joyfrag Posté(e) 5 avril 2012 Share Posté(e) 5 avril 2012 Je voulais vous présenter cette Rom qui n'a pas encore de sujet sur ce forum, mais qui vaut le détour! Lien XDA Téléchargement : Toutes les versions sur min.us: http://minus.com/mbTSqS0sK GApps (from RootzWiki/goo-inside):http://wiki.rootzwiki.com/Google_App...Android_4.x.29 Script A2SD recommandé : mounts2sd 2.2.6http://www.cxsr.eu/p...php?dir=m2sd%2F Ne pas utiliser amarullz's data2sdx script. Cela provoque des bootloops à cause de la façon dont le script init.d scripts est utilisé dans la Rom AOKP. Installation: Flasher la ROM, ensuite GApps (c'est mieux sans rebooter). Passer de la Rom de Sandvold ou de CM9 peu fonctionner sans faire un data wipe, mais ne cela peu quand même provoquer un blocage. Full Wipe conseillé. Change Log : **Beta 5c synced with latest AOKP fixed WiFi (this time for real) **Beta 5, Beta 5b Failed builds **Beta 3 "No codename" minor changes mostly, but since you asked for it... a lot of changes to the way I build stuff (internally),regressions may be there clean rebuild against latest AOKP source weather on lockscreen more locations should be supported by the weather provider updated icons **Beta 2 "Unicorns!" update rebuild against latest AOKP source (aka build 25+) Lockscreen wallpapers Torch in power menu Airplane mode in power menu LCD density wizard added to fix Market with non-standard densities Option to show dBm instead of signal bars Lost of bugfixes, including random reboots etc. Added Google's LatinIME, dictionaries and stuff works now. Added AOKP official bootanimation (with unicorns!) **Beta 1 "Hitagi" clean rebuild against latest AOKP source (aka build 23+) quick torch feature end call button in notification tablet features added (as if we care ) update camera and libs Panorama mode works now barcode scanners work upstreamed some things, doesn't depend on anything Evervolv except binaries, so pure AOKP now much lighter, 183MB on /system (thus the codename). Also fits on Data++ w/o OpenWnn (aka Japanese IME) **FrankenBuild 4 http://ompldr.org/vY3A5Yg rebuild against latest AOKP source (aka build 22) toggleable adb notification power key as shutter in camera weather fixes and improvements (i.e. it's working now) new GApps package recommended (FULL WIPE) a lot lighter now, most downloadable apps are removed **FrankenBuild 3 http://ompldr.org/vY29rZA clean rebuild against latest AOKP source USB now works added live wallpapers (yay 227MB /system!) just a bit more APNs (should work with most US/European carriers, bug Google if it doesn't) **FrankenBuild 2 (http://ompldr.org/vY281dA) fixed init.d (that means app2sd/data2sd scripts should work now) update to the latest git **FrankenBuild 1 first release Remerciements (pas de traduction...désolé) : uge thanks to Sandvold, drewis, Evervolv and Team Kang people and everyone who reported bugs, tested and compiled to get ICS working on our devices. Without you guys, this could never have existed. Soyez indulgents, c'est mon premier Post ! :emo_im_undecided: Si vous avez des suggestions pour la tenue ou l'amélioration de ce topic, n'hésitez pas à m'envoyer un mp. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Foine Posté(e) 5 avril 2012 Share Posté(e) 5 avril 2012 Je vais essayer cette rom de ce pas. Mais j'ai néanmoins une question : quel script A2SD doit on prendre ? Aroma ou Legacy ? Je ne connais pas du tout ça ^^ EDIT : C'est bon pour arome/Legacy : ce sont les installeurs. J'avais pas fait le rapprochement. De plus, il faut le flasher après les Gapps ou bien ça ce fait tout seul ? EDIT : Après quelques temps d'essai : cette rom est très bonne. Tout fonctionne, même les mms qui me résistais sur celle de sandolv. En plus elle est même plus véloce que cette dernière. Le seul point négatif pour moi est la présence de trébuchet à la place du launcher stock. Je trouve en effet trébuchet moins bien optimisé pour une customisation vraiment gadget. J'ai donc mis nova mais c'est un peu pareil... Mais bon c'est tout de même très bon tout ça :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
