cajl Posté(e) 14 décembre 2011 Share Posté(e) 14 décembre 2011 Google apps: new Honeycomb release 6 integrated. It fixes Video GTalk crash when switching cameras on devices with only one camera. Now Google+ is part of the firmware. Archos media server: allow connected TVs to play video from your tablet via network Network shortcuts: it is now possible to create network shortcuts in file/music/video browsers Accessories: external USB audio cards (DAC) support has been added Media center: a new progress bar slider indicates resume position on videos already played Media center: in regular list view, the title of the TV show episode is appended after the season and episode numbers File manager: support of zip files Music: fix repeat mode Audio: decrease loud volume glitches on notifications while playing music Media database: remove muSD card related entries when the card is ejected Media center: global resume displays posters when available File manager: fix UI glitches when dragging files after cycling through dual/single panel display Network shares: make sure authentication credentials are asked when entering a samba protected share folder with Archos media center MTP: device icons for A80S/H and A101S/H have been added for display on the Windows PC Display: fix touch panel events sometimes not taken into account Display: fix blinking of icons occurring sometimes in applications (e.g. Android Market) Display: increase of icon redraw speed when moving application icons on launcher 3G: correct telia.se and add Polen Telekom APNs Battery: make sure led blinks at full charge Battery: issue a warning that the product will stop charging if powered off while on DCin in the shutdown menu Battery: a new shutdown policy has been implemented when in suspend to ensure that product still has battery when powered back on. Shutdown of the device occurs when it reaches 50% of the battery capacity when the screen was last on. http://update.archos.com/9/gen9/gen9_3.2.77/firmware_archos_it4.aos avec le nouveau firmware vous avez un serveur multimédia http://www.jbmm.fr/?p=24695 vous pouvez également utiliser des enceintes USB http://www.jbmm.fr/?p=24611 @++ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
detroit Posté(e) 23 décembre 2011 Share Posté(e) 23 décembre 2011 merci beaucoup et bonne fetes loooool Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mrjhack Posté(e) 1 janvier 2012 Share Posté(e) 1 janvier 2012 (modifié) bonjour ce firmware est il compatible avec les Archos 101 IT ? merci par avance ------ EDIT : apparement non dommage. Modifié 1 janvier 2012 par mrjhack Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cyril47430 Posté(e) 1 janvier 2012 Share Posté(e) 1 janvier 2012 Bonjour, il m'est impossible de télécharger la mise a jour, j'ai à chaque fois un message d'échec à 10% du téléchargement. Quelqu'un aurait une solution à mon problème? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sami_22 Posté(e) 1 janvier 2012 Share Posté(e) 1 janvier 2012 Si tu le fait a partir de la tablette fais le sur Pc et le inversement ;-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
