[ICS-CM9] Coldfusion
oui afin la rom semble relativement fluide ce qui semble être une réelle avancée ! :
Should be slightly less iPhone and quite a bit better than gingerbread
En gros il ne manque plus qu'à corriger les nombreux bugs.
  • 1 month later...
http://android.modaco.com/topic/351670-ics-cm9-404-coldfusionx-for-the-zte-blade-rom-updated-3103/
Rom Details:
  • Android 4.0.4 - Ice Cream Sandwich!
  • Synced with latest CyanogenMod 9 repos
  • 2.6.35 kernel - based on ZTE stock Skate kernel
  • Full HW acceleration makes it faster than Gingerbread
My sources:
  • Device - github.com/ColdFusionX
  • Kernel - github.com/TomGiordano/kernel_zte_blade
Thanks go to:
  • Tom Giordano - being my mentor in developing for ZTE devices and basically being a general legend
  • CM Team for making an awesome ROM base
  • Skywave, Tom B and the rest of the ICS4Blade team - I, uh, "borrowed" a lot of their fixes
  • Maclaw and the GalaxyICS team - using their libaudio and some flags from them
  • drewis and Evervolv team - they were the ones that led me to enable OpenGL acceleration
  • The community - for testing and enthusing - I love doing what I do because of you guys
SEE SECOND POST FOR MORE INFO!
FLASH ORDER:
  • First: you should get the GAPPs and ROM and put them on your SD card
  • Now FORMAT SYSTEM <- VERY IMPORTANT
  • Then flash the ROM and any patches (if applicable)
  • After this wipe data
  • Then reboot out of recovery and let it boot into the ROM
  • After you let it sit on the launcher for ~ 5 minutes then reboot into recovery again
  • Now flash the GAPPs zip
  • And reboot out of recovery
  • The ROM should boot
  • Let it sit on launcher for another 5 minutes to stabilise.
  • If you still have problems post on the thread.
A2SD - S2E:
http://android.modac...coldfusion-ics/
Download:
30/03/2012:
Goo.im - http://goo.im/devs/t...lade-signed.zip
Putlocker Mirror - only use if the above absolutely doesn't work -http://www.putlocker...7098607A81A03BD
Mediafire mirror - thanks to colluc - http://www.mediafire...f8i7eb4b8ioqa06
Patch for video decoding to work - http://goo-inside.me...Patch-Blade.zip
Google Apps (Market, Gmail, etc.) - http://goo-inside.me...0317-signed.zip
J'utilise cette rom au quotidien, aucun gros bug a présent, fluide, stable, une merveille quoi ! Il reste plus qu'a corriger des petits bugs comme pouvoir lire les vidéo en HD sur Youtube et de pouvoir filmer :) Je recommande la coldfusion pour ceux qui souhaitent passer a ICS sur Blade !
