boostermbkking Posté(e) 23 septembre 2011 Share Posté(e) 23 septembre 2011 9th version of the KING_3D_ROM by KING3Developers. Based on v10e Busybox + Root + Su Full deodex apps & Framework AcuraTeam kernel v1.2 New framework Optimized ram Increased speed of microSD Performance patch New gps.conf Increased speed of system Added more ringtones and notification sounds Added ubuntu font Added live wallaper Added widgets dialers Added fasterfix Added KING-manager Removed LG Apps Android Market 3.1.3 Facebook 1.7 GoLauncher 2.57 KING-manager 1.0 Installation procedure: make a backup of applications and data with wipe because you will delete 'all the contents of your phone 1) copy the files on the external sd 2) reboot into recovery (ClockworkMod 4.0.0.9) 3) make a backup nandroid (useful to restore your files and apps) 4) make the wipe 3 (Cache, date and Dalvik) 5) Flash zip from sdcard -> select the file 6) reboot system now 7 optional) reboot into recovery and go to backup and restore / advanced restore / YOUR BACKUP / Restore date (this puts all the files and apps as you had before flashing this rom but leaving unchanged the current Roma) CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed, JAM IS NOT NOTHING Rom screenshots Download: KING_3D_ROM_V1.8 Now I want to talk about the new program that you will find in the rom, free downloadable also from the market, is called King-manager, is an app created by lpirro (team member of the Rom as well as very good programmer), at my request, you can check with this rom changelog of the new ROM, you can download a new version of the rom if available via mobile phone and then flash from cwm, but most importantly, you can report bugs and ask for help the Roma to me directly via the function bug report and I will answer all very quickly trying to satisfy everyone who wants a mobile rom and my performance even though they are starting out with Android, in short, I will give you a better feeling with the Roma than all the others that for every problem you have access to the forum to report it But with this app wherever you are and for whatever reason, it is trivial, you can contact me to ask for clarification ... THIS 'DO A GIFT THAT I WANTED TO ALL THOSE WHO TRUST IN ME Put DEVICE FOR THEM! ! ! I leave you now with the screenshots of this fantastic, functional and useful app: PREVIEW: SCREENSHOT 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tomtom688 Posté(e) 23 septembre 2011 Share Posté(e) 23 septembre 2011 testé et approuvé, très sympa comme rom, merci KING ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
boostermbkking Posté(e) 23 septembre 2011 Auteur Share Posté(e) 23 septembre 2011 testé et approuvé, très sympa comme rom, merci KING ;) thank so much Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Londonboy44 Posté(e) 23 septembre 2011 Share Posté(e) 23 septembre 2011 Cette rom est juste parfaite ! Néanmoins j'ai un seul point négatif, c'est que je n'arrive pas a installer le widget social+, j'ai essayer par root explorer en changeant les permissions, mais rien a faire. Et je veux vraiment l'avoir, aucun autre widget n'est aussi bien que lui ! Quelqu'un serait-il comment faire pour l'avoir ? Merci d'avance ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
