androboy06 Posté(e) 27 octobre 2012 Share Posté(e) 27 octobre 2012 (modifié) Bonsoir, je vous présente une version d'Android 4.1.2 et plus récemment 4.2.1 pure AOSP pour nos HTC Sensation / XE [4.1.2] 100% d'origine aucun ajout [4.1.2] Très stable / fluide Changelog [bUILD1]: - Android Jelly Bean 4.1.2 (JZO54K - Android-4.1.2_r1) - JB Kernel - 3.0.36 - No visual changes - No 3rd party apps [bUILD2] - Init.d support - Updated kernel - Improved scrolling cache - Video playback fixed (local/stream) - Enabled Live Wallpapers [bUILD3] - Updated kernel (wifi modules&video drivers) - Improved and optimized (Dalvik,Webkit,SQlite,framework etc) - Implemented WebGL Support - init.d support - fixed - Video files with full HW acceleration - More speed and battery and - Video camera 1080p - ready! [bUILD4] - missed call notification led fixed - FM radio - ggaps included in build process (no need to flash gaps) - enchanced sensitivity for wifi [bUILD5] - kernel patch to linux 3.0.50 - unsecured boot (adb commands now works) - updated gapps - reverted camera patch- when in gallery view,ignore any keyevents.. [bUILD6] Hi all! In the past 2 months I have received a lot of requests to refresh up a bit this rom. I have not found time for personal commitments. Last week I received two requests, but also the first donations for the "refreshment" rom. That's exactly why I decided to give back and compiled fresh edition 16.01.2013. A lot of things has improved since the last change framework, dalvik, webkit, browser, skia, new kernel... [bUILD7] - built with a custom linaro based gcc 4.7.3 toolchain - kernel patch to linux 3.0.55 - fixed gps - gapps are not included in the build 7 [bUILD8] -Kernel 3.0.60 -googlesource fixes -added AOSP 4.2 stuff Installation Full wipe Flash de la ROM Flash du GAPPS Reboot Téléchargement BUILD 1 MD5 : F25F42FFD137483B0978B62794A9C6DA BUILD 2 MD5 : 68592D022330E22F69367CD488A48E67 BUILD 3 MD5 : 4716859E6B910176B5731C1F3B5BC7A3 BUILD 4 MD5 : 39CAFCBE89769B8786C2B533B2750BF6 BUILD 5 MD5 : DFB235B78B2C5E4E1BE546D4E20A904C BUILD 6 MD5 : 1AB1AF76B472F29EE0AB6184307D8B70 BUILD 7 MD5 : 4565E7BA5C9E903C603FA19DE1308817 Désormais tout est téléchargeable ici : www.superxe-rom.tk Lien XDA Modifié 30 janvier 2013 par androboy06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mike08 Posté(e) 28 octobre 2012 Share Posté(e) 28 octobre 2012 elle me tente bien moi cette rom , personne n a essayé ici ? sur xda les retours on l air plutot bien positif Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 28 octobre 2012 Auteur Share Posté(e) 28 octobre 2012 (modifié) Au pire tu fait un nandroid backup et tu test edit: Mise à jour du premier post ! Modifié 31 octobre 2012 par androboy06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 31 octobre 2012 Share Posté(e) 31 octobre 2012 Salut, La rom est elle en Fr, et quel version du firmware faut il ?. Merci @+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 31 octobre 2012 Auteur Share Posté(e) 31 octobre 2012 Oui, toutes les langues de "base" de JB et pour le firmware c'est le 3.32 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 1 novembre 2012 Share Posté(e) 1 novembre 2012 Salut, Merci pour la réponse, par contre avec un FW 3.33 cette ROM fonctionne ou pas, je ne souhaite pas changer de FW. @+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 1 novembre 2012 Auteur Share Posté(e) 1 novembre 2012 Au fait le firmware 3.33 fonctionne aussi Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 (modifié) Salut, J'ai flasher cette ROM (build 3) et les gapps, mais quand je reboot, le sensation reste bloqué sur le logo HTC, faut il être S-OFF, car je suis Unlocked, root, et je flashe avec EXt4 recovery. Merci @+ Modifié 2 novembre 2012 par hcl_28 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
wn.h Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 (modifié) Est ce que quelqu'un l'a essayé/comparé à la CM10 ? Modifié 2 novembre 2012 par wn.h Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barthandelus Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 @ HCL pour toutes les roms oui il faut etre S-Off mais tu peux flasher en activant le smartflash du 4ext. avant de flasher ta rom une fois les wipe fait va dans tools=> enable 4ext smartflash Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 (modifié) Salut, Pour le moment j'ai toujours réussi à flaher des ROM sur mon sensation sans être S-OFF, juste Unlocked et cela se passé sans soucis, je vais voir pour le smartflash, Mais je ne souhaite pas passer en S-OFF pour le moment avec la méthode du "trombone". Je viens de refaire un flash en activant le smartflash, mais cela ne semble pas être suffisant, je reste toujours bloqué sur le logo HTC , j'ai retiré la batterie au bout de 5 min. @+ Modifié 2 novembre 2012 par hcl_28 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barthandelus Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 D’après certains retours XDA le smartflash ne marche pas pour cette rom, par contre pas de soucis sur celle de Kang CM10 (je l'essaye en ce moment). Si tu veux tenter essaye cette méthode http://forum.xda-developers.com/showthread.php?p=31082578. Il te faut flasher le fichier boot.img de la rom par une ligne de commande (shift-clic droit dans le dossier que tu as crée pour débloquer le bootloader avec htc dev celui avec les fichiers adb et fastboot), le tuto détaille les commandes à rentrer. Je suis dans le même cas que toi mon tel est débloqué mais toujours S-on le coup du trombone c'est assez hardcore je trouve :emo_im_undecided: , jusqu’à présent j'ai toujours flashé mes roms avec le smartflash aucun problème sauf sur cette rom Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 (modifié) J'ai essayé cette ROM, qui ressemble fortement à celle que tu présentes et la pas de soucis , tout fonctionne. http://forum.xda-dev...d.php?t=1828250 @+ Modifié 2 novembre 2012 par hcl_28 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 2 novembre 2012 Auteur Share Posté(e) 2 novembre 2012 Le build 4 est sortie Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 Je vais la tester ce soir, la je lance le téléchargement de la Build 4, et d'apres ce que j'ai lu sur xda, pas la peine d'installer les Gapps sur cette version, c'est ça ? En espérant me débarrer de mes problèmes de reboot (sans aucune raison) avec cette rom. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 5 novembre 2012 Auteur Share Posté(e) 5 novembre 2012 Exacte Envoyé depuis mon Sensation avec Tapatalk 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 Sur 4ext, pour le full wipe, j'ai selectionne "wipe data/factory reset" ? avec la venom, ça full wipe tout seul, là je sais pas si ça va toucher la sd card, les photos et toussa. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 5 novembre 2012 Auteur Share Posté(e) 5 novembre 2012 Tu fait wipe data, cache et dalvik cache surtout ne fait pas de wipe SD card Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 en faite, j'ai fais le "Wipe data/factory reset" mais j'ai enlevé la carte mémoire, là la rom marche a merveille ! mais je sais pas si je risque de rencontrer quelque problemes dans les heures/jours a suivre ... a ton avis, je reflashe ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 5 novembre 2012 Auteur Share Posté(e) 5 novembre 2012 Tu aurais du faire un wipe cache et dalvik sinon ensuite la sd tu la remis dans le tel ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 (modifié) Ouep pour flasher la rom ^^ elle est super fluide cette rom ! il manque des tweaks et ça sera le summum un peu ^^ Modifié 5 novembre 2012 par The W Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
androboy06 Posté(e) 5 novembre 2012 Auteur Share Posté(e) 5 novembre 2012 (modifié) Pour les tweaks je te conseillerais ces trois ROMS http://forum.xda-dev...d.php?t=1828250 http://forum.xda-dev...d.php?t=1782009 http://forum.xda-dev...d.php?t=1879111 Modifié 5 novembre 2012 par androboy06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 Oui mais c'est bon, je suis tomber amoureux de cette rom ^^ je vais rester avec pendant quelques jours, si y a plus le coup de le phone s’éteint directement sans rien me dire, le reve pour moi ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hc_l28 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 (modifié) Salut, Dans Ext4 recovery , dans la section wipe, il y a un choix qui propose de tous formater sauf la SD card, je fais cette manip a chaque changement de ROM et cela fonctionne sans soucis, cela ne touche pas au contenu de la SD. @+ Modifié 5 novembre 2012 par hcl_28 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouloudia007 Posté(e) 6 novembre 2012 Share Posté(e) 6 novembre 2012 (modifié) et le choix c'est ? Sinon pour la rom, j'aime bien, c'est propre, mais la je défile ma liste de contact, j'ai l'impression que sa freine. la batterie ne tiens pas vraiment, et mon Sensation s'est éteint 4/5 fois pendant la journée :( ... je crois que je vais tester la AOKP "Initiate Your Swagger" ça a l'air d'etre une bonne rom. Modifié 6 novembre 2012 par The W Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
