optimisation du build.prop
orefie
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JZO54K
ro.build.display.id=Orefie V1.2 opt Dans82
ro.build.version.incremental=eng.scm.1355138941
ro.custom.build.version=1355138941
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Mon Dec 10 19:29:50 CST 2012
ro.build.date.utc=1355138990
ro.build.type=user
ro.build.user=scm
ro.build.host=vanzo66
ro.build.tags=test-keys
ro.product.model=B92M
ro.product.brand=H958
ro.product.name=H958
ro.product.device=H958
ro.product.board=H958
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=PULID
ro.product.locale.language=fr
ro.product.locale.region=FR
ro.wifi.channels=
ro.board.platform=MT77_H958
# ro.build.product is obsolete; use ro.product.device
ro.build.product=H958
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=H958-user 4.1.2 JZO54K eng.scm.1355138941 test-keys
ro.build.fingerprint=PULID_F13/H958/H958:4.1.2/JZO54K/1355138941:user/test-keys
ro.build.flavor=mt77_h958_b92_pulid_jb
ro.build.characteristics=default
# end build properties
# begin mediatek build properties
ro.mediatek.version.release=ALPS.JB.MP.V1.13
ro.mediatek.platform=MT6577
ro.mediatek.chip_ver=S01
ro.mediatek.version.branch=ALPS.JB.MP
# end mediatek build properties
# system.prop for generic sdk
rild.libpath=/system/lib/mtk-ril.so
rild.libargs=-d /dev/ttyC0
# MTK, Infinity, 20090720 {
wifi.interface=wlan0
# MTK, Infinity, 20090720 }
# MTK, mtk03034, 20101210 {
ro.mediatek.wlan.wsc=1
# MTK, mtk03034 20101210}
# MTK, mtk03034, 20110318 {
ro.mediatek.wlan.p2p=1
# MTK, mtk03034 20110318}
# MTK, mtk03034, 20101213 {
mediatek.wlan.ctia=0
# MTK, mtk03034 20101213}
# MTK, TeChien {
ro.media.enc.hprof.file.format=3gp
ro.media.enc.hprof.codec.vid=m4v
ro.media.enc.hprof.vid.width=720
ro.media.enc.hprof.vid.height=480
ro.media.enc.hprof.vid.fps=30
ro.media.enc.hprof.vid.bps=3400000
ro.media.enc.hprof.codec.aud=amrnb
ro.media.enc.hprof.aud.bps=12200
ro.media.enc.hprof.aud.ch=1
ro.media.enc.hprof.aud.hz=8000
ro.media.enc.mprof.file.format=3gp
ro.media.enc.mprof.codec.vid=m4v
ro.media.enc.mprof.vid.width=352
ro.media.enc.mprof.vid.height=288
ro.media.enc.mprof.vid.fps=30
ro.media.enc.mprof.vid.bps=990000
ro.media.enc.mprof.codec.aud=amrnb
ro.media.enc.mprof.aud.bps=12200
ro.media.enc.mprof.aud.ch=1
ro.media.enc.mprof.aud.hz=8000
ro.media.enc.lprof.file.format=3gp
ro.media.enc.lprof.codec.vid=h263
ro.media.enc.lprof.vid.width=176
ro.media.enc.lprof.vid.height=144
ro.media.enc.lprof.vid.fps=30
ro.media.enc.lprof.vid.bps=384000
ro.media.enc.lprof.codec.aud=amrnb
ro.media.enc.lprof.aud.bps=12200
ro.media.enc.lprof.aud.ch=1
ro.media.enc.lprof.aud.hz=8000
# MTK, TeChien }
wifi.tethering.interface=ap0
ro.opengles.version=131072
wifi.direct.interface=p2p0
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=128m
# Encrypt phone function
ro.crypto.tmpfs_options=mode=0771,uid=1000,gid=1000
ro.crypto.fs_type=ext4
ro.crypto.fs_real_blkdev=/emmc@usrdata
ro.crypto.fs_mnt_point=/data
ro.crypto.fs_options=noauto_da_alloc
ro.crypto.fs_flags=0x00000406
# USB MTP WHQL
ro.sys.usb.mtp.whql.enable=0
# Power off opt in IPO
sys.ipo.pwrdncap=2
ro.sys.usb.storage.type=mtp,mass_storage
# USB BICR function
ro.sys.usb.bicr=yes
# USB Charge only function
ro.sys.usb.charging.only=yes
# audio
ro.camera.sound.forced=0
ro.audio.silent=0
# ADDITIONAL_BUILD_PROPERTIES
ril.specific.sm_cause=0
gps.solution.combo.chip=1
fmradio.driver.chip=1
ro.sf.hwrotation=0
ril.current.share_modem=2
launcher2.allappsgrid=3d_20
curlockscreen=1
ro.mediatek.gemini_support=true
persist.radio.fd.counter=20
persist.radio.fd.off.counter=20
drm.service.enabled=true
fmradio.driver.enable=1
dalvik.vm.mtk-stack-trace-file=/data/anr/mtk_traces.txt
mediatek.wlan.chip=MT6620
mediatek.wlan.module.postfix=_mt6620
ro.config.notification_sound=S_Whistle.ogg
ro.config.alarm_alert=Daw_chorus.ogg
ro.config.ringtone=25_The_secret_forest.ogg
ro.init.screen_brightness=255
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.setupwizard.mode=DISABLED
# Disable Kernel Error Checking
ro.kernel.android.checkjni=0
ro.kernel.checkjni=0
# 3G signal and speed tweaks
ro.ril.hsxpa=2
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=10
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=5
# Saves some battery without reducing performances
wifi.supplicant_scan_interval=180
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
# Increase camera's photo and video recording quality
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
# Connect and disconnect faster (experimental)
ro.mot.eri.losalert.delay=1000
# More free ram and apps load faster
dalvik.vm.dexopt-flags=m=y
# Deeper Sleep to save battery
pm.sleep_mode=1
# Reduce dial-out time
ro.telephony.call_ring.delay=0
# Increase jpg quality to 100%
ro.media.enc.jpeg.quality=100
# Better Flashlight intensity and camera-flash quality
ro.media.capture.flash=led
ro.media.capture.flashMinV=3300000
ro.media.capture.torchIntensity=40
ro.media.capture.flashIntensity=70
# Keep launcher in memory to reduce redraws
ro.HOME_APP_ADJ=1
# Better internet browsing & download speed
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
# Increase general Performance
debug.performance.tuning=1
# Reduce the black screen time of the proximity sensor
ro.lge.proximity.delay=25
mot.proximity.delay=25
# Allow purge of assets to free more ram
persist.sys.purgeable_assets=1
# Better Scrolling responsiveness and speed
windowsmgr.max_events_per_sec=150
ro.max.fling_velocity=12000
ro.min.fling_velocity=8000
# Smoother video streaming
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
# Device will boot faster
ro.config.hw_quickpoweron=true
# Allow dalvik to use JIT (Just in Time) Compiler
dalvik.vm.execution-mode=int:jit
# Video Acceleration Enabled
video.accelerate.hw=1
# Force gpu render on 2d operations
debug.sf.hw=1
# Enable surface dithering which will raise image quality at the cost of performances
persist.sys.use_dithering=1
# Enable HSUPA for better upload speed
ro.ril.hsxpa=3
# Hide adb debugging icon when usb is connected
persist.adb.notify=0
# The device won't wake up if hitting the volume buttons
ro.config.hwfeature_wakeupkey=0
# Prevent your device from sending usage data
ro.config.nocheckin=1
# Hardware buttons's backlight always on when screen is o n
ro.mot.buttonlight.timeout=0
# Use 16b Transparency
ENFORCE_PROCESS_LIMIT=false
MAX_SERVICE_INACTIVITY=false
MIN_HIDDEN_APPS=false
MAX_HIDDEN_APPS=false
CONTENT_APP_IDLE_OFFSET=false
EMPTY_APP_IDLE_OFFSET=false
MAX_ACTIVITIES=false
ACTIVITY_INACTIVE_RESET_TIME=false
MAX_RECENT_TASKS=false
MIN_RECENT_TASKS=false
APP_SWITCH_DELAY_TIME=false
MAX_PROCESSES=false
PROC_START_TIMEOUT=false
CPU_MIN_CHECK_DURATION=false
GC_TIMEOUT=false
SERVICE_TIMEOUT=false
MIN_CRASH_INTERVAL=false
DNS + ppp0 tweaks
net.ppp0.dns1=8.8.8.8
net.ppp0.dns2=8.8.4.4
net.dns1=8.8.8.8
net.dns2=8.8.4.4
voici le build.prop de la rom Orefie et d'autres
la majorité des mod sont des mod génériques si ils fonctionnent c'est ok
mais si ils ne sont pas pris en comptes (je ne sais pas)
c'est du copié\collé
si vous avez des infos pour optimiser ce build.prop je suis preneur
Modifié par orefie
Sur un forum italien j'ai trouvé ça :
j'ai téléchargé "BuildPropEditor" et j'ai ajouté aux chaînes existantes le fameux "ro.ril.fast.dormancy.rule = 0".
J'ai redémarré le téléphone, puis j'ai de nouveau réinitialiser BBS et CPUSPY.Dopo.
Après cela, le téléphone a cessé de se réveiller, chaque fois que je le mets en veille il va profondément dormir,
tout en obtenant des déclarations "whastapp" appels et les SMS../..
J'ai fait la modification et je teste, retour demain soir.
Dany
Modifié par danycmoi
te prends pas la tête utilise notepad++ pour éditer
mais merci pour tes tests
j'ai regardé un autre mt6577 aujourd'hui (un clone du note)
il y a trop d'onglets en chinois et d'autres bugs (nous sommes bien niveau rom LOL)
par contre il y a une calibration du capteur de proximité et du gsensor
a voir
Oréfie
Modifié par orefie
