Yvory Posté(e) 30 août 2011 Share Posté(e) 30 août 2011 (modifié) 2.3.5 ENIGMA DEFINITION R3 by Danzano ENIGMA REDEFINED INSTALL TUT —- This rom is in the form of a recovery file so you must have clockwork mod recovery to install it i recommend version 4.0.0.5 If you are using a custom partition table please re configure this partition table so that you have 190mb + for system i recommend 200mb to be safe this can be done using mur4iks custom boot loader If while installing you get a md5 mismatch please visit mygt540.com they have detailed instructions on how to fix this issue If you get stuck at boot screen for longer than say 4 mins on first boot please check the following you have 190mb+ system partition you have wiped user data and dalvik cache If all else fails do a clean install of rc4 through fastboot and then come back to enigma if i have left anything out in this tut please let me know ENIGMA REDEFINED RELEASE NOTES In light of some comments ive gone from ground up go weather is sucking alot of ram so has been removed so if you like it like i do re install. Also the red theme for cm7 is not default but its there as an option Flash 10 working not perfect but better than we had The rom will be odexed still with all the tweaks and good parts of RC2 but with hopefully less bugs glitches maybe none (cross fingers) Apps2sd People have had problems with this and it does use ram plus the stock rom does support apps2sd so in light of that and comments ive had this will be removed. There will be 2 or 3 themes from the moment you turn the phone on as i understand not everyone has my taste. The market issue is fixed The keyboard issue please if you are going to erase userdata etc have another keyboard to install or backup !!!!!!!!!! Anything else i have done in this is purely to solve issues this update is RC2 with a new look and the kinks worked out in essence. Please help with market issue as this is crippling my softmod have an idea but if it doesn’t work need help SCREENS: Download: http://link2me.ru/8118/www.multiupload.com/3QMOBE9PHQ ENIGMA REDEFINED —- Available unodexed and odexed ODEXED —- http://link2me.ru/8118/www.multiupload.com/ATI3IDANDR DEODEXED —- http://link2me.ru/8118/www.multiupload.com/L2S6P40PDM Modifié 30 août 2011 par Yvory Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yvory Posté(e) 30 août 2011 Auteur Share Posté(e) 30 août 2011 Traduction et photos à venir. Ps: je n'ai pas testé cette ROM. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Spoke_ Posté(e) 30 août 2011 Share Posté(e) 30 août 2011 Je la testerai peut-être Vendredi. Je prendrais des screens. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yvory Posté(e) 31 août 2011 Auteur Share Posté(e) 31 août 2011 Merci hurricane, étant pas trop la j'ai pas trop de temps. Based on cyanogen RC2. Je sais vraiment pas ce que cette rom vaut... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
