Posté(e) (modifié)
Based on XXBLFB
Deodexed
Zipaligned
Ext4 Tweak
SQLlite 3
Battery Tweaks
Busybox
RAM Optimizations
GPU Acceleration
Zipaligns Apk's At Boot
Dalvik To Cache Tweak
Cell Standby Fix
1% Batt Mod
Smooth Spinners
10 Steps Auto Brightness Mod
Lager APN List
Extended Power Menu (Thanks To Walhalla)
Tweaked build.prop
Call Rec Enabled (Thanks To Wanam)
Hide Sms From Call Log (Thanks To Wanam)
Disable Increasing Ringtones
Init.d Scripts
SuperSu 0.93
Black Android Keyboard
Cpu Config Tool (Advanced Settings) (Thanks To Raffaele88)
Start-up Tweaks (Advanced Settings)
CenterClock Mod (Addon Download)
OTA Updater
Fast Dormancy App (Settings Menu)
Modded Youtube 4.0.8E (Black)
Modded WhatsApp (Thanks to rafalense)
Aroma installer. (Custom Installation)
Choose:
*DragonICS Theme*
Framework
SecSettings
Contact style AOSP
Phone style AOSP (Thanks To Raffaele88 For Some Drawables)
Calculator (From my SGS2 AOKP Rom)
Gallery2
Gmail
Black PlayStore
Black Talk
*Aroma*
Install Or Remove Bloatware
Choose Your Apps
*Choose Kernel*
Siyah
Franco Kernel
Ninphetamin
Stock Kernel
*Choose Modem*
XXLFB (Recommended for XXBLFB Firmware)
*Choose Launcher*
Apex
LG Home 3
TouchWiz
DragonICS Rebirth V3.0
ChangeLog:
I9300XXBLFB
Tweaked Default Kernel (Thanks To Wanam)(Aroma)
CenterClock Mod (Aroma)
Modded Browser
Classic Reboot Menu
Auto Flash Modem (XXLFB Recommended)
Removed Lightmanager
Updated All Apps
Added Twitter (Black) (Aroma)
Added Facebook (Aroma)
Some tweaks for more speed
All Previous Tweaks and mods from V2.1.1
And more...
(After installaing rom you have to set manual, choose crt off or on or on/off) also landscape mode)
Installation :
Copier la Rom sur votre Carte SD
Démarrer votre téléphone en mode récovery
Option "wipe data/factory reset" et Validez YES
Option "wipe cache partition" et Validez YES
Menu "advanced"
Wipe Dalvik Cache
Selectionnez "Install Zip from SD Card" et Validez
Sélectionnez "Choose ZIP from SD Card" et Validez
Déplacez vous dans l'arborescence jusqu'à arriver dans l’endroit où vous avez mis la ROM
Validez la ROM
CWM fais l'installation
Rebooter le téléphone
Modifié par beta15
  • 5 weeks later...
ma rom prefere la 3.0 est dispo !
ChangeLog:
I9300XXBLFB
Modded Browser
Classic Reboot Menu
Updated All Apps
And more...
http://www.xdafileserver.nl/index.php?dir=Samsung/Galaxy%20S%20III/Custom%20ROMS/DragonICS%20Rebirth
source : xda ^^
Dommage on perd le lecteur d'origine et donc Pop Up Play...
on ne perds pas le lecteur d origine en tout cas pas en choisissant tw comme launcher
