[ROM] [2.3.7] LiGux (Coopoui) (v3.2 - 09/01/2012)
Posté(e) (modifié)
la version [ROM][2.3.7] LiGux (Coopoui) (RC2.0 - 01/12/2012)[Port] vient de sortir.
Topic officiel :http://forum.xda-dev...d.php?t=1435655
Fonctionnalités :
This rom is basically a highly themed CM7.2. I give all credit to the developers of LiGux, Coopoui, CM, and the Heroc. It includes the expanded LiGux settings which allows a lot of customization. I'll expand on customization/options in the second post. It features an MIUI-ish expanded statusbar with toggles for all the common settings.
[u]Changelog:[/u]
BUILD CHANGES FROM PREVIOUS RELEASE
* SystemUI, framework, settings are all updated now.
* SystemUI and settings are all compatible... no more settings force close
* Completely new UI
* Includes LiGux boot animation (I can provide the old one if you'd like it)
* Edited LatinIME to match the gray-ish theme
* Fixed Chinese "new" message icon
* Removed some more Chinese
* Changed some text to fit better
* LiGux lockscreen (make sure you click it to allow it)
Removed Chinese from many, many various locations
Edited build.prop to remove unnecessary info and align it with current CM build.prop
Removed battery and memory tweaks from boot.img
Removed a few init tweaks
Modified updater-script to align with up-to-date CM standards
Changed available cpu freqs to standards in boot.img and framework
Edited eri.xml in framework-res to add Sprint
Replaced PinyinIME with LatinIME (keyboard)
Edited MMS settings in framework to remove Chinese carriers and align with CM settings
Edited apn settings in framework to align with CM
Fixed a few mis-translated words and a couple missing translations
Fixed text sizes in apps that were lost in translation
Fixed messaging menu force close with Kirin update
Updated included gapps
Updated Coopoui and LiGux to latest available versions (3.2)
Updated system files to latest from CM
Removed Chinese 'market crack' options (plan on removing this completely from settings)
Added 'missing' apks and removed Chinese apks
Fixed a few mistakes and a whole lotta little things.
have built in the Latest LV kernel(thanks to reimer for this!)
Problèmes connus :
Pour ceux qui comme moi ne sont pas des dieux en anglais, je vous conseille d'installer gratuitement More locale 2 : https://market.andro....ccl.morelocale
LED lights(must've missed something while porting)
The 4G and flashlight settings don't work on the toggles (sorry, no magical 4G!)
Téléchargement :http://www.mediafire.com/?17155spdnsbtf91
Screenshoots :
Modifié par batien
Posté(e) (modifié)
Malheuresement pas en français ... Enfin c'est surtout avec le clavier ou c'est vraiment génant :/
Mais More Locale 2 passe t'il la correction orthoghraphique en FR ?
Sinon j'ai testé, le "skin" est un "home" Launcher pro est aussi installé; perso je préfére Launcher Pro.
Mais le clavier étant rebutant j'ai abandonné les tests plus en profondeur :(
A re-tester peut'étre avec More Locale ? j'y ai pas pensé
Modifié par Vincoll
@Vincoll : More locale 2 permet de changer la langue, le clavier et la correction orthographique. Donc pas de soucis même tout n'est pas traduit.
Tu es quand même au courant qu'il existe des claviers alternatifs avec parfois des dictionnaires FR pré-installés ?
Sinon, c'est une ROM bien sympa et assez épurée, légère mais je n'ai pas trouvé de réel bénéfice à utiliser celle là plutôt qu'une autre. Cela reste mon avis, je préfère des firmwares basés sur CM7.1.
Alors je test depuis 5 Jours ...
j'ai mis More locale pour la clavier en FR.
Les +
La barre CM en notification est déporté sur la droite en un espéce de popup , super personalisable c'est agréable.
Aucune remarque sur une lenteur particuliére, c'est même assez réactif pour un Hero.
Les -
La home est jolie mais pas fluide sur le switch de bureau,
Sa bug ! Le reseau ne se reveille pas forcément à la sortie du mode avion, j'ai pas de demande de PIN
Le Popup SMS de GO SMS fait planté la Home
Depuis se matin et malgré un GPS désactivé j'ai l'icone qui clignote .
Pas de LED mais vraiment aucune !
Le lockscreen est sympa en apparence mais pour débloquer le tel avec l'écran faut étre assez précis pour bien placer le délocker sur l'icone de déverouillage . (On peut se mettre avec les 2 icones basiques si on veut quand même)
Le mode appel est modifié et pas pratique.
Bref Je CHANGE !
@Xkz tu utilises quoi comme ROM ? la decked eelney ?
Dual boot.
J'ai d'un côté la 2.1 officielle et de l'autre la decked X à laquelle j'y ai ajouté quelques features.
