Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 (modifié) Gros changelog à venir : to be included in next nightly: Update reboot and screenshot drawables (android_frameworks_base) Added a setting to do nothing/snooze/dismiss an alarm by flipping the device. (android_packages_apps_DeskClock) Use preferences from default launcher (android_packages_apps_Settings) Fix for wrong selection of sms template (android_packages_apps_Mms) opengl: remove tegra errata duplicates (android_frameworks_base) Add Hungarian predictive dictionary support - settings item (android_packages_inputmethods_LatinIME) Revert Hungarian keyboard to qwertz and add alternative qwerty layout (android_packages_inputmethods_LatinIME) Add Hungarian accents (required for the predictive dictionary to work) (android_packages_inputmethods_LatinIME) MemoryHeapBase: ifdef for gingerbread compatibility (android_frameworks_base) telephony: CDMA: fix ERI display when device is in airplane mode (android_frameworks_base) Additional fixes for button/keyboard backlight auto-brightness. (android_frameworks_base) Modified Torch string references for cleaner UX (android_packages_apps_Torch) PanoramaActivity: null pointer exception (android_packages_apps_Camera) Camera: sanity check for camcorder frame format parameter (android_frameworks_base) Extended quick controls for tablet-like controls on phones (android_packages_apps_Browser) frameworks/base: surfaceflinger: Enable dither if needed (android_frameworks_base) FontRenderer: do not leak mIndexBufferID (android_frameworks_base) SurfaceTexture: Reset buffer values on disconnect. (android_frameworks_base) Surfaceflinger: Add Src orientation for the layer (android_frameworks_base) Handling EGL_BAD_ALLOC egl error as return from swap (android_frameworks_base) SurfaceFlinger: Return the current transform value when queried (android_frameworks_base) Add lookup in Call logs to lookupNumber (android_packages_apps_Contacts) Settings: Data usage: Linear chart option and 2GB to 100MB vertical axis limit. (android_packages_apps_Settings) use TARGET_RECOVERY_FSTAB location if defined (android_bootable_recovery) Fix sent SMS timestamp display (android_packages_apps_Mms) J'attend particulièrement : "Added a setting to do nothing/snooze/dismiss an alarm by flipping the device" et "Extended quick controls for tablet-like controls on phones" Modifié 13 mai 2012 par diogo65 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoRiTo Posté(e) 13 mai 2012 Auteur Share Posté(e) 13 mai 2012 Les serveurs sont out, faut patienter. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 La prochaine version, ça veut dire celle du 14/05 ? Je suis encore avec celle du 11/05, s'il faut je peux attendre avant de faire la mise à jour, pour faire la " grosse mise à jour ". Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoRiTo Posté(e) 13 mai 2012 Auteur Share Posté(e) 13 mai 2012 Vaut mieux attendre, car celle du 12 n'a pas grand chose d'intéressant ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 (modifié) Non, la 13/05 est déjà dispo... => http://download.cyan...device=galaxys2 <=, c'est celle-là qui est senser avoir un gros " changelog " ? Modifié 13 mai 2012 par Neutre0 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lolilolmartin Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Mmmh va voir au premier post sur le site du changelog et tu auras ta réponse :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Excuse-moi, j'ai complètement loupé le lien tantôt quand je l'ai cherché dans le premier poste. Oui, effectivement c'est la version du 13/05 qui a un " gros change log ". Ils ont ajouté de nouveaux point sur le " changelog " que @Diogo65 nous a publié : Power widget & tether: Restore ICS drawables, replace/create xhdpi drawables (android_frameworks_base)Prevent Sym key from showing the IME picker (android_frameworks_base) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
opopop Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Pas ce problème de mon coté. J'ai un trcu qui vient de temps en temps, mais je ne sais pas si c'est à cause de la rom ou à cause de mes tunings Voltage controle et Lulzactive : Parfois,e n sortie de veille, le mobile RAME, à en être inutilisable. J'ai l'impression qu'il ne sort pas complètement du mode veille (à 100MHz pour moi). Vous avez ça ? Je vais aussi poster dans le topic des optimisations. il est déconseillé de mettre 100 Mhz en fréquence minimal je crois. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 C'est donc celle du 13, je l'installe immédiatement ! :) Non, la 13/05 est déjà dispo... => http://download.cyan...device=galaxys2 <=, c'est celle-là qui est senser avoir un gros " changelog " ? Par contre je ne vois pas celle du 13 de dispo ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoRiTo Posté(e) 13 mai 2012 Auteur Share Posté(e) 13 mai 2012 Idem, je ne vois que celle du 12 ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tux0307 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Il en a fumé de la bonne le salop ! Sur ce ! 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lolilolmartin Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 En Belgique on a de la bonne :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoRiTo Posté(e) 13 mai 2012 Auteur Share Posté(e) 13 mai 2012 (modifié) Et en Hollande c'est fini pour les non-résidents ^^ edit : ta signature est largement visible :) Modifié 13 mai 2012 par DoRiTo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lolilolmartin Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Lol mais ça c'est ce que tu crois ^^' Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tibob77 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 il est déconseillé de mettre 100 Mhz en fréquence minimal je crois. La fréquence minimale de mon cpu en ondemand est de 100Mhz et je n'ai jamais eu de problèmes. Ca m'est déjà arrivé en revanche avec smartass2 sur un tel d'une autre marque.. En passant je vois que ca parle fumette, à la votre ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 J'ai loupé des choses là ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Et passant, je me dis que les S2 sont pas que des amateurs de customisation Android ! Enjoy ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 (modifié) diogo65 : Dans ta signature 'Defy CM9 - Touchpad CM9' ? EDIT : Excuse, j'ai pigé que now ! Modifié 13 mai 2012 par Invité Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Ce sont deux autres appareils sous Android que je possède. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lolobarjo Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Celle daté du 12 est celle d'aujoud'hui depuis un petit moment les dates sur les MaJ son décaler d'une journée. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 (modifié) Pourtant sur d'autres appareils, celle du 13 apparaît bien sous la bonne date ... Edit : Ceci dit elle est bien sorti aujourd'hui : 2012-05-13 06:26:20 Modifié 13 mai 2012 par diogo65 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Je voulais savoir, à quoi sert encore l'appli Busybox, parce que je l'ai transférée de mes anciens backups, mais plus moyen de me souvenir de ce pourquoi elle est faite. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tibob77 Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 (modifié) C'est une appli qui regroupe un ensemble de commandes linux non integrées en natif et qui sont essentielles au bon fonctionnement de CWM par exemple... Edit:tappes busybox dans un terminal ;) Modifié 13 mai 2012 par T!b Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lolobarjo Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Pourtant sur d'autres appareils, celle du 13 apparaît bien sous la bonne date ... Edit : Ceci dit elle est bien sorti aujourd'hui : 2012-05-13 06:26:20 Je veut dire que le nom de la MàJ mis en ligne date d'un jour avant Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 mai 2012 Share Posté(e) 13 mai 2012 Oui j'avais bien compris, et je te disais que sur le site Cyanogenmod, certains appareils ont la mise à jour du treize estampillé 13. ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
