sebennett Posté(e) 10 septembre 2012 Share Posté(e) 10 septembre 2012 (modifié) Description ROM JB basée sur les sources google, CM et AOKP avec toutes les customisations possibles et imaginables ! ——— * Based off of Clean Android 4.1.1 Rev6 (JRO03R) * File Manager Included * T-mobile Theme Manager (tmobile, CyanogenMod, xoomdev) * T9 Dialer/Landscape/Dialpad Settings (CyanogenMod) * Trebuchet Custom Launcher (CyanogenMod) * Ability to set custom ringtone delay (in phone settings - Netboy) * Framework: added support for caller name display (kenshin) * Framework: added HSPA+ support (shows H+ icon on status bar when connected to hspa+ - Bajee11) * Framework: ability to set custom carrier label (Netboy) * Browser: option open tab in incognito mode (Arham Jamal) * Browser: option to close all other tabs (Arham Jamal) * Browser: unhid the user agent settings * DeskClock: added stopwatch and countdown timer (Jorge Ruesga) * DeskClock: added settings to do nothing/snooze/dismiss and alarm by flipping the device (maurodec) * DeskClock: you can set an alarm to switch your profile (jorge ruesga) * Email: added meeting time to email invitation tab (erezak) * Email: added option to enable/disable LED notifications per email account (apohl79) * Keyboard: ability to use the volume buttons to move the cursor (romanbb) * Settings: ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks) * Settings: Added option to disable volume adjustment sound (Settings -> Sound - StevenHarper) * Settings: Option to change the devices hostname * Settings: Hardware info in about phone (romanbb) * Settings: Added nfc poling (sethyx) * Custom Camera App: (CyanogenMod) - Continuos focus - Iso Support - Support for red eye reduction - Ability to use the power button to take pictures * Customizable Messaging App: - Added the ability to display a pop-up QuickMessage when an Sms message is received (DvTonder) - Added call sender and quick reply notification actions (DvTonder) - Added Emoji patch from CM MMS app (Robert Burns) - SMS Templates (rciovati) - Custom Vibrations (mssmison) - Timestamp Options (aravance) * Customizable Phone App (CM) - Advanced Phone settings (optional vib on outgoing or incoming call or every 45 seconds) * Customizable Power Menu (codenamedroid) - Reboot Menu - Profile Switcher - Screenshot - Airplane Mode - Navigation bar toggle - Silent toggle * Customizable Status Bar: (Miui, CyanogenMod, romanbb, sethyx, kejar, syaoran12 ,romanbb, Stevespear426, Kyle Teague, Whitehawkx) - Battery Icon style - Battery Icon in notification bar - Miui style battery bar - Clock style - Customizable Clock Color - Clock Am/Pm style - Clock Day of the Week - Customizable Signal Text - Customizable WiFi Signal Text - Ability to slide your finger across the status bar to control brightness - Notification counter * Customizable Notification bar: - Notification bar Power Widget (Cvcps, DvTonder – CyanogenMod) - Notification bar Toogles (AOKP - romanbb) * Customizable Navigation Bar: (Zaphod-Beeblebrox, KhasMek, romanbb, akellar) - Ability to enable/disable the navigation bar (enable toggle in power menu settings) - Customizable navigation button actions - Custom navigation bar ring targets (Team Eos, modified by Codenamedroid) - customizable navigation bar color (Team Eos, modified by Codenamedroid) - Customizable navigation button and button glow color - Menu button visibility and location - Number of navigation buttons - Order of navigation buttons - Navigation bar size - Navigation bar transparency * Customizable Lockscreen: - Up to eight configurable lockscreen targets (Codenamedroid) - Added optional centered lockscreen layout (Codenamedroid) - Optional centered lockscreen clock - Option to disable vibration on the lockscreen (StevenHarper) - Customizable number of lockscreen targets (CyanogenMod) - Configurable lockscreen wallpaper (Danesh M) - Option to always show lockscreen battery (Blunden) - Add weather to the lockscreen (DvTonder, Danesh M, Marius Volkhart, Rick C, Aokp) - Add calendar reminders to the lockscreen (David Morgan) - Lockscreen before secure unlock (Danesh M) - Ability to unlock with menu (CyanogenMod) - Quick pin unlock (unlock with pin/password without pressing ok – CyanogenMod) * Customizable Sound Settings: - Customizable volume panel (Stevespear426) - Configurable ascending ringtone (Danny Baumann) - Safe headset volume (CyanogenMod) - Volume rocker music controls (CyanogenMod) - Ability to customize action taken when connecting a headset (syaoran12) - Face down actions (syaoran12) * Customizable Display Settings: (CyanogenMod) - Customizable Rotation Modes - Customizable LED Pulse (Duration and Color) - Volume wake (tap either the up or down volume key to wake your phone from sleep) - Volume music controls (long press volume buttons to skip tracks) * Custom Profiles (CyanogenMod) - assign different profiles to change the behavior of your phone to your liking * Quiet Hours (CyanogenMod) - the ability to set when notification sounds, haptic feedback, vibration and notification light will function[/color] * Performance Settings: - Start-up tweaks (kejar, Jrummy) - Processor Speed (xoomdev) - Voltage controls (xoomdev) - Kernel controls (kejar, Jrummy) * Developer Options: - Propmodder (Jdkoreclipse) - Spare Parts - Development app - Testing Settings EXTRA TOOLS ——— * SuperSU * Busybox * Bash * Nano[/color] SCREENSHOTS ——— ROM Download Link : http://goo.im/devs/c...xyS3-INTL-i9300 Gapps Download Link: http://goo.im/devs/c...roid/googleapps Donation Link: https://www.paypal.c...d=MQTR739QNS3CY (Full Wipe -Data & Cache Needed) CM10 Thème Engine http://forum.xda-dev...d.php?t=1801752 https://play.google....10 theme&c=apps ---- Codename Android 3.6.5 – 3.6.6 Changelog ——— [additions] * enables custom navigation bar keys and ring on 10inch tablets (Stevespear426) * added the option to change the soft keyboard type when composing messages (GzFighter): Gives the user the option to change the keyboard from Emoji to enter or a new line or enter to send. The setting has no effect on the hardware keyboard. * increased the default number of sms messages sent in checking period (TeamBAMF) * added screenshot option to navbar settings (Stevespear426) [general] * updated navbar color picker (Patrick L) [fixes] * fixed audio wakelock on galaxy s3 * fixed reverting to 700mhz on screen on galaxy nexus * fixed QuickMessage popup force closing when receiveing Mms and QuickMessage themeing support * fixed switching custom navbar icons without resetting the navbar Source : http://forum.xda-dev...d.php?t=1900448 http://codenameandroid.com/ TWEAKS : ZRAM (RAM virtuelle) Paramètres / Performances / Kernel controls / Utiliser Zram / 18% TRANSITIONS / ANIMATIONS Paramètres / Options pour les développeurs (à activier)/ Echelle animation fénêtres, transitions, animations => MODIFIER LA VALEUR DE 1X à 0.5x ACCELERATION MATERIELLE Paramètres / Options pour les développeurs (à activier) / Forcer le rendu GPU RAPPEL FLASH DES GAPPS A CHAQUE MAJ ! WIPE CACHE et DALWIK entre chaque MAJ WIPE DATA pour 1ere installation BUGS : Radio FM / HDMI out / WIFI et bluetouth tethering RAPPEL : PAS D'APPLICATIONS / FONCTIONS Samsung SUR AOSP Modifié 24 octobre 2012 par sebennett Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tovisiegfried Posté(e) 10 septembre 2012 Share Posté(e) 10 septembre 2012 Bonjour et merci pour les liens ! Des retours d'utilisateurs ? 2 questions essentielles : - quid de l'autonomie par rapport à la ROM JB leaked ? - des bugs répertoriés ? :-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 10 septembre 2012 Auteur Share Posté(e) 10 septembre 2012 (modifié) EDIT : Modification du Topic => Codename Android :) :) Wipe data / cache et dalwik pour une première installation Wipe cache / dalwik venant d'une AOSP récente (wipe data si FC) Modifié 22 octobre 2012 par sebennett Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 2 octobre 2012 Auteur Share Posté(e) 2 octobre 2012 Pour finir : Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Je tourne avec cette rom depuis 3 mois avec mon nexus et maintenant 3 jours avec le S3. Jamais eu de bug ni autre. Autonomie en usage basique de 3 jours avec le nexus+batterie de 2000mAh. Pour le s3 l'autonomie est du même ordre. Sur nexus c'est la rom la plus customisable en Jb que j'ai essayé. A essayer ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 2 octobre 2012 Auteur Share Posté(e) 2 octobre 2012 Pour l'autonomie je pourrais pas encore donner mon avis mais aussi fluide que CM et tellement d'option de customisation que j'ai pas encore fait tout le tour..... :P Définitivement à essayer ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
re4 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Pour le wifi venant de la DLIb stock kernel Siyah repassage comme les cm10 en ICS pour avoir le wifi ou directement je peut passer dessus ? Je suppose avec un full wipe ? Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Salut Y'a til possibilité d'enlever la barre en bas? (retour, home et paramètre) et plutot utiliser les boutons? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Les screenshoot viennent du nexus, il n'y a pas de softkey pour la rom du S3 ! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Julien Délandes Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Une question peut être débile mais pourquoi les gapps ne sont pas les mêmes que pour la CM ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
re4 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Les screenshoot viennent du nexus, il n'y a pas de softkey pour la rom du S3 ! C'est tu se que je doit faire pour installer la roms merci bien. Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Ba full wipe (c'est conseillé), flash de la rom et flash des gapps aussitôt. Tu redémarres 2 fois ton S3 et c'est bon ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 (modifié) Pas de softkey veut dire pas de boutons virtuelles? (désolé j'ai déjà mits des roms de ce genre mais il y avait toujours les touches en bas ^^) Faut'il prendre la 3.6.2? ou la 3.6.5? et est ce bien le dossier "GalaxyS3-INTL-i9300" Je ne veux pas me tromper ^^ Modifié 2 octobre 2012 par Quent01120 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Oui il faut bien prendre celle de ton lien en 3.6.5 (c'est la derniére release). Les softkeys sont bien les boutons virtuels du nexus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 2 octobre 2012 Auteur Share Posté(e) 2 octobre 2012 (modifié) J'ai mis à jour le topic pour le lien de téléchargement de la ROM (vers la version internationale) @anilis; le développeur à apparemment modifié les gapps pour que la synchronisation avec Picassa soit fonctionnelle ! Pour l'installation / wipe c'est indiqué dans le 2ime post du topic :P Edit : Pour les sofkey ont peux les activer/désactiver dans les menus ! Modifié 3 octobre 2012 par sebennett Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 La rom stock est en wifi puis je la flasher par CWM? ou je doit passer par ODIN? (désolé de poser autant de question mais mon S3 est neuf j'y vais donc doucement ^^ ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Je ne comprends pas ta question "La rom stock est en wifi" Pour flasher tu dois passer par CWM Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 2 octobre 2012 Auteur Share Posté(e) 2 octobre 2012 J'ai mis le lien d'une ics (LH1) en première page à flasher avec odin Pour les novices flashez pas n'importe quoi alors posez vos questions dans la section dédiée :) Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 désolé mea culpa je voulais dire en .zip xD je me demandais dou venez le probleme de wifi Donc non on ne peut le flasher par CWM il faut bien le flasher avec Odin j'ai ma réponse merci ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 OK OK j'ai bien tester la rom au niveau personnalisation ^^ peut on éteindre les voyant des touche sensitives (retour et paramètre)??? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
psykup007 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 Oui, dans paramétres-->options spécifiques---> onglet screen--> en bas décocher backlight 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
orochimaru94 Posté(e) 2 octobre 2012 Share Posté(e) 2 octobre 2012 avec la rom sous ICS à flasher avec Odin, il faut donc ensuite rerooter son phone pour avoir CWM ou pas? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 2 octobre 2012 Auteur Share Posté(e) 2 octobre 2012 Oui avec cf root (ou renommer la ROM en update.zip...mais je suis pas sur...) ! Je rajoute demain :-) Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 3 octobre 2012 Share Posté(e) 3 octobre 2012 Bon je n'ais pas réussi à mettre la rom sans avoir des problèmes de wifi je ne comprend pas... j'ai pourtant bien suivit le tutoriel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 3 octobre 2012 Auteur Share Posté(e) 3 octobre 2012 Topic mis à jour pour le lien vers cf root ! @Quent01120 : C'est quoi tes problèmes de wifi ? soit il marche soit il marche pas.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
