[ROM] KING_3D_ROM_V2.2
boostermbkking
13th version of the KING_3D_ROM by KING3Developers.
  • Based on v10k
  • Busybox + Root
  • Updated Superuser
  • Updated bin/su
  • Full deodex apps & Framework
  • Original Kernel
  • New King ICS framework
  • Optimized ram
  • Increased speed of microSD
  • Performance patch
  • Increased speed of system
  • Added ringtones ICS
  • Added bootanimation ICS
  • Added music ICS
  • Added Roboto ICS font
  • Added live wallaper
  • Added 2D-3D Converter
  • Added KING-manager
  • Removed LG Apps
  • Fixed bug of GoSmsPro
  • Android Market 3.1.5
  • GoLauncher 2.61
  • KING-manager 1.0
KING_3D_ROM v2.2
KING_3D_ROM v2.2 BETA (more performance but more battery drain)
To install: Put the patch that you want in your SD, and flash it.
Original apps patch
3D games in internal SD
3D games in external SD
KING ICS framework
KING ICS framework + %battery
Frame KING (the old grafics)
Original LG framework
NOTE! You should make a nandroid backup, if something goes wrong, or if you want to restore configuration and apps.
Installation procedure - Quick guide:
1) Copy the KING_3D_ROM in your SD.
2) Reboot in to recovery (ClockworkMod)
4) Do the 3 wipe (data/factory reset, cache partition, and in advanced, dalvik cache.
5) Go to Flash zip from sdcard -> Choose zip from sd card and select the KING_3D_ROM and confirm.
6) When the installation is completed, reboot your system.
Installation procedure - Detailed guide for newbies (ENG\ITA):
- Nandroid buckup
- Install the ROM
Note! Please not restore the data from recovery mode, it may cause reboots. Restore your apps with programs as MyBackup PRO.
Preview of new King ICS Framework
For good effect, you shoud install the GoLauncherEx Ice Cream Sandwitch theme (and apply it in the theme section of GoLauncherEx)
GoLauncherEx Ice Cream Sandwitch theme - Download
device20111027183443.pngdevice20111028224951.pngdevice20111027183503.pngdevice20111028225117.png
Modifié par boostermbkking
