Posté(e) (modifié)
bonjour.
j'ai recuperé un desire mais il reste sur le logo htc au demarrage.
adb ne fonctionne pas.
le recovery ne tourne pas....
j'ai essayé de flasher un recovery ca ne passe pas
c:\GW620\sdk\tools>fastboot flash recovery recovery.img
sending 'recovery' (4182 KB)... OKAY [ 0.582s]
writing 'recovery'... FAILED (remote: not allowed)
finished. total time: 0.584s
que' ce soit un recovery clockworkmod ou un amon ra...
il y a juste fastboot qui tourne.
donc pour les infos affichées
BRAVO PVT1 SHIP S-OFF
HBOOT-0.80;0000
MICROP-031d
TOUCH PANEL-SYNW0101
RADIO-4.06.00.02_2
Mar 29 2010....
en tapant fastboot oem boot j'ai ca
... INFOsetup_tag addr=0xA0000100 cmdline add=0x8E
07D944
INFOTAG:Ramdisk OK
INFOTAG:smi ok, size = 0
INFOTAG:hwid 0x0
INFOTAG:skuid 0x21F04
INFOTAG:hero panel = 0x0
INFOTAG:engineerid = 0x0
INFOMCP dual-die
INFOMCP dual-die
INFOTAG:mono-die = 0x0
INFODevice CID is super CID
INFOCID is super CID
INFOBackup CID is empty
INFOsetting->cid::11111111
INFOserial number: SH07MPL01679
INFOcommandline from head: no_console_suspend=1
INFOcommand line length =419
INFOactive commandline: board_bravo.disable_uart3=0 board_bravo.
INFOusb_h2w_sw=0 board_bravo.disable_sdcard=0 diag.enabled=0 boa
INFOrd_bravo.debug_uart=0 smisize=0 userdata_sel=0 androidboot.e
INFOmmc=false androidboot.baseband=4.06.00.02_2 androidboot.cid
INFO=11111111 androidboot.carrier=ALL androidboot.mid=PB992****
INFOandroidboot.keycaps=qwerty androidboot.mode=normal androidbo
INFOot.serialno=SH07MPL01679 androidboot.bootloader=0.80.0000 no
INFO_console_suspend=1
INFOaARM_Partion[0].name=misc
INFOaARM_Partion[1].name=recovery
INFOaARM_Partion[2].name=boot
INFOaARM_Partion[3].name=system
INFOaARM_Partion[4].name=cache
INFOaARM_Partion[5].name=userdata
INFOpartition number=6
INFOValid partition num=6
INFOjump_to_kernel: machine_id(2457), tags_addr(0x20000100), ker
INFOnel_addr(0x20008000)
INFO-------------------hboot boot time:774192 msec
FAILED (status read failed (Too many links))
finished. total time: 6.294s
je viens d'essayer avec PB99IMG_2.29.405.5_Radio_32.49.00.32U_5.11.05.27_release_159811_signed.zip sur µsd
toujours pareil. logo htc ca vibre une fois de temps en temps rien de plus....
nouvelles infos hboot passé en 0.93.0001 et radio en radio-5.11.05.27.
en revanche chose étrange il n'y a eu aucune erreur durant cette derniere operation mais il me redemande si je veux faire l'update.....
Modifié par aekold
Tu as une quelconque reconnaissance avec l'USB connecté a ton pc quand tu es dans le bootloader ? Si oui essay de flasher une RUU.exe directement. Sinon je ne vois pas désolé
oui oui il est bien reconnu comme,je crois quelque chose comme bootloader device...
l'histoire de la ruu j'avais essayé mais.... je le mets en quoi pour le flasher? je le laisse en bootloader? en fastboot? ou sur le logo?
enfin j'avais essayé les 3 rien ne passait du coup j'avais un peu laissé tomber de ce coté
Sinon telecharge un PB99IMG.ZIP que tu fous sur la SD, tu démarre sur le bootloader et il devrais te proposer une MAJ, il repassera S-ON et le root sera annulé, mais si tu choisis une MAJ avec un hboot 0.93 tu pourra rooter a nouveau ...
Sent from my HTC Desire
Quand tu essaie de passer sur le recovery tu a quoi?
Ok donc même pas acces au stock recovery (le point d'exclamation rouge n'apparais pas?)
non pas de point d'exclamation.
en demarrant avec power et volume haut idem rien a part la led vert/orange...
j'essaye de mettre PB99IMG_Bravo_Froyo_HTC_WWE_2.29.405.2_Radio_32.49.00.32U_5.11.05.27_release_151783_signed actuellement on sait jamais et téléchargee avec getright
ce qui fonctionne par contre c'est le fastboot oem rebootRUU mais apparemment ca n'apporte pas grand chose
Alors la MAJ a fonctionnée ?
Ca c'est normal en revanche, a partir du moment ou tu a un PB99IMG sur la sd il demande a faire la MAJ...
Posté(e) (modifié)
bon j'ai reussi a flasher une RUU
j'ai mis celle la
RUU_Bravo_Froyo_HTC_WWE_2.29.405.5_Radio_32.49.00.32U_5.11.05.27_release_159811_signed
et toujours pareil.
logo htc pendant 2 minutes puis ecran noir 1 seconde vibre une fois et repart sur le logo et ainsi de suite
dans le bootloader toujours pareil
bravo pvt1 ship s-off
hboot 0.93.0001
touchpanel synw0101
radio 5.11.05.27
avec la ruu il aurait pas du repasser s-on normlement?
sinon pas eu d'arreur pendant le flashage en tout cas
Modifié par aekold
Si si il repasse en s-on après une ruu, sinon en essayant la ruu format exe de la rom dev de htc peut être que avec une version de hboot plus récente ca passerais ?
donc il ne l'a pas prise alors je suppose vu que toujours s-off.
sebrider aurais tu des liens a me donner stp? vu que je suis nouveau sous htc... j'ai deja du mal a trouver des infos!!
Posté(e) (modifié)
c'est peut etre idiot mais j'ai cru lire quelque part que qqun avait reussi a le debloquer en flashant une rom custom... c'est possible?
et si oui comment faire sans recovery? un fastboot update?
bon j'ai ete voir un peu sur xda... j'ai lu qu'il fallait eventuellement downgrader le hboot par un hboot alfarev + downgrade pb99img downgrade egalement mais en tentant ca rien qu'au niveau du hboot via fastboot j'ai eu
writing 'hboot'... FAILED (remote: not allowed)
comme pour le recovery. j'avais pris le hboot_downgrade.img du site alfarev
Modifié par aekold
Posté(e) (modifié)
Tout se trouvera la ou presque pour les tutoriels sinon a part ma solution (qui déjà elle je ne sais pas si ca va marcher), je n'en vois aucunes autres, après je ne connais pas tout :s
Modifié par sebrider
Posté(e) (modifié)
aaaaah acces au recovery...... enfin!
je partitionne la sd et je flash la
[ROM] 2.29.405.5 WWE - Rooted/Bash/BusyBox/UV [v5 21/12/10]
Bon c'est toujours pas ca toujours logo htc au bout de 15min.
La radio est apparemment la bonne.
en revanche le hboot je n'en suis pas sur. pour cette rom je dois prendre quelle version de hboot sur alpharev?
bon donc edit 11h56 ca avance un peu!
flash du pb99img downgrade alpharev
flash RUU RUU_Bravo_HTC_WWE_1.15.405.4_Radio_32.30.00.28U_4. 05.00.11_release_122704.exe en cours de DL
Modifié par aekold
toujours pas de boot apres la ruu..
BRAVO UNKNOWN SHIP S-OFF
HBOOT-0.75.0000
MICROP-031D
TOUCHPANEL-SYNW0101
RADIO-4.05.00.11
MAR 5 2010
Recovery a nouveau disparu je comprends plus rien la....
Posté(e) (modifié)
Euh j'avais pas vus mais ta rom est trop vieille si tu as un désire slcd donc essaye de flasher un RUU plus récent et ca devrais passser .
D'ailleurs t'est passé pas loin d'un brick comme moi quand je ne savais pas -_-'...
Et aussi un truc très louche "BRAVO UNKNOWN SHIP S-OFF" Normalement c'est écris pvt1 ou 2 ou 3 ou 4 ...
La preuve tu avais pvt1 avant.
La a mon avis ca commence a sentir le roussis ... mais bon rien n'est perdu essaye un ruu récent de ce genre ou sinon si le premier ne marche pas essaye celui ci
Posté(e) (modifié)
j'ai essayé de remettre le recovery comme au debut ca passait pas.
j'ai remis le pg99img downgrade donc j'ai pu reinstaller le recovery-clockwork-3.0.0.5-bravo.img.
voila ou j'en suis
au bootloader j'ai maintenant alpharev unlock en rose et le unknown a disparu au 1er reboot.
je passe par les ruu que tu m'as conseillé ou c'est mieux de faire d'une autre facon?
bon en attendant je DL cette ruu!
en tout cas avant le downgrade tout était locké en écriture que ce soit le hboot ou le recovery je comprends mieux pourquoi les mises a jour passaient mais ca ne changeait rien... je me trompe?
boot en recovery ok v3.0.0.5
alpharev unlock
HBOOT-6.93.9999
MICROP-031D
TOUCHPANEL-SYNW0101
RADIO-5.11.05.27
aug 10 2010
au final si et seulement si ca remarche je me contenterai d'une rom de base enfin nue htc on verra apres pour une custom.....
13h47 le premier RUU est flashé.... ca peut prendre maxi combien de temps sur le logo htc blanc?
14h05 toujours rien je vais essayer le 2e ruu que tu m'as donne en lien. recovery a nouveau disparu
HBOOT-0.93.0001
MICROP-031D
TOUCHPANEL-SYNW0101
RADIO-5.11.05.27
aug 10 2010
Modifié par aekold
j'ai remis l'alpharev stock.
du recovery je colle le log
bon donc maintenant avant de reflasher je vais attendre davantages de conseils mais toujours pareil
Starting recovery on Thu Jan 10 19:31:51 1980
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (480 x 800)
ClockworkMod Recovery v3.0.0.5
recovery filesystem table
0 /tmp ramdisk (null) (null)
1 /boot mtd boot (null)
2 /cache yaffs2 cache (null)
3 /data yaffs2 userdata (null)
4 /misc mtd misc (null)
5 /recovery mtd recovery (null)
6 /sdcard vfat /dev/block/mmcblk0p1 /dev/block/mmcblk0
7 /system yaffs2 system (null)
8 /sd-ext auto /dev/block/mmcblk0p2 (null)
I:Completed outputting fstab.
I:Processing arguments.
mtd: successfully wrote block at 0
I:Set boot command "boot-recovery"
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.service.adb.enable=1
ro.build.id=GINGERBREAD
ro.build.display.id=full_bravo-eng 2.3.1 GINGERBREAD eng.udK.20110106.161820 test-keys
ro.build.version.incremental=eng.udK.20110106.161820
ro.build.version.sdk=9
ro.build.version.codename=REL
ro.build.version.release=2.3.1
ro.build.date=gio 6 gen 2011, 16.19.23, CET
ro.build.date.utc=1294327163
ro.build.type=eng
ro.build.user=udK
ro.build.host=radium
ro.build.tags=test-keys
ro.product.model=Full Android on Bravo
ro.product.brand=generic
ro.product.name=full_bravo
ro.product.device=bravo
ro.product.board=bravo
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=hdpi
ro.product.locale.region=
ro.wifi.channels=
ro.board.platform=qsd8k
ro.build.product=bravo
ro.build.description=full_bravo-eng 2.3.1 GINGERBREAD eng.udK.20110106.161820 test-keys
ro.build.fingerprint=generic/full_bravo/bravo:2.3.1/GINGERBREAD/eng.udK.20110106.161820:eng/test-keys
ro.sf.lcd_density=240
rild.libpath=/system/lib/libhtc_ril.so
ro.ril.ecc.HTC-ELL=92,93,94
ro.ril.ecc.HTC-WWE=999
ro.ril.enable.a52.HTC-ITA=1
ro.ril.enable.a53.HTC-ITA=1
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
ro.ril.gprsclass=12
ro.ril.hsdpa.category=8
ro.ril.hsupa.category=5
ro.ril.hsxpa=2
wifi.interface=eth0
wifi.supplicant_scan_interval=15
ro.telephony.default_network=0
ro.ril.enable.prl.recognition=1
ro.ril.def.agps.mode=2
ro.opengles.version=131072
dalvik.vm.heapsize=32m
ro.media.dec.jpeg.memcap=20000000
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=SH07MPL01679
ro.bootmode=recovery
ro.baseband=5.11.05.27
ro.carrier=ALL
ro.bootloader=6.93.1002
ro.hardware=bravo
ro.revision=129
init.svc.recovery=running
init.svc.adbd=running
I:Checking for extendedcommand...
I:Skipping execution of extendedcommand, file not found...
I:Set boot command ""
Formatting /sdcard...
I:Formatting unknown device.
rm: can't remove '.' or '..'
Done.
Partitioning SD Card... please wait...
Found SDPATH=/dev/block/mmcblk0
checking script requirements...done
unmounting all partitions...done
to continue, all existing partitions must be removed.
this action will remove all data from your sdcard.
removing all partitions...done
total size of sdcard=3965MB
the following actions will be performed:
-create 3197MB fat32 partition
-create 512MB ext2 partition
-create 256MB swap partition
-ext2 partition will be upgraded to ext3
performing selected actions...
creating fat32 partition...done
creating ext2 partition...done
creating swap partition...done
adding journaling to /dev/block/mmcblk0p2...done
retrieving current sdcard information...
Model: SD SU04G (sd/mmc)
Disk /dev/block/mmcblk0: 3965MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
1 512B 3197MB 3197MB primary fat32 lba
2 3197MB 3709MB 512MB primary ext3
3 3710MB 3965MB 255MB primary linux-swap(v1)
script log is located @ /data/sdparted.log
Done!
Étrange, attend d'autres réponses par ce que moi ca dépasse mes compétences et je dirais max 15 min sur l'écran blanc après le flash de la RUU. En tout cas bonne chance et bon courage !
sujet a clore j'ai reussi ENFIN a booter en cm7!!!!!!!!!!!!!!!!!!
donc install du alpharev downgrade puis flash recovery ensuite flash du alpharev cm7r2 flash radio et install zip de cm7....
