bossgd Posté(e) 11 décembre 2011 Share Posté(e) 11 décembre 2011 (modifié) CyanogenMod 9 en version béta pour ceux qui veulent tester.Il y a pas mal de choses qui fonctionnent mais l'appareil photo n'est pas pleinement fonctionnel (pas caméra/flash/mode panorama). source : http://android.modac...uild-coming-up/ MAJ 05/01/2012: Browsers and Gmail fixed!!! Proximity calibration WiFi Signal Strength USB mounting 10/02/2012: Multiple bugfixes Fix crashing New kernel Increase stability Better HW acceleration Add HW video decoding - still choppy though Enable V8 JIT Multiple other small stability imporvements 13/02/2012: FULL HW OpenGL acceleration Audio fully fixed Fixed WiFi Fixed GPS Fixed kernel panic Fixed network stats 21/02/2012: Reboots should now be completely fixed Improved graphics Tweaked memory settings to prevent out of memory issues Synced with latest CM repos Camera progress has been made although it still doesn't work Should be faster and can now overclock stably Mass storage partially fixed - still causes reboots - trying to figure out why 23/02/2012: Fixed reboots Fixed browser Fixed settings crash Fixed USB mass storage 25/02/2012: Pretty much the same fixes as last release but it should be completely fixed now 08/03/2012: Brand new audio - compiled from source Brand new copybit - compiled from source Added proximity calibration Camera partially working!! Much improved kernel Better battery life Updated CM sources More CPU OCing options GPU OCing CPU undervolting Brand new EGL libs - huge performance boost on 3D Updated kernel with new Blade kernel files 17/03/2012: Brand new copybit source Sped up rendering in browser slightly Increased smoothness in some areas Experimental HW video decoding added - works in some places but not others 31/03/2012: Fix colour banding General performance improvements Speeded up UI 05/04/2012: Using new QCOM drivers Using open source gralloc and copybit Brand new kernel - better performance Much faster Much smoother Broken camera preview data:image/gif;base64,R0lGODlhFAAUAHMAACH/C05FVFNDQVBFMi4wAwEAAAAh+QQJCgAPACwAAAAAFAAUAINDNBDHx8LQnwx1YzmXjXLx0Bvk6vGXcQpsUAnmvhX94yGviQ1lUB7ZsBLS1NQAAAAEqPDJSaulJpDB2CCBcUkOgSxNUTQLQjhXMBwFoNxAkRxDUDkMgcJ2w+kWDJjEQFgMi9BcYkEQPQKIQpH4VOgaCN+jGd0WdQeCZNAo484JwUDCSLi73jiDbof6bzoCew9sWn9wLHNjC4aHeQJpElgJhgCWl18CYUtNlFxeNQ2QVRNACwmUKjoJokhKEwEMBw2oqKKQDGI/JgcLAgILBy6vFhkbHR8hI8sjEQA7 Gallery now working Calculator now working Live wallpapers now working 07/04/2012: Fixed ZTE Parts crash Fixed any small bugs from previous New kernel again Cleaned source tree Fixed audio bugs Fix YouTube video crash from previous build Bit more performace eeked out Closer to getting BT working 09/05/2012: Missed out a huge number of builds from changelog Bluetooth fixed - thanks to C3C0 Camera preview now working Up to date with CM sources - Themes, Lockscreen etc. Loads of performance improvements Lot of other things whcih I've forgotten - I promise to keep the first post up to date from next time :P 15/05/2012: Fix video recording Update with CM repos - many changes have happened behind the scenes Revert to using CM kernel with a gerrit patch for black screen fix Fix market apps not showing up Readd softkey settings Make camera preview smooth Lot more stuff behind the scenes FLASH ORDER: First: you should get the GAPPs and ROM and put them on your SD card Now FORMAT SYSTEM <- VERY IMPORTANT Then flash the ROM After this wipe data Then reboot out of recovery and let it boot into the ROM After you let it sit on the launcher for ~ 5 minutes then reboot into recovery again Now flash the GAPPs zip And reboot out of recovery The ROM should boot Let it sit on launcher for another 5 minutes to stabilise. If you still have problems post on the thread. Download: 15/05/2012: Goo.im - http://goo.im/devs/t...6991-signed.zip Google Apps (Market, Gmail, etc.) - http://goo.im/gapps/...0429-signed.zip Modifié 17 mai 2012 par bossgd 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oscardrome Posté(e) 11 décembre 2011 Share Posté(e) 11 décembre 2011 Merci pour ce post. Personnellement je vais attendre un peu notamment que le data fonctionne. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 11 décembre 2011 Share Posté(e) 11 décembre 2011 (modifié) Merci pour ce post. Personnellement je vais attendre un peu notamment que le data fonctionne. " tilal6991 : Mobile data and hardware acceleration now working. " :) Modifié 11 décembre 2011 par bart143b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oscardrome Posté(e) 11 décembre 2011 Share Posté(e) 11 décembre 2011 Bien vu, j'ai lu trop vite et lu not working. Comme quoi faut prendre son temps!!! Bon ben je pense que je vais la tester début janvier! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
shangalisto Posté(e) 12 décembre 2011 Share Posté(e) 12 décembre 2011 L'écran tactile à pas l'air de fonctionner si en croit un des coms'...mais bon on y croit vu que c'est qu'une Alpha (qui un jour deviendra p'te une ROM stable) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjy02 Posté(e) 12 décembre 2011 Share Posté(e) 12 décembre 2011 (modifié) Il n y a pas de section dédié a nos Skate/Staraddict sur modaco et xa-developers ? Modifié 12 décembre 2011 par benjy02 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jp33 Posté(e) 12 décembre 2011 Share Posté(e) 12 décembre 2011 Sur Modaco, si (d'ailleurs, le lien en tête de topic en provient). Sur xda, non ... pas encore ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 MAJ 12/12/11 Version 2 fonctionne : Mobile data Audio partially Graphics acceleration - hacked fonctionne pas : Wifi Sensors Audio fuly Camera Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjy02 Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 A ce rythme la nous allons avoir bientot une version stable. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
shangalisto Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 Avec le Blade ils en sont a l'update 16 ou 17 et y'a encore du boulot donc ici le stable est encore loin (mais deviendra rapide si ZTE met a jour le Skate et surtout qu'il lâche le code source) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjy02 Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 Le blade est plus avancé que le Skate :o. C'est bizarre je trouve.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 Non, le Blade y est depuis longtemps. Ils se servent du boulot réalisé sur le Blade pour l'adapter sur le Skate. De plus, la Blade a une bien plus forte communauté, la demande est donc plus forte... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjy02 Posté(e) 13 décembre 2011 Share Posté(e) 13 décembre 2011 Tu croit que le Skate à un bel avenir dans le monde du custom ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 (modifié) MAJ d’après tilal6991 le rom est suffisamment stable pour un usage quotidien 17/12/2011 : Synced with latest repos Audio WiFi Sensors Multi-touch 17/12/2011 - 2nd build (coming up): WiFi Gallery Audio (fully) Download: 17/12/2011 - http://www.mediafire...gaxa4tcp82zen42 MD5SUM - 000342a6050f67624e81032143854f77 Google Apps (Market, Gmail, etc.) - http://download.cloc...cs-20111128.zip si gapps ne fonctionne pas (se qui est le cas pour le staraddict) utillisé ce lui la http://i.min.us/jQVWHFiudlrD1.zip /!\ faire un Wipe data avant d installer le gapps source : http://android.modac...g-updated-1712/ Modifié 17 décembre 2011 par bart143b 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
shangalisto Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 Qu'elle soit suffisamment évoluée pour être utiliser d'une manière quotidienne, j'en doute un peu pour l'instant surtout aux niveau des performances ou à mon avis, ça doit pas être encore trop ça. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jp33 Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 L'audio passe, le Wifi se coupe quand il faut, il ne doit plus rester grand chose .... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 (modifié) le wifi ne fonctionne pas du tout chez moi, bon j aurais essayé :P je confirme globalement, il est plutôt stable Modifié 17 décembre 2011 par bart143b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjy02 Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 Pour que le wi-fi fonctionne ; http://www.mediafire.com/file/9j9tpded74wse80/WiFi-Fix.zip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 17 décembre 2011 Share Posté(e) 17 décembre 2011 (modifié) si gapps-ics-20111128 ne fonctionne pas utilisé cela http://i.min.us/jQVWHFiudlrD1.zip /!\ faire un wipe data avant d installer Modifié 17 décembre 2011 par bart143b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 19 décembre 2011 Share Posté(e) 19 décembre 2011 (modifié) MAJ DU 19/12/2011 :P FONCTIONNE: Hardware acceleration (hack) Bluetooth Mobile data 2G and 3G Network Audio (partially) WiFi Sensors NE FONCTIONNE PAS: Camera Live Wallpapers Hardware Acceleration (fully) Changelog: Version 1: Initial release Version 2: Mobile data Audio partially Graphics acceleration - hacked 17/12/2011: Synced with latest repos Audio WiFi Sensors Multi-touch WiFi temp fix: Wifi 19/12/2011: Gallery Audio (fully) Much smoother UI Fixed "buffer not found error" - some games (Skyball, Angry Birds Seasons) work very well - others crash Reboot constantly fix FLASH ORDER - EVEN IF YOU ALREADY HAVE THIS ROM INSTALLED: ROM Wipe data Google Apps Reboot TELECHARGER: 19/12/2011 - http://minus.com/mrmj48dfw#4 Google Apps (Market, Gmail, etc.) - i.minus.com/1324329758/asm92mIBmeIaTOinq1YX5Q/dQVWHFiudlrD1.zip SOURCE : http://android.modac...d-updated-1912/ Modifié 19 décembre 2011 par bart143b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 23 décembre 2011 Share Posté(e) 23 décembre 2011 (modifié) MAJ 23/12/2011: Super smooth animations!! Many bugs fixed Updated to latest CM sources FLASH ORDER - EVEN IF YOU ALREADY HAVE THIS ROM INSTALLED: ROM Audio fix Wipe data Reboot Back into recovery Google Apps Reboot Download: 23/12/2011 - http://minus.com/mrmj48dfw#5 Audio Fix - http://minus.com/mboEJQ4iqD#1 Google Apps (Market, Gmail, etc.) - http://www.mediafire...lx9f937kq9aivaf Modifié 23 décembre 2011 par bart143b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bossgd Posté(e) 6 janvier 2012 Auteur Share Posté(e) 6 janvier 2012 (modifié) MAJ 05/01/2012: Browsers and Gmail fixed!!! Proximity calibration WiFi Signal Strength USB mounting FLASH ORDER - EVEN IF YOU ALREADY HAVE THIS ROM INSTALLED: ROM Wipe data Reboot Back into recovery Google Apps Reboot Download: 06/01/2012 - http://www.mediafire...qmdlrb4bvagsf46 Google Apps (Market, Gmail, etc.) - http://www.mediafire...lx9f937kq9aivaf Modifié 6 janvier 2012 par bossgd Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 6 janvier 2012 Share Posté(e) 6 janvier 2012 @bossgd MAJ 05/01/2012: Browsers and Gmail fixed!!! Proximity calibration WiFi Signal Strength USB mounting FLASH ORDER - EVEN IF YOU ALREADY HAVE THIS ROM INSTALLED: ROM Wipe data Reboot Back into recovery Google Apps Reboot Download: 06/01/2012 - http://www.mediafire...qmdlrb4bvagsf46 Google Apps (Market, Gmail, etc.) - http://www.mediafire...lx9f937kq9aivaf pourrais tu mettre tous ca dans le premier poste :) merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alex_02 Posté(e) 7 janvier 2012 Share Posté(e) 7 janvier 2012 La caméra remarche ou pas ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bart143b Posté(e) 7 janvier 2012 Share Posté(e) 7 janvier 2012 non pas encore Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
