.:{LeZigue}:. Posté(e) 8 août 2012 Share Posté(e) 8 août 2012 salut j'utilise cette rom et comme personne n'en parle je me jette a l'eau le lien sur xda : [ROM][JB][4.1.1] MiNCO (Minooch + Franco) comme son nom l'indique supporté par minooch et francisco franco (développeur franco kernel) lien pour la rom en version 4 :http://minco.de.firelab.net/MiNCO_v4.php Installation: Quote: 1) Boot to Recovery 2) Make a Nandroid 3) Wipe 4) Flash ROM 5) Reboot 6) Profit Updating: Quote: 1) Boot to Recovery 2) Make a Nandroid 3) Wipe Cache 4) Flash new version 5) Reboot 6) Profit le descriptif avec le changelog : 1% Battery Capable Rotation Lock under Notification Bar Super Power Menu Some minor theming SuperSU as default Franco Kernel - 384 GPU Possibly more - I can't remember Version 4 Added Gapps in a slightly different way - Face-unlock & Picasa are fixed Updated to Android 4.1.1_r4 Using Franco Kernel Milestone 5 Under Settings>Sounds there is a separate notification volume Fixed Nav Bar Sizing asked by ro_explorer Increased SMS limit from 30 every 30 minutes to 3000 Custom Tuna PowerHAL Bionic patches from codeaurora - performance boost New boot animation & wallpapers Changed audio sampling rate to 48khz Volume boost for rear speaker, phone speaker, headset & mic Version 3 Fixed video camera effects - Thanks mike1986 Removed duplicate ringtones Increased WiFi scan interval to 90 seconds New Wallpapers - Thanks vomer Integrated Gapps Added Clockworkmod Backups under Settings>Storage Upgraded the Proprietary Binaries to properly support Android 4.1.1_r3 Version 2 Franco Kernel r230 Reverted navbar & battery icons ROM is 1% battery capable - just add the correct PNGs Updated to Android 4.1.1_r3 Disabled "Bug Mailer" Removed Japanese & Chinese keyboards New Bootlogo (Thanks vomer) New MiNCO Wallpaper (Thanks vomer) You need to flash Gapps after flashing v2 as the system partition gets formatted Version 1 Initial release améliorations du theme et divers : MiNCO Plus+ MODs & Enhancements par vomer capture d'écran : voili voila je la trouve stable, rapide et econome en energie. je régle le kernel avec franco.Kernel updater mais c'est payant ,un prog gratos Trickster MOD . bye Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 8 août 2012 Share Posté(e) 8 août 2012 Pour contrôler le kernel gratuitement prendre trickster mod sur xda. Édit: lien frandroid [-Une-app+rom-multikernel-]#entry1805412 RasBeanJelly powered by TRINITY Lien vers le commentaire Partager sur d’autres sites More sharing options...
.:{LeZigue}:. Posté(e) 8 août 2012 Auteur Share Posté(e) 8 août 2012 merci je l'intégre de suite au post c'est vrai qu'avant de tomber sur l'appli de franco j'utilisai un script sous un terminal mais comme l'appli est sympa a utiliser j'ai pas pu m'empécher de la citer au moins ça vas laisser une alternative aux gens Lien vers le commentaire Partager sur d’autres sites More sharing options...
