rooter impossible
sa nemarche pas il me dise no fuggoo voici le rapport
Go for root !
Version: Universal Androot - v1.6.2 beta 5
Detected OS version:7
ls -l /system/etc
drwxr-xr-x root root 2011-02-22 12:42 flex
-rw-r--r-- root root 25 2011-02-22 12:42 hosts
drwxr-xr-x root root 2011-02-22 12:42 wifi
-rw-r--r-- root root 1116 2011-02-22 12:42 gps.conf
drwxr-xr-x root root 2011-02-22 12:42 security
-rw-r--r-- root root 43490 2011-02-22 12:42 apns-conf.xml
-rw-r--r-- root root 473 2011-02-22 12:42 pvplayer.cfg
drwxr-xr-x root root 2011-02-22 12:42 firmware
drwxr-xr-x root root 2011-02-22 12:42 dhcpcd
drwxr-xr-x root root 2011-02-22 12:42 bluez
-rw-r--r-- root root 85 2011-02-22 12:42 01_qcomm_omx.cfg
drwxr-xr-x root root 2011-02-22 12:42 wl
-rw-r--r-- root root 2 2011-02-22 12:42 AutoVolumeControl.txt
-rw-r--r-- root root 97231 2011-02-22 12:42 NOTICE.html.gz
drwxr-xr-x root root 2011-02-22 12:42 omadm
-rw-r--r-- root root 1804 2011-02-22 12:42 loc_parameter.ini
-rw-r--r-- root root 684 2011-02-22 12:42 wiperconfig.xml
drwxr-xr-x root root 2011-02-22 12:42 permissions
-r--r----- bluetooth bluetooth 935 2011-02-22 12:42 dbus.conf
-r-xr-x--- root shell 1200 2011-02-22 12:42 init.goldfish.sh
-rw-r--r-- root root 4217 2011-02-22 12:42 AudioFilter.csv
-rw-r--r-- root root 2046 2011-02-22 12:42 bookmarks.xml
-rw-r--r-- root root 625 2011-02-22 12:42 vold.conf
drwxr-xr-x root root 2011-02-22 12:42 ppp
-rw-r--r-- root root 3469 2011-02-22 12:42 init.qcom.bt.sh
-rw-r--r-- root root 8319 2011-02-22 12:42 event-log-tags
-rw-r--r-- root root 300 2011-02-22 12:42 arcplayer.cfg
ls -l /system/bin/reboot
lrwxr-xr-x root shell 2011-02-22 12:45 reboot -> toolbox
cat /proc/sys/kernel/osrelease
2.6.29
getprop ro.product.model
GT540
getprop ro.product.brand
LGE
getprop ro.product.name
swift
getprop ro.product.manufacturer
LGE
getprop ro.build.product
swift
ls -l /sqlite_stmt_journals
ls -l /data/local/tmp
opendir failed, Permission denied
ls -l /app-cache
/app-cache: No such file or directory
run mount
rootfs / rootfs ro 0 0
tmpfs /dev tmpfs rw,mode=755 0 0
devpts /dev/pts devpts rw,mode=600 0 0
proc /proc proc rw 0 0
sysfs /sys sysfs rw 0 0
/dev/block/mtdblock6 /data yaffs2 rw 0 0
/dev/block/mtdblock1 /cache yaffs2 rw,nosuid,nodev 0 0
tmpfs /sqlite_stmt_journals tmpfs rw,size=4096k 0 0
/dev/block/mtdblock4 /system yaffs2 ro 0 0
/dev/block/mtdblock5 /lgdrm yaffs2 rw,nosuid,nodev 0 0
/dev/block//vold/179:1 /sdcard vfat rw,dirsync,nosuid,nodev,noexec,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
run df
/dev: 86492K total, 12K used, 86480K available (block size 4096)
/data: 142848K total, 127076K used, 15772K available (block size 4096)
/cache: 65536K total, 61544K used, 3992K available (block size 4096)
/sqlite_stmt_journals: 4096K total, 0K used, 4096K available (block size 4096)
/system: 250880K total, 231500K used, 19380K available (block size 4096)
/lgdrm: 2816K total, 1180K used, 1636K available (block size 4096)
/sdcard: 3870400K total, 1373632K used, 2496768K available (block size 65536)
Preparing Exploit ... :true
Preparing busybox binary ... :true
User selected: Eclair
Preparing Su binary ... :true
Preparing Superuser apk ... :true, resid:2131034118
Preparing root toolkit script ... :true
Trying to get mount point:/data
Trying to get mount point:/system
mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
mkdir /system/xbin
cat su > /system/xbin/su
chmod 04755 /system/xbin/su
ln -s /system/xbin/su /system/bin/su
mount -o remount,ro -t yaffs2 /dev/block/mtdblock4 /system
mount -o remount,rw -t yaffs2 /dev/block/mtdblock6 /data
rm /system/bin/su
rm /system/xbin/su
Preparing to execute exploit, do chmod
Executing exploit..
cmd: /data/data/com.corner23.android.universalandroot/files/getroot /dev/block/mtdblock6 yaffs2
[*] Android local root exploid © The Android Exploid Crew
[*] Modified by shakalaca for various devices
[+] Using basedir=/sqlite_stmt_journals, path=/data/data/com.corner23.android.universalandroot/files/getroot
[+] opening NETLINK_KOBJECT_UEVENT socket
[+] sending add message ...
[*] Try to invoke hotplug now, clicking at the wireless
[*] settings, plugin USB key etc.
[*] You succeeded if you find /system/bin/rootshell.
[*] GUI might hang/restart meanwhile so be patient.
Wifi disabled ...
/sqlite_stmt_journals/rootshell missing ..
/app-cache/rootshell missing ..
/data/local/tmp/rootshell missing ..
Install/Uninstall rootkit: false
lrwxrwxrwx app_77 app_77 2012-06-27 22:06 data -> /proc/sys/kernel/hotplug
-rw-r--r-- app_77 app_77 6 2012-06-27 22:06 fs_type
-rw-r--r-- app_77 app_77 20 2012-06-27 22:06 mount
-rw-r--r-- app_77 app_77 62 2012-06-27 22:06 hotplug
-rw-rw-rw- app_77 app_77 0 2012-06-27 22:06 loading
ls -l /app-cache
run mount
run df
/data: 142848K total, 128448K used, 14400K available (block size 4096)
/sqlite_stmt_journals: 4096K total, 12K used, 4084K available (block size 4096)
Trying to get mount point:/system/bin
Go for root !
ls -l /system/etc
2.6.29
GT540
LGE
swift
LGE
swift
ls -l /app-cache
run mount
run df
/data: 142848K total, 128456K used, 14392K available (block size 4096)
mkdir /system/xbin
rm /system/bin/su
rm /system/xbin/su
Executing exploit..
Wifi enabled ...
lrwxrwxrwx app_77 app_77 2012-06-27 22:07 data -> /proc/sys/kernel/hotplug
-rw-r--r-- app_77 app_77 6 2012-06-27 22:07 fs_type
-rw-r--r-- app_77 app_77 20 2012-06-27 22:07 mount
-rw-r--r-- app_77 app_77 62 2012-06-27 22:07 hotplug
-rw-rw-rw- app_77 app_77 0 2012-06-27 22:07 loading
ls -l /app-cache
run mount
run df
