Coolos Posté(e) 24 novembre 2012 Share Posté(e) 24 novembre 2012 (modifié) Source : http://forum.xda-dev...d.php?t=2010903 WORKING/CHANGELOG: [v0.0.0] Boots, of course [v0.0.0] General Android 4.2 system [v0.0.0] Basic 2D/3D elements [v0.0.0] External SD Card (automounting works, too) [v0.0.0] Reboot menu (recovery) [v0.0.0] Screenshot option [v0.0.0] Dock Lid System [v0.0.0] WiFi [v0.1.0] Themes [v0.1.0] Audio [v0.1.1] Make the system (and apps, such as Gallery+Apollo) recognize the internal and external sdcard! [v0.1.1] Quick Settings (Pull down from the top right hand corner) [v0.2.0] OMX [v0.2.0] Main Camera [v0.2.0] Rotation [v0.5.0] Fixup battery drain [v0.5.0] Multi-User Support (Up to 8 users) [v0.5.0] KERNEL: BCMDHD: Add Wake-On-Wireless [v0.5.0] KERNEL: BCMDHD: Add Hardware-Out-Of-Band-Interrupt [v0.5.0] KERNEL: LINARO: Compiled with LINARO-GCC-4.7 Toochain enhancements [v0.5.0] KERNEL: LINARO: Use all available optimizations, but keep the non-strict aliasing [v0.5.0] KERNEL: MODULES: Upgrade modules with LINARO optimizations enabled [v0.5.0] KERNEL: Bring in a new kernel with new governors and a (hopefully) better and stronger WiFi [v0.5.0] Bump version number to 0.5.0 to represent the progress being made [v0.5.0] Android 4.2.1 [v0.5.0] Trebuchet Launcher [v0.5.0] Camera seems to be broken again.. thank you CM [v0.6.0] Internal Microphone (thanks timduru!) [v0.6.0] Camera (back, 5MP) [v0.6.0] Bluetooth [v0.6.0] Proper GFX acceleration (Games working atleast as smooth as on stock) [v0.7.0] Tegra 2 EGL Framebuffer [v0.7.0] Enable Expanded Desktop Feature [v0.7.0] Enable Mouse Pointer Touchpad Mode instead of Circle Gesture Mode [v0.7.0] Upgrade wifimacwriter (built from source) [v0.7.0] Front facing camera (Mi1040 Sensor) [v0.8.0] Wifimacwriter: return to prebuilt version for now.. NOT WORKING: HDMI (?) - User-reported. Comes time, comes testing, come fixes. GPS (?) - I don't use it on my tablet, but I will try to confirm and fix if I get some time. Lien ROM v0.8.0 : http://goo.im/devs/R...F101/v0.8.0.zip Lien Gapps for 4.2 : http://goo.im/devs/R...jb-20121119.zip Procédure d'installation : Le Recovery est obligatoire, si ce n'est pas deja fait : http://forum.xda-developers.com/showthread.php?t=1688012 1) Copier à la racine de la SD interne le fichier zip de la ROM ainsi que le fichier zip des Google app pour android 4.2 2) Reboot en recovery 3) Faire tous les Wipe 4) Install du zip de la ROM 5) Reboot 6) Retour en recovery 7) Install du zip des Google Apps 8) Reboot Modifié 26 décembre 2012 par Coolos Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 24 novembre 2012 Share Posté(e) 24 novembre 2012 Ça va être une ROM de l'espace :) je file l'essayer des que la wifi est opérationnel ! Envoyé depuis mon XT925 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 24 novembre 2012 Auteur Share Posté(e) 24 novembre 2012 (modifié) Le Wifi est opérationnel (il est dans la liste des working !). Pour l'instant ce qui ne fonctionne pas c'est : - Le bluetooth - L'audio - Les caméras Modifié 24 novembre 2012 par Coolos Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adien Posté(e) 25 novembre 2012 Share Posté(e) 25 novembre 2012 (modifié) Genial! Aucune info sur le dock (azerty, extinction à la fermeture, ...) ? Modifié 25 novembre 2012 par Adien Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 27 novembre 2012 Auteur Share Posté(e) 27 novembre 2012 Ça avance vite, la 0.1.0 puis la 0.1.1 viennent de sortir. L'audio fonctionne à présent. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 27 novembre 2012 Share Posté(e) 27 novembre 2012 Excellent, tu l'a testé ? Envoyé depuis mon XT925 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 27 novembre 2012 Auteur Share Posté(e) 27 novembre 2012 (modifié) Non mais je suis ça de prêt. A l'allure ou ça va, ça va bientôt être tentant... ça en est déjà à la version 0.5.0. Modifié 27 novembre 2012 par Coolos Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adien Posté(e) 28 novembre 2012 Share Posté(e) 28 novembre 2012 C'est vrai qu'elle évolue vite cette rom, c'est tentant. Par contre, vous en pensez quoi de l'interface tablette 10 pouces de android 4.2 ? Je ne suis pas fan... Les 2 barres en haut et en bas bouffent encore plus de place sur l'écran. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 28 novembre 2012 Auteur Share Posté(e) 28 novembre 2012 (modifié) Pour l'interface ce n'est absolument pas un problème car j'utilise GO Launcher HD pour tablette, ça me permet d'avoir des répertoires dans le drawer et une sauvegarde au petits oignons de l'agencement du bureau lorsque je change de ROM. La 4.2 m’intéresse surtout pour la gestion du multi-utilisateurs, ça fait une plombe que j'attends ça sur Android, c'est une avancée énorme ! Modifié 28 novembre 2012 par Coolos Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adien Posté(e) 28 novembre 2012 Share Posté(e) 28 novembre 2012 Oui c'est sur. Mais avec le clavier sur la TF101, les boutons au milieu ce n'est pas le plus pratique... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gallardo93 Posté(e) 28 novembre 2012 Share Posté(e) 28 novembre 2012 Bonjour a tous j'ai un probleme lors de l'installation ,le voici, lorsque je redemarre en recovery ,quand je choisis de l'installer ,j'obtient un message d'erreur comme ceci : assert failed: getprop("ro.product.device")=="tf101"|| getprop("ro.build.product")=="tf101" Merci de bien vouloir m'aider Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 (modifié) Nouveau changelog ^^ [v0.5.0] Android 4.2.1 [v0.5.0] Trebuchet Launcher [v0.5.0] Camera seems to be broken again.. thank you CM [v0.5.1] Expanded Desktop Feature (Hiding the navbar) Modifié 5 décembre 2012 par esteboun Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ThorAsgard Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 (modifié) Ca avance plus vite que chez Asus ^^ Modifié 5 décembre 2012 par ThorAsgard Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Juste un peu ^_^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
steevou Posté(e) 6 décembre 2012 Share Posté(e) 6 décembre 2012 Bonjour, Quelqu'un l'a testé ? et peux nous faire un retour ? Je viens de le downloder, mais j'aimerai bien une petite critique sur ce CFW. Merci pour vos retours. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 7 décembre 2012 Share Posté(e) 7 décembre 2012 Je l'ai testé. Elle est sympa, elle marche bien elle est fluide mais il n'y a pas de gps, et pas de caméra fonctionnel. Sinon elle est sympa jolie pas de bug. Ça change quand même. Mais comme j'utilise pas mal ma tablette je suis retourné en v7 car j'avais fait une sauvegarde depuis le recovery Envoyé depuis mon XT925 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 8 décembre 2012 Share Posté(e) 8 décembre 2012 Nouveau changelog ^^ [v0.6.0] Expanded Desktop Feature (Hiding the navbar) [v0.6.0] Internal Microphone (thanks timduru!) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 8 décembre 2012 Auteur Share Posté(e) 8 décembre 2012 Merci pour l'info et pour ton retour ! Du coup j'ai mis le premier post à jour. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 9 décembre 2012 Share Posté(e) 9 décembre 2012 Pas de quoi, je ferai un retour quand elle aura un peu plus évolué. Envoyé depuis mon XT925 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 11 décembre 2012 Auteur Share Posté(e) 11 décembre 2012 (modifié) La prochaine version v0.6.0 sera 100% fonctionnelle ! (cameras, bluetooth etc...) Dispo dans 1 ou 2 jour si tout va bien... Modifié 11 décembre 2012 par Coolos Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
esteboun Posté(e) 11 décembre 2012 Share Posté(e) 11 décembre 2012 Yahouuuuuuuuuuu B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adien Posté(e) 14 décembre 2012 Share Posté(e) 14 décembre 2012 La dernière version est donc 100% fonctionelle ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Coolos Posté(e) 14 décembre 2012 Auteur Share Posté(e) 14 décembre 2012 La v0.6.0 devrait l'être... sauf qu'elle se fait toujours attendre. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ThorAsgard Posté(e) 14 décembre 2012 Share Posté(e) 14 décembre 2012 Un retour sur la reconnaissance du dock avec cette rom ? Je pense que je vais me lancer entre noël et nouvel an :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 16 décembre 2012 Share Posté(e) 16 décembre 2012 EOS4 est basé sur la 4.2 ...Par contre, je trouve qu'elle lag pas mal ! Envoyé depuis mon Transformer TF101 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
