Galize Posté(e) 26 février 2010 Share Posté(e) 26 février 2010 (modifié) If the Nexus One is freezing or won’t start properly, you may want to try to start it in Safe Mode. Safe Mode will allow you to start the smartphone with the default software running so you have a chance to disable any software you’ve installed that may be causing the problem.Perform these steps: 1. Power the device off. Take the battery out if it won’t turn off normally. 2. Power the device on. 3. When the logo appears, press and hold the Menu button. 4. Continue holding the Menu button until you see the home screen. The words Safe Mode should appear in the lower left corner if you performed the steps correctly. bref appui sur menu quand le logo en X apparait, jusqu'au démarrage. Sinon essayer un hard reset ? I will add some new tips. If your Nexus One smartphone is stuck and having consistent problems, you may need to try a hard reset. This will erase all data off the device and start you off with the factory defaults. The steps are given below.# Pull the battery from the phone. # You need to press and hold both the Home and Back buttons simultaneously. # Press the Power button while continuing to hold the buttons. # Then release home button and back. # Then follow the instruction on the screen to complete the process. Maison et retour en même temps. Modifié 26 février 2010 par Galize Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
