[ROM's] by Scorpio92 2.1|2.2|2.3|4.0
WELCOME TO THIS THREAD
Je le traduirai en français
Original thread:
http://4pda.ru/forum...howtopic=259783
http://forum.xda-dev...d.php?t=1477527
ALL CREDITS GO TO SCORPIO92
OptimalPerformance v1 (2.1)
Features:
* data2system
* built-in acceleration
* 2 new governors: Minmax & Scary
* Dalvik-cache moved to /cache (for more space for user applications)
* Various tweaks to the performance, Internet, Wi-Fi
* the amount of free RAM increased: 90mb +
* set the required software
* patched the hosts file on advertising
* Market Update is disabled
* Superuser v3.0.2 + Root Explorer v2.16
* fixed and changed a little theme
* bottles and animation changed some sounds
* init.d, support ext 2,3,4 etc. is not discussed
Download : http://depositfiles....files/8bgbyv6um
Extract, copy to sdcard/clockworkmod/backup and go to recovery, backup and restore, and restore like you usualy do that.
Screenshots:
OptimalPerformance v2 (2.1)
Changes from version v1:
* reduced weight to a minimum firmware
* 136mb partition on a date (the system does not d2s!)
* added apps (Swapper 2 - who needs a swap, Links2SD - transfer prog to stick, QuickPic)
* new RootExplorer, superuser
* amount of RAM increased slightly
* New patch antireklamny
* loud melody to call a couple more other
* animated theme
* More....
Download : http://depositfiles....files/z7etsgvol
Copy to sdcard and go to recovery and install it.
Screenshots:
IceFroyo beta (2.2)
Features:
* CM 6.1.2
* Based on core taken from OptimalPerformance v2 with lots of tweaks
* Built-in acceleration 480/768 MHz
* The camera writes video to mp4, 640x480, bitRate: 5 Mbit
* The most desired and necessary, replacing the standard, software
* Ice theme, animated
Work:
* GSM, APN
* Bluetooth
* Sensors
* Overclocking
* Haptic feedback
* Camera
* SD
* USB
* GPS
* Wi-Fi, WiFi Tethering
* Select the network
* Video Codecs
* 3D
* Reboot into Recovery & Fastboot Power through the menu
* Chips from CM
Bug:
* Black watch on a black status bar
Download : http://depositfiles....files/taibi4r88
Screenshots:
GLite (GingerbreadLite) (2.3)
My new custom GLite (GingerbreadLite) - based on AOSP 2.3.7 + team achievements OXYGEN
Features:
* All of the system *.apk deodexed
* Firmware is facilitated to the maximum (left only the most necessary), and the rest put option (optional)
* Various tweaks to set up an internal performance + TASK killer
* Section data is moved to cache (136mb freely under "yuzersky" application)
* All the latest versions of applications
* Camera (Video: 640x480 mp4 3Mbs, audio: codec aac, bitRate 102 400, sampleRate 44100)
* Slightly redrafted system graphics + animation added to the ICS (4.0) - is included in the display settings (all media)
* Chips with CM: Control points and edit the processor status bar in the settings + DSP Manager + Screenshot (in the Power Menu)
* Bootle disabled (for faster download)
* Clinging to automatically swap (preferably beat the map into 3 sections and make the swap partition from the recovery)
* Dispersal of 122-825MHz (the most optimal range, as the works at all)
* Standard overclocking 480/600MHz
* Ip tables + ext 2/3/4 + netfilter + blah blah blah ...
* If still remember, write ...
Work:
GSM, MMS, APN
GPS
WI-FI
WI-FI TETHER(?)
Bluetooth
BT HEADSET(?)
3D
Camera
Codecs (video and audio)
SENSORS
Vibration (full)
SD
FM Radio.
Not work:
Download: http://depositfiles....files/ddr28mvfi
Screenshots:
ICS4Optimus pre-beta (4.0)
Based on the latest beta version of the Mike (4 version in CM9).
Flash as easy as possible, and optimized to work much faster beta4.
Work:
GSM, APN
SD
Sensors
Vibration (Full)
Звук
USB Mass storage
Bluetooth
GPS
Acceleration
Reboot in recovery and fastboot
Not work:
Camera
Download: http://depositfiles....files/wykm6cxma
NOTE: FOR ME (AND SOME PEOPLE) IN GLite (GingerbreadLite)and ICS4Optimus pre-beta (4.0) WIFI DIDN'T WORK.
SI vous avez une question allez faire un tour sur le post original ou postez ici.
Modifié par Yvory
