Spyder-ferrari Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 (modifié) [ GINGERBREAD (2.3.4/5/6) Kernel 2.6.32.56] CWM File ==> Unified GB Kernel Version 024 @ 1.45 GHz CWM File ==> Unified GB Kernel Version 024 @ 1.3 GHz CWM File ==> Unified GB Kernel Version 024 @ 1.0 GHz [ CYANOGENMOD 7 Kernel 2.6.32.56 ] CWM File ==> Unified CM7 Kernel Version 024 @ 1.45 GHz CWM File ==> Unified CM7 Kernel Version 024 @ 1.3 GHz CWM File ==> Unified CM7 Kernel Version 024 @ 1.0 GHz [ Installation: ] [ CWM Method ] 1. reboot to CWM 2. Clear cache 3. install zip from SDcard 4. Reboot Changelog - Version 024 switched to fast NoHz tree RCUCompletely rebuilt from scratch based on ATT 4591 baseline Both Stock and Cyanogen now share the same baseline code base Patched to latest kernel.org 2.6.32.56 Fixed some warnings during compilation enabled NETFILTER_XT_MATCH_MAC (for wifi tethering app users) arm/vfp: vfp_pm_suspend: Use local variable instead of rereading from register ARM: vfp: clear fpscr length and stride bits on entry to sig handler ARM: vfp: move user vfp state save/restore code out of signal.c ARM: vfp: flush thread hwstate before restoring context from sigframe crc32: Don't reference unnecessary crc32 tables in single-bit mode ARM: proc-v7.S: remove HARVARD_CACHE preprocessor guards ARM: net: JIT compiler for packet filters enabled by default ARM: net: JIT compiler for packet filters include/filter.h: add missing rcu_types.h for kernel usage ARM: hwcaps: add new HWCAP defines for ARMv7-A ARM: hwcaps: use shifts instead of hardcoded constants mmc: fix deadlock from mmc core when suspend the device mmc: change mmc_delay() to use usleep_range() nohz: Remove ts->inidle checks before restarting the tick Modifié 5 février 2012 par Spyder-ferrari 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shirosagi Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 Miam. Merci bien pour ce superbe réveil... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
foxxy Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 (modifié) Quest-ce-qu'ils rapportent de plus ces kernels à part l'overclock? Essayé mais ça me met failed to boot 2 à chaque fois donc obligé de reflasher avec un sbf sur rsd lite ! Modifié 5 février 2012 par foxxy Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shirosagi Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 Tu as déverrouillé ton BL ou pas? Quel recovery? Comment tu fais??? Téléchargement + Transfert sur SD + Reboot en recovery + Flash + Wipe Cache/Dalvik + Reboot ça m'as prit quoi.... trois minutes max... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
N'oliv Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 (modifié) Ouaip, mais quels sont les réels avantages ? L'overclock donne-t-il un gain de performances ? Sans plantage ? Mes dernières expériences (sur mon ancien mobile) n'étaient pas concluantes, surtout en ce qui concernait la stabilité et l'autonomie Modifié 5 février 2012 par Noliv Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
foxxy Posté(e) 8 février 2012 Share Posté(e) 8 février 2012 Est-ce-que ces kernel sont compatibles avec une version retail fr ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shirosagi Posté(e) 8 février 2012 Share Posté(e) 8 février 2012 Lis ma signature. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
foxxy Posté(e) 8 février 2012 Share Posté(e) 8 février 2012 (modifié) Effectivement :) Les kernel OC consoment-ils beaucoup de batterie en plus ou pas tant que ça? Et celui qui est juste optimisé mais qui reste à 1Gh, je suppose qu'il pompe moins que les autres. Modifié 8 février 2012 par foxxy Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
N'oliv Posté(e) 11 février 2012 Share Posté(e) 11 février 2012 J'hesite à passer sur un Kernel Overclocké : histoire de profiter un peu mieux de mon Lapdock. Un conseil serait bienvenu, du moins des retours des utilisateur. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Delewer Posté(e) 11 février 2012 Share Posté(e) 11 février 2012 Comme l'a dit Foxxy, le kernel de 1Ghz cossomme moins que celui OC. Cela dis, le Lapdock est alimenté, donc il suffit de mettre un profil dans Setcpu pour OC totalement son kernel quand le telephone est branché, et de limitter la vitesse maximum quand il est debranché. Le seul inconveniant du kernel OC, est que l'on peut "beaucoup" moins l'undervolter", c'est à dire diminuer la tension d'alimentation du processeur, pour qu'il consomme moins... Et comme ce n'est pas une science exacte, cela differe d'un téléphone à l'autre. Si tu n'a jamais UV ton processeur, tu devrais y gagner, sinon, tu y perdra plus que tu n'y gagnera en dehors de l'usage de ton Lapdock. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
foxxy Posté(e) 11 février 2012 Share Posté(e) 11 février 2012 Moi j'arrive pas à bien maitriser les UV (de combien baisser et à quel pallier) et ainsi l'UV permettrait-il de consommer encore moins de batterie? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Delewer Posté(e) 12 février 2012 Share Posté(e) 12 février 2012 Oui en effet, c'est le principe même. On "undervolt" jusqu'a instabilité du système. On a alors la limitte basse, et on remonte un peu.. On a alors l'UV le plus stable et le plus économe en energie. Il faut le faire pour chaque palier de fréquence. Par exemple, en mettant, sur Setcpu, le fréquence basse et haute à la même valeur, et en laissant tourner tout ça une demi journée, puis en lançant Quadrant 3 ou 4 fois (ou en lançant un jeu en 3D) Dès que l'UV est validé pour cette fréquence, on recommence pour le frequance suivante. A la fin, on a la tension optimum (minimum plutôt) pour chaque fréquence. Voilà le principe. On y arrive aussi en tattonant, mais on galère toujours sur une ou deux fréquence en général. La tension la plus importante, c'est celle qui sera attribuée à la fréquence "écran éteind" (à regler dans Setcpu) C'est là où on va vraiment économiser. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DNAngel Posté(e) 12 février 2012 Share Posté(e) 12 février 2012 Est ce que setcpu va regler tout ca lui meme ou il faut le configurer? Sur le forum du X10, il y avait des tuto pour les profils setcpu mais ici je ne trouve rien Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Delewer Posté(e) 12 février 2012 Share Posté(e) 12 février 2012 Non, il faut configurer soit même. Et pour compliquer le tout, il y a des régles à suivre... de palier de tension. Tout les Kernels ne permettent pas le réglage en plus. Pour le Kernel de Faux, ou de Clemsyn, ça marche pas mal Regarde ici : http://forum.xda-developers.com/showpost.php?p=22237661&postcount=6 Le type a reglé les tensions (colonne à gauche en blanc), de 925mv à 400mv, soit, sans jamais dépasser un palier de 100mv Si jamais il avait mis, pour le 312Mhz, une tension à -300mv, la tension à cette vitesse serait revenu à celle par défaut, car on aurait dépassé le palier de 100mv (on aurait eu 775mv au lieu des 475mv désirée). Ca à l'air compliqué, mais on prend le coup. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DNAngel Posté(e) 13 février 2012 Share Posté(e) 13 février 2012 Merci. Je regarde tout ca demain au boulot Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shirosagi Posté(e) 23 février 2012 Share Posté(e) 23 février 2012 Bon. Je reviens ici faire un rapport après presque 20 jours d'utilisation de ce kernel 0.2.4... Je ne sais pas ce qu'il donne pour les autres mais moi j'ai décidé de repasser à la version 0.2.3. J'ai eu droit à un peu de tout: reboot en étant branché en usb, problème de localisation GPS, perte de signal réseau, et surtout ce qui m'a vraiment décidé à revenir en arrière, à savoir une autonomie vraiment exécrable. 8h tout juste en normal alors qu'à utilisation équivalente je tenais le double avec le kernel précédant. Bref, je passerais sans doute à la 0.2.5 pour voir si c'est mieux, mais cette version 0.2.4 ça sera sans moi... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DNAngel Posté(e) 23 février 2012 Share Posté(e) 23 février 2012 J'ai testé la baisse de tension. Sauf que j'ai pris le kernel a 1,3Ghz donc les voltages sur xda ne passent pas. J'ai eu droit a un freeze et reboot obligé. Du coup Shiro, tu fait comment? Tu pourrais faire un petit tuto pour noob comme moi? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xkz Posté(e) 23 février 2012 Share Posté(e) 23 février 2012 J'ai testé la baisse de tension. Sauf que j'ai pris le kernel a 1,3Ghz donc les voltages sur xda ne passent pas. J'ai eu droit a un freeze et reboot obligé. Du coup Shiro, tu fait comment? Tu pourrais faire un petit tuto pour noob comme moi? C'est en fonction de ton téléphone après, une tension qui marchera pour toi ne marchera pas forcément pour un autre. Quelles étaient tes réductions en mV pour chaque pas ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shirosagi Posté(e) 24 février 2012 Share Posté(e) 24 février 2012 Sur la baisse de tension? Plus simple, c'est de faire par palier de 25mV en "bloquant" la fréquence... Dès que ton Atrix devient instable (freeze ou reboot), il faut remonter de 25mV. Il faut refaire la même chose à toutes les fréquences. Pour ma part, j'ai 7 fréquences à régler: 1,45GHz, 1,30GHz, 1,20GHz, 1GHz, 800MHz, 456MHz, 216MHz. En tout cas, pour chaque Atrix ce sera différent...Donc c'est pas étonnant que les valeurs que tu as trouvé sur xda ne fonctionnent pas sur le tien. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xkz Posté(e) 24 février 2012 Share Posté(e) 24 février 2012 Pour chaque freq max ou freq min, tu aura toujours 7 pas avec le kernel de faux123 (ou même celui de Clemsyn d'ailleurs). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DNAngel Posté(e) 2 mars 2012 Share Posté(e) 2 mars 2012 Bon ben pour l'instant j'ai baissé de 50 pour chaque palier. Le system est parfaitement stable (juste 1 reboot depuis qu'il est installé mais je pense que ce soit lié aux tensions). J'ai testé tout ca avec stability test sur le market. Pour l'autonomie, elle est tres bonne. Je tiens plus de 30 heures a l'aise en usage normal : un peu de net, une 20aine de minutes d'appel, des sms. Pour les voltages, je passe de 1300 mV pour 1300 MHz a 700 mV pour 216 MHz. Par contre j'ai reglé des profils avec setcpu ou le proc est bridé a partir de 30% de batterie (max 1000 MHz) et très bridé a 20% (max 800 MHZ). Il est aussi bridé a 800 MHz pendant les appels. Du coup j'economise pas mal de batterie sans perdre en réactivité. Je n'ai pas encore testé de tensions plus basses mais si quelqu'un a testé, ca m'interesserais, je me lancerais aussi du coup. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
N'oliv Posté(e) 21 mars 2012 Share Posté(e) 21 mars 2012 (modifié) CWM File ==> Unified GB Kernel Version 024 @ 1.45 GHz Bon allez je me lance, je teste celui-ci. Je verrais à l'usage et ne manquerais pas de vous donner mes impressions, plantages, et surtout retombées qui seront positives... :D j'espère. Sachant que je tourne avec la Motorola Retail 2.3.4... Retour d'infos après quelques jours d'utilisation : Stable : aucun reboot constaté Consomme de la batterie : je trouve l'autonomie moins bonne qu'avec le Kernel Stock, malgrès le Downclocking à 1000 Mhz et l'utilisation à 1450 hz uniquement lors de l'utlisation du Lapdock En gros rien de plus, rien de moins... Si ce n'est un lapdock plus réactif.... Modifié 26 mars 2012 par Noliv Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kyusu Posté(e) 19 avril 2012 Share Posté(e) 19 avril 2012 Jai tester la version 1ghz_24 pour la cyano7 ca consomme bcp de batterie alors que le tél est en veille. 1ghz_23 est plus autonome . Quelqu'un d'autres a remarquer ceci ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xkz Posté(e) 19 avril 2012 Share Posté(e) 19 avril 2012 Oui. faux123 devrait sous peu upload ces nouveaux kernels, il est en train de le faire actuellement pour plusieurs autres modèles. (En espérant que le tethering et la gestion du scaling par gouverneurs soit possible) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kyusu Posté(e) 19 avril 2012 Share Posté(e) 19 avril 2012 tethering c'est bien le fait d'envoyer le net du telephone vers le pc via une cable usb ? Chez moi ca marche deja ca. Oui sur le defy quand on mets le gouverneur en ondemand c'est moins econome en batterie que interactive. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
