HTC Keyboard (Amélioré)
Je vous laisse découvrir ici le clavier HTC en version amélioré (v25 :p) spécialement pour les grandes résolutions et basses résolutions maintenant !http://forum.xda-developers.com/showthread.php?t=624416
Téléchargements :
> Basse Résolution (Spica, Hero, Magic, Dream, Dext, Eve...) :
Android 1.6 et + : http://www.hallerud.se/htc_ime_jonasl_lowres_25.zip
Android 1.5 (absence de "Voice Input") : http://www.hallerud.se/htc_ime_jonasl_lowres15_25.zip
> Haute Résolution (Nexus One, Milestone, Liquid,...) : http://www.hallerud.se/htc_ime_jonasl_hires_25.zip
Installation :
> Installer l'APK
> Dan les paramètres "Clavier", cocher "Touch Input"
> Aller sur un champ de texte (comme une recherche par exemple)
> Maintenez le doigt sur le champ
> Appuyez sur "Selection Mode de saisie" puis sur "Touch Input"
Customizable language settings
Smileys hacked into the hide key (see screen shots)
Custom smileys
Installs also on Android < 2.1
Custom word candidate bar that raises the keyboards so dictionary won't cover the app you type in
Prediction in fields with own suggestions (search bar etc.)
Prediction in fields that sets the filter flag
Prediction in URL fields
Disable automatic capitalization
Play sounds in silent mode
Set sound level
Automatic space insertion
Enable prediction with cursor in or adjacent to existing words (QWERTY only)
Enable a space bar key in URL keyboard (experimental)
Prediction for physical keyboard (reported working, not tested by me)
Support for German QWERTZ hard KB layout
Show voice input button for all keyboards with a settings button
Swipe right for voice input on any keyboard
Swipe left to delete word
Swipe down to hide keyboard
Disable key preview popup
Use Google development server for voice (supports German but isn't online 24/7)
Position of word candidate list is saved if you long press and move it
Left align word candidate list
MANY HTC bugs fixed, the changelog for a few of them
Droid landscape support with resolution related glitches
User dictionary import/export (for backup or building your dictionary on your computer)
User dictionary accepts any character, not just HTC approved ones
Custom vibration length
Character replacement (can remove diacritic chars)
pi** key in qwerty mode
My source code is now available for your own modding pleasure
Screenshoot :
Modifié par Zoozloz
  • Réponses 132
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
bonjour a tous je suis nouveau et j'ai voulu installer ce clavier donc apres le telechargement j'ai reussi a grace a astro a installer deux fichier clicker et htc ime mais apres je ne trouve pas ce nouveau clavier comment es ce qu'il faut faire pour l'installer correctement ?
merci par avance.
@foxy38:
tu ouvres le clavier de base, tu fais un appui long sur la touche 123 et la tu choisis 'touch input' comme méthode de saisie ;)
J'ajoute que sur mon Nexus One, il a fallu que j'ailles dans Paramètres>Langues et clavier, puis il a fallu que je coche "Touch Input".
PS @ unixseb : tu parles de transparence ? C'est une envie ou on peut le faire ? Y a des thèmes pour ce clavier ? Merci pour ta réponse.
Merci, c'est vrai qu'il est pas mal :) .
Par contre peut-on supprime certaines touches, ou encore changer la dispositions d'autres? Genre celle du smiley, qui me gêne plus qu'autre chose, ou encore la touche du passage au mode chiffre, que je ne trouve pas très bien placée...
Modifié par yaya69
Avec l'ancien clavier, on pouvait laisser la suggestion apparaitre, mais sans être automatiquement prise en compte après la barre "espace".
Avec le clavier amélioré, dès que je mets la barre "espace", un mot suggéré est mis automatiquement.
Comment faut il régler pour avoir des suggestions non-automatiques ?
Je n'ai pas la réponse a vos questions mais voici une update du clavier, la V19 :
Version 19: Options: Clear user dictionary, Swipe down to hide keyboard, Swipe left to delete last word, Character replacement (can remove diacritic chars), Custom smileys. Changed: Import/export of user dictionary is now threaded, pi** key added to qwerty symbol keyboard, Fixed voice hack was enabled by default even if disabled in settings
Et j'actualise le premier post pour inclure les nouveautés ;)
Maintenant la V19 est accessible en haute et basse résolution donc je pense qu'il faudrait déplacer le topic, à voir ;)
Modifié par Zoozloz
> Installer l'APK
Voila ;) Je l'inclus au premier post ! :)
