[ROM] BAMF Paradigm v2.3.1 [4.1.1] JRO03L 31/08/2012 *FIXES AND MORE*
Team BAMF Proudly Presents...
Paradigm represents the culmination of months of work to bring our users the best possible AOSP experience.
Using all of our previous experience with a multitude of devices and user interfaces, we aim to bring you something you just can't get anywhere else.
Are you ready for the shift?
What to Expect:
  • Android 4.1.1 internals
  • Quick, lag-free performance
  • Rock-solid stability
  • Many original features
  • Bug-free (we hope) android experience
  • Outstanding developer support
What you won't find:
  • Useless tweaks, mods, and bloat
  • Over the top themeing
  • A coffee maker
Features:
Under the Hood:
  • AOSP 4.1.1 base
  • Updated to latest AOSP bug fixes
  • 4.1.1 Proprietary blobs
  • Kernel Overclocked to 1.35ghz with stock voltages
  • Tweaked deadline I/O scheduler
  • Custom busybox built for Team BAMF
  • Superuser and su binary built from source and updateable from Market (thanks ChainsDD)
  • Signed with private developer keys for increased security
Add-ons:
  • All stock sound files
  • Sped up notification LED
  • Spare Parts enabled and added to build
  • Additional live wallpapers not included in AOSP
  • Enabled extra browser settings
  • Increased rotation and animation speed and opened up 360 degree rotation
  • Accurate battery
  • Custom clock widget from ICS pre-release
  • Added long press of Recent apps to activate menu key
  • Configurable Search soft key with option to enable/disable
  • Separate ringer and notification volumes
  • T9 dialer courtesy of CyanogenMod with optional settings in dialer
  • Custom launcher with search bar removed, 4x5 grid layout, and custom app drawer button
BAMF Add-ons:
  • Custom boot animation with audio (thanks to gadget! for the logo)
  • BAMF LTE Widget
  • BAMF Torch Widget
  • Configurable Lockscreen with three hotseats, selectable left target, and pull down for Torch - Back Soon
  • Completely configurable QuickSettings replacing normal settings in Status Bar
  • BAMF Settings (huge thanks to Stericson for the RootTools SDK which we incorporated for root functionality)
BAMF Settings Features:
  • Performance Settings (Based on CyanogenMod CPU Settings)
    • CPU Speeds
    • Governor
    • I/O Scheduler
    • Voltages (where supported)
    [*]System Settings
    • Ad Blocking
    • Remounting of System Partition
    • Granular Autobrightness adjustment
    • Full management of system apps (disable/enable/uninstall)
    [*]Visual Settings
    • Lockscreen setup - Back Soon
    • Fully configurable boot animation (enable/disable, enable/disable sound, adjust audio volume)
    • Launcher Tweaks
      • Show or hide the dock divider
      • Show or hide search bar
      • Set number of home screens (3,5, or 7)
  • Status Bar Tweaks
    • Show or Hide Clock
    • Show or Hide Alarm notification
    • Show or Hide Debugging Indicator
    • Battery Skin System (Some sample skins are available in the 2nd post and a tutorial for making your own is available in the "Themes" section) (1.2)
    • Fully customizable battery text including size, color, and visibility (1.2)
    • Normal, Centered, or Hidden Status Bar Clock (1.2)
    • Customizable carrier banner (1.1)
    • Select and arrange Quick Settings (17 currently available)
    [*]Navbar Tweaks
    • Show or hide the Search soft key
    • Customize long-press functionality of Search Key
    • Soft key reflections on/off (1.1)
    • Set Soft Key color
    • Set Soft Key glow color
Thank Yous:
  • Thanks again to Gadget! for the graphics
  • CyanogenMod for paving the way
  • ChainsDD for his work with superuser
  • Stericson for giving us lazy developers RootTools
  • wowthatisrandom for the initial battery skins
  • All of our Beta Testers (even though you made us crazy wink.gif)
  • Most importantly, our users, who waited patiently while we beat our heads against the wall working on this!
Installation instructions
Wipe data
Flash BAMF Rom
Flash BAMF Gapps
Reboot
Version 1.0
Initial Release
Version 1.1
First release of Maguro version
Changing softkey background alpha to 0 disables all animations
Soft key reflections toggle
Fixed hotspot quick setting (which should stop random reboots for some)
Fixed launching direct contacts from the lock screen
Please note: Volumes do not appear split under settings temporarily. They are still split for quick settings
Version 1.2
Updated ROM and Kernel to 4.0.4
Normal, Centered, Hidden Clock options
Battery Skin System (Sample skins are in the 2nd post and a tutorial for making your own is available in the "Themes" section)
Full Battery text customization
Persistent search bar option for launcher
Huge changes under the hood in preparation for future mods
Version 1.25
Maintenance Release
Performance Enhancements
Bug Fixes
Version 1.3
Bug Fixes
Addition of Sprint Galaxy Nexus
New Notification Management System
Theme Chooser from CM9 with a custom theme
Much more (changelog to be updated later)
Version 2.0
Everything from before, but with Beans included.
Version 2.1
Fix for BAMFSettings not restoring Kernel Settings
GPS Lock Fix
Fixed launcher FC loop
Fixed SIM unlock reboot
Added LongPress track skip
Increased Speaker volume
Added option to link ringer and notification volumes
Paradigm theme is back - Although not complete
Updated GAPPS
Version 2.2
Based on JRO0L3
Lockscreen is back!
Many bug fixes!
DRM and Hulu are fixed =D
Some more I can't remember...
Version 2.3
Custom Navigation Bar!
Updated AdBlocking
Added ability to open alarm clock view Statusbar clock courtesy of 1RoLa
Many small changes and bug fixes
Version 2.3.1
Maintenance Release
Fixed MMS for Toroplus users (Huge thank you to maddoggin and dreamsforgotten for the assistance)
Theme Chooser now correctly applies wallpaper 94% of the time.
Modifications to ThemeEngine framework to allow themeing of Gapps that replace AOSP versions.
Updated Gapps to fix some missing theme elements.
Modifié par skroprod
