Zoozloz Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 (modifié) Et oui tout cela vient des forums d'XDA où semblerait quelqu'un a reussit a mettre la main sur une version alpha de Fennec ! :cool: Apparemment cela est réservé aux Nexus One et Milestone, si vous n'etes pas sur Android 2.X, pas la peine d'essayer par contre si vous etes sur des ROM en 2.X sur des téléphones différents, n'hésitez pas à mettre des retours ;) ROM incompatibles : >VillainROM 4.2 (Legend) MartinSchirr over at Android Forums has compiled Fennec for Android, with a demo video and everything. I've tried it to no result on my N1 (hit launch, screen went black and my phone hung; I suspect it's because I'm using apps2sd), but I dunno, maybe you guys might have better luck. Guy's server seems a tad slow, so I slapped it on Sendspace here: http://www.sendspace.com/file/g6kp6p Update: okay, gave it another whirl. The person responsible for compiling this wasn't kidding about 41 MB; even with apps2sd, it still takes up roughly 33 MB of internal storage. Giant ouch. And here I thought Google Earth was big. The initial launch results in a black screen and the OS hanging. Not sure why or what it is doing there, but as iSecks said, after rebooting it works. Sort of. I can't for the life of me type in a URL. Kept poking at the address bar and inputting random letters, but no go. This was compiled for use on the Droid, so it may very well not gel with an N1 (I've got Modaco Desire ROM, for what that's worth). If anyone's had better success on an N1, I'd like to hear about it. Still, I must say that it looks a lot more sophisticated than any other Android browser available right now. Pourma part je vais télécharger et voir ce que cela donne (n'oubliez pas de désinstaller d'autres applications avant car 41Mo ca en fait quand meme :p) Screenshoots http://forum.xda-developers.com/attachment.php?attachmentid=301297&d=1269961572 http://forum.xda-developers.com/attachment.php?attachmentid=301298&d=1269961572 Modifié 30 mars 2010 par Zoozloz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mateo95 Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 41mo !!!! Ça vous semble pas énorme quand même non? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 30 mars 2010 Auteur Share Posté(e) 30 mars 2010 Mozilla avait annoncé l'application lourde (dans les 30Mo) donc bon après faut voir ce que ca vaut comme navigateur, selon les retours après un (ou deux) reboot, cela marche bien (enfin mieux que ce que l'on peut espérer d'une alpha dont le produit sort 6 mois apres :p) mais reste encore un petit peu lent pour un usage quotidien. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Louis62 Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Je teste merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
de39 Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 je test ça de suite ! Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepez Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 On attends vos retour ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 30 mars 2010 Auteur Share Posté(e) 30 mars 2010 Bon bah moi c'est rapide, apres deux reboot, toujours un beau FC :p (ROM du Legend en 2.1 ;)) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 http://androidandme.com/2010/03/news/fennec-gets-compiled-for-the-motorola-milestone/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+androidandme+%28Android+and+Me%29 plus d'infos :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
de39 Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Hum ça marche pas sur mon Hero .... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Armoire Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Ne marche pas sur un Magic 32B Rom d'origine (Installation impossible) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 30 mars 2010 Auteur Share Posté(e) 30 mars 2010 D'apres les retours cela ne marche que sur les Nexus et le Milestone, je le met dans le premier post mais si jamais cela marche sur une de vos ROM, n'hésitez pas a le dire ! :) (Par contre compatible uniquement 2.X il me semble) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 c'est au stade alpha vu la stabilité, mieux vaux attendre Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fraggy94 Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 ne marche pas sur spica en 2.1,pas de fc,mais il y a un carré blanc avec marqué launch. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ABÜ Posté(e) 19 mai 2010 Share Posté(e) 19 mai 2010 Visiblement l'Apk est téléchargeable en Pre-Alpha http://www.androidguys.com/2010/05/19/prealpha-test-firefox-android/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Toucool Posté(e) 19 mai 2010 Share Posté(e) 19 mai 2010 Mais enfaite, c'est quoi "Fennec" ? (euh oui newbiie :] ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
panda Posté(e) 19 mai 2010 Share Posté(e) 19 mai 2010 La version mobile de Firefox de la compagnie Mozilla ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
NeB Posté(e) 19 mai 2010 Share Posté(e) 19 mai 2010 C'est "Firefox" pour téléphones Android , si on peut dire. Un navigateur pour android développé par la fondation Mozilla. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Toucool Posté(e) 19 mai 2010 Share Posté(e) 19 mai 2010 Ah ok ! Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jorodan Posté(e) 20 mai 2010 Share Posté(e) 20 mai 2010 Très sympa! 10Mo c'est lourd mais vraiment original comme approche! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
prog-amateur Posté(e) 20 mai 2010 Share Posté(e) 20 mai 2010 Alors ça donne quoi ? Aussi lent que l'ancienne version alpha ou des améliorations ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jorodan Posté(e) 20 mai 2010 Share Posté(e) 20 mai 2010 Sur le N1 ca passe bien! Mais je ne suis pas très exigeant! Avec Froyo ca va tracer :) (ou pas parce que je crois que ca passe par le NDK) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chensp Posté(e) 20 mai 2010 Share Posté(e) 20 mai 2010 alors ça change quoi par rapport au navigateur par defaut ??? sur Legend ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jorodan Posté(e) 20 mai 2010 Share Posté(e) 20 mai 2010 BEAUCOUP de choses! Teste tu verras :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chensp Posté(e) 21 mai 2010 Share Posté(e) 21 mai 2010 mdr au moins ça c'est fait ! lol ok je vais voir ça ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 3 juin 2010 Share Posté(e) 3 juin 2010 mise a jour en nighty build elle passe de 30 a 9 mb :D source : http://www.nexusoneforum.net/forum/nexus-one-google-phone-news/5936-new-fennec-build-its-getting-great.html?utm_source=twitterfeed&utm_medium=twitter Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
