Nouvelle mise a jour ! (4.1.B.0.431)
bonjour,
j'ai tenté de root suivant la métode indiqué universelle, et la :
--- STARTING ----
--- WAITING FOR DEVICE
--- creating temporary directory
mkdir failed for tmp, File exists
--- cleaning
rm failed for *, No such file or directory
--- symlinking tmp directory
failed on '/data/local/tmp' - Permission denied
link failed File exists
--- Rebooting
--- WAITING FOR DEVICE TO RECONNECT
--- PLEASE WAIT, THIS MAY TAKE A WHILE
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- enabling emulator hack
/system/bin/sh: cannot create /data/local.prop: Permission denied
--- Rebooting
j'essaye de le root mais cela ne fonctionne pas !
CONFIRM ALL THE ABOVE THEN
Appuyez sur une touche pour continuer...
--- STARTING ----
* daemon not running. starting it now *
* daemon started successfully *
--- cleaning
--- Rebooting
--- DEVICE FOUND
--- Rebooting
--- DEVICE FOUND
--- pushing busybox
3145 KB/s (1075144 bytes in 0.333s)
--- correcting permissions
--- remounting /system
mount: permission denied (are you root?)
--- checking free space on /system
61 KB/s (439 bytes in 0.007s)
--- Free space on /system : 63704 bytes
--- no cleanup required
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for writ
--- correcting ownership
Unable to chmod /system/xbin/busybox: No s
--- installing busybox
/system/bin/sh: /system/xbin/busybox: not
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/
Unable to chmod /system/bin/su: No such fi
--- correcting symlinks
rm failed for /system/xbin/su, Read-only f
link failed Read-only file system
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/
file system
--- cleaning
rm failed for /data/local.prop, No such fi
rm failed for /data/local/tmp, Permission
failed on '/data/local/tmp.bak' - No such
--- rebooting
ALL DONE!!!
Salut a tous, j'aimerais passé sous ics (4.1) sur mon ray mais j'ai peur que mes messages/conversations soient supprimés après maj, est-ce que ça va être le cas où ils vont être conservés ? Merci.
Modifié par Ressay
+ un meilleur navigateur internet
+ des réglages plus complets
+ des applications qui fonctionnent uniquement sur ICS
+ des raccourcis (touche power) et un locker mieux foutus
- un gros temps de chargement pour lancer la messagerie, les contacts ou le dialer
- un gros temps de chargement pour relancer la home d'origine ou les launcher (sauf "7 launcher") en quittant des applis ...
Chez certains y'a des bugs mais moi je n'en ai pas a signaler :/. Non le très très gros problème pour moi c'est les temps de chargement ... Qui me fait hésiter tout les jours a retourner en 2.3.
  • 3 weeks later...
  • 4 weeks later...
j'aurais un question
Je débute avec android et mon ray c'est mis a jour en 4.0.4 avec le logiciel, mais je le trouve trop lent, je voudrais repassé en 2.3.4, comment faire sans risque.
Note je viens du canada je ne sais pas si c'est la même version quand Europe
Merci !!!
