battery does not shut down device at critical battery level [Reported] Medium Priority Camera does not take pictures [Accepted] Low Priority Reboot and Shutdown can take a long time [Accepted] Low Priority LED light turns off while sleeping [Accepted] Low Priority Light Sensor does not work automatically, needs to be turned on manually [Accepted] Low Priority No audio support for BT headsets [Accepted] Low Priority Add divx codecs for video support [started] Low Priority GPS apps crashes because apps assume for valid GPS [Accepted] Fixed msm_rotator does not work correctly. Screen may rotate for video, but becomes distorted. (Fixed 10/11) Fixed Sleep Issues (Fixed 10/11) Fixed Touchscreen has feedback issues (Fixed 10/11) Fixed Camera fails to save to disk, does not rotate (Fixed 10/11) Fixed Airplane mode stays on once turned on, happens because the touchpad doesn't have a real radio interface layer. (Fixed 10/10) Fixed Screen stays blank for 10 second before boot animation appears (Fixed 10/9) (Confirmed in IRC) Fixed Wifi Issues (Fixed 10/9) Fixed Sh exceeds the open file limit (Fixed 10/9) Fixed Sleep Issues for Wifi (Fixed 10/9) Fixed CPU stays on max frequency (Fixed 10/8) Fixed Touchscreen turns off when accelerometer is disabled (Fixed 10/7) Fixed Touchstone works and charges, but no event is raised to show you it's charging (Fixed 10/6) Fixed Touchscreen events (touches) are ignored after sleep (Fixed 10/5) Fixed Protect certain partitions in the kernel (Fixed 10/5) Fixed Root for bluetooth cmattach (Fixed 10/5) Fixed Touchscreen stays on at all times, even when screen is turned off (Fixed 10/4) Fixed Touchscreen has issues with pinch gestures (Fixed 10/3) Fixed No root access (Fixed 9/30) Modifié 12 octobre 2011 par facil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoRiTo Posté(e) 12 octobre 2011 Share Posté(e) 12 octobre 2011 Beating Metal Gear Solid 4 under 5 hours. :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
facil Posté(e) 13 octobre 2011 Share Posté(e) 13 octobre 2011 Alpha 1 Dipso: http://rootzwiki.com/showthread.php?4011-RELEASE-ALPHA-Discussion-CyanogenMod-team-Touchpad-port Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sonny84 Posté(e) 13 octobre 2011 Share Posté(e) 13 octobre 2011 Bonjour, Installé avec succès le double boot fonctionne parfaitement, c'est plus simple a installer qu'un SGS vraiment du beau boulot même si ce n'est pas encore parfait... Un petit tuto en Français ici: http://forum.hardware.fr/hfr/gsmgpspda/tablet/unique-touchpad-android-sujet_23356_1.htm a suivre pour une ALFA c'est déjà énorme réactif Bravo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
abby Posté(e) 10 janvier 2012 Share Posté(e) 10 janvier 2012 très bon partage !! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 21 janvier 2012 Share Posté(e) 21 janvier 2012 Je viens d'installer l'alpha 0 de CyanogenMod 9, Ice Cream Sandwich est tellement magnifique ! Je vous le conseille à tous ! L'alpha actuelle ne gère pas encore l'accélération matérielle, la caméra, et l'USB autre que pour la charge (personnellement je passe par Bluetooth). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pleonasm18 Posté(e) 13 février 2012 Share Posté(e) 13 février 2012 slt, non on peut utilser en usb host, il faut rentrer dans les réglages du sous menu de l'usb! des tutos existes... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
