Déverrouiller votre bootloader avec Flashtool 0.4.2.0
voila:
19/012/2012 23:12:07 - INFO - Searching Xperia....
19/012/2012 23:12:07 - INFO - Found at USB\VID_0FCE&PID_ADDE\5&5A5FAC4&0&1
19/012/2012 23:12:07 - INFO - VER="R8A013";DATE="20100119";TIME="17:24:00";�
19/012/2012 23:12:07 - INFO - Start Reading property
19/012/2012 23:12:07 - INFO - Reading property finished.
19/012/2012 23:12:07 - INFO - You can now unplug and turn on device, then plug it again
19/012/2012 23:12:07 - INFO - Waiting for device
19/013/2012 23:13:21 - ERROR - Cannot identify your device.
19/013/2012 23:13:21 - INFO - Selecting from user input
19/014/2012 23:14:14 - INFO - Connected device : X10
19/014/2012 23:14:51 - INFO - Phone in recovery mode
19/015/2012 23:15:30 - INFO - Pushing .\devices\X10\features\X10UnlockBL\fixPart to /data/local/tmp
19/015/2012 23:15:56 - INFO - Running runfixPart as root thru sysrun
19/016/2012 23:16:02 - INFO - Successfully applied fixPart. Rebooting
19/016/2012 23:16:29 - INFO - Waiting for device
19/018/2012 23:18:58 - INFO - Pushing .\devices\X10\features\X10UnlockBL\mapper_2.6.29-00054-g5f01537.ko to /data/local/tmp
19/019/2012 23:19:04 - INFO - Pushing .\devices\X10\features\X10UnlockBL\qsd8250bootwrite_semcSL to /data/local/tmp
19/019/2012 23:19:20 - INFO - Running runqsd8250bootwrite as root thru sysrun
19/019/2012 23:19:26 - INFO - Successfully applied unlock. Rebooting
Modifié par bache
Salut desspil
Celle-ci :
Merci,
Je pars de ca :
RUNNING S1_EROM VER "r8A033"
SOFTWARE AID: 0001
LOADER AID: 0001
FLASH ID: "002C/00B3"
LOADER VERSION: "r4A024"
MODEL (from GDFS): X10i
SOFTWARE VERSION: 1227-4612_3.0.1.G.0.75
CUSTOM VERSION: 1233-2796_R1C
FILESYSTEM VERSION: WORLD-1-4-8_3.0.1.G.0.75
SERIAL NO: CB511JDSHK
SEMC SIMLOCK CERTIFICATE
Elapsed:64 secs.
Salut :)
Petit problème j'extrait le zip et je le met dans un dossier puis je pars sur flash tools -> plugin -> "Bootlaoder Unlock" -> mettre en mode fastboot et la error :s
Que faire :s (x10i rom stock 2.3.3 et rooté)
VOila mon flashtool :
22/057/2012 18:57:48 - INFO - <- This level is successfully initialized
22/057/2012 18:57:48 - INFO - Flashtool Version 0.7.1.0 built on 2012-05-01 22:07:23
22/057/2012 18:57:48 - INFO - You can drag and drop ftf files here to start flashing them
22/057/2012 18:57:54 - INFO - Device connected with USB debugging on
22/057/2012 18:57:54 - INFO - Connected device : X10
22/057/2012 18:57:55 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-04-04 18:40:20 CDT) multi-call binary.
22/057/2012 18:57:55 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-00054-g5f01537
22/057/2012 18:57:55 - INFO - Root Access Allowed
22/059/2012 18:59:13 - INFO - Device disconnected
22/059/2012 18:59:15 - INFO - Device connected with USB debugging on
22/059/2012 18:59:15 - INFO - Connected device : X10
22/059/2012 18:59:15 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-04-04 18:40:20 CDT) multi-call binary.
22/059/2012 18:59:15 - INFO - Android version : 2.3.3 / kernel version : 2.6.29-00054-g5f01537
22/059/2012 18:59:16 - INFO - Root Access Allowed
22/000/2012 19:00:36 - INFO - Please connect your device into flashmode.
22/000/2012 19:00:39 - INFO - Device disconnected
22/000/2012 19:00:53 - INFO - Device connected in flash mode
22/000/2012 19:00:53 - INFO - Opening device for R/W
22/000/2012 19:00:53 - INFO - Reading device information
22/000/2012 19:00:53 - INFO - Phone ready for flashmode operations.
22/000/2012 19:00:53 - INFO - Flashing loader
22/000/2012 19:00:53 - INFO - Ending flash session
22/000/2012 19:00:53 - WARN - Cancelled
22/000/2012 19:00:54 - INFO - Device connected in flash mode
22/000/2012 19:00:55 - INFO - Device disconnected
22/000/2012 19:00:56 - INFO - Device connected in flash mode
22/001/2012 19:01:00 - INFO - Please connect your device into flashmode.
22/001/2012 19:01:00 - INFO - Opening device for R/W
22/001/2012 19:01:00 - INFO - Device connected in flash mode
22/001/2012 19:01:00 - INFO - Reading device information
22/001/2012 19:01:00 - INFO - Phone ready for flashmode operations.
22/001/2012 19:01:00 - INFO - Flashing loader
22/001/2012 19:01:00 - INFO - Ending flash session
22/001/2012 19:01:00 - WARN - Cancelled
22/001/2012 19:01:01 - INFO - Device connected in flash mode
22/001/2012 19:01:02 - INFO - Device disconnected
22/001/2012 19:01:03 - INFO - Device connected in flash mode
Resolu gràce au flashtool de desspil Merci !
Modifié par maktaara
Tu as juste besoin de flashtool pour déverrouiller, tu n'as pas besoin de télécharger autre chose
Dans le tuto ça parle d'une version de Flashtool où il fallait 2 fichiers, mais maintenant c'est plus d'actualité......si tu as téléchargé Flashtool c'est bon (sauf si tu as la dernière version, elle beug) !
Utilise mon lien http://www.terafiles.net/v-136911.html
D'accord je télécharge ta version, car j'ai la dernière. Merci :)
Me revoila, ça ne marche pas ...
Sa reste sur Waiting for device, depuis 20 min, j'ai débranché ... remis, rien ne marche :(
Oui il était éteint ^^, mais j'avais pas vu juste au dessus c'était demandé de débranché le tél, le rallumer et le brancher ^^.
C'est bon c'est unlock, je cherche une rom maintenant ^^, la CM7.2 Tiens pas la batterie.
