boostermbkking Posté(e) 6 octobre 2011 Share Posté(e) 6 octobre 2011 (modifié) 11th version of the KING_3D_ROM by KING3Developers. Based on v10k Busybox + Root + Su Full deodex apps & Framework Franlov kernel System converted in ext4 New framework Optimized ram Increased speed of microSD Performance patch Increased speed of system Added more ringtones and notification sounds Added ubuntu font Added live wallaper Added widgets dialers Added 2D-3D converter Added KING-manager Removed LG Apps Added new apn Game installed on external sd Best 3D menù Android Market 3.1.5 Facebook 1.7.1 GoLauncher 2.58 KING-manager 1.0 Installation procedure: make a backup of applications and data with wipe because you will delete 'all the contents of your phone 1) copy the files on the external sd 2) reboot into recovery (ClockworkMod 4.0.0.9) 3) make a backup nandroid (useful to restore your files and apps) 4) make the wipe 3 (Cache, date and Dalvik) 5) Flash zip from sdcard -> select the file 6) reboot system now 7 optional) reboot into recovery and go to backup and restore / advanced restore / YOUR BACKUP / Restore date (this puts all the files and apps as you had before flashing this rom but leaving unchanged the current Roma) CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed, JAM IS NOT NOTHING Rom screenshots Download: KING_3D_ROM_V2.0 Now I want to talk about the new program that you will find in the rom, free downloadable also from the market, is called King-manager, is an app created by lpirro (team member of the Rom as well as very good programmer), at my request, you can check with this rom changelog of the new ROM, you can download a new version of the rom if available via mobile phone and then flash from cwm, but most importantly, you can report bugs and ask for help the Roma to me directly via the function bug report and I will answer all very quickly trying to satisfy everyone who wants a mobile rom and my performance even though they are starting out with Android, in short, I will give you a better feeling with the Roma than all the others that for every problem you have access to the forum to report it But with this app wherever you are and for whatever reason, it is trivial, you can contact me to ask for clarification ... THIS 'DO A GIFT THAT I WANTED TO ALL THOSE WHO TRUST IN ME Put DEVICE FOR THEM! ! ! I leave you now with the screenshots of this fantastic, functional and useful app: PREVIEW: SCREENSHOT if you want support for this rom to me please write in English or Italian. Modifié 6 octobre 2011 par boostermbkking 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pascal1973 Posté(e) 6 octobre 2011 Share Posté(e) 6 octobre 2011 (modifié) Merci pour l'info. Tu devrais mettre ce sujet dans le post rom custom ;) Modifié 6 octobre 2011 par pascal1973 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tomtom688 Posté(e) 7 octobre 2011 Share Posté(e) 7 octobre 2011 Thanks King ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
