benjiwolff Posté(e) 2 décembre 2012 Share Posté(e) 2 décembre 2012 (modifié) La ROM 3.0 : http://d-h.st/InJ Les Gapps : http://forum.xda-dev...d.php?t=2012857 *Instructions* 1. Full wipe before flashing(For easy way, JUST FLASH THIS(Rom-Wiper.zip)! : http://forum.xda-dev....27&postcount=2 Thanks brainmaster.) **You don't have to full wipe if you don't want that. But don't post here bugs if you did dirty flash.For Stableness, Full wipe is always recommended.** 2. Flash ROM and then Gapps, kernel(CM kernel is recommended). 3. Boot to System! 4. Don't touch anything for 5 mins.(I'm not sure if this really needed) 5. Reboot and enjoy.(login to gmail account..etc) *Please READ* -Use at Own your Risk. -About the Reporting bugs, -- Don't post bug here if you did dirty flash. -- When you are complaining about Battery, post BBS Dump file here. (BBS app link- http://forum.xda-dev.....php?t=1179809 ; Thanks chamonix!) -- Reboot? - post proc/last_kmsg in Kernel thread, and here. Before posting, Please READ once, if there is 'kalimochoaz', that's from cwm. Don't post it!! -- FC? Provide logcat! Or tell me how to reproduce it...... --Don't quote OP -Stock Kernel is included,(but I don't recommend it;it's performance is awful, imho) but I recommend custom kernel which has "Highbigmem"(CM version recommended) -Don't compare ROM and others' ROM. I don't like those things.. -Search before asking!! Changelog : v3.0(milestone3),(v2.12, v2.13, v2.14 was private release. Thanks for testing, androidphone2012) -Merged android-4.2.2_r1 JDQ39 -Completely rebased MMS.apk, Needs translations, again. -Reorganized lockscreen Settings -Little bit changed CRT-off related stuff. Hope you like it. -Bunch of commits from aosp. -Improved scrolling cache -Added refresher to screen off tile. -New "Mark Read" drawables (mms.apk) from Cyanogenmod -Cleaned up unused lines -Fixed Lockscreen Background stuff(anyway, thanks for the tip r_data) -Fixed GPS tile -Launcher2:Moved N4 Wallpaper to last -Build busybox from source(Cyanogenmod) -Allow muting camera shutter sound in certain countries(Or carriers) -expose mod version in "about phone" -remove incorrect summaries -New icons for rom control(thnx to androidphone2012) -some bug fixed -etc.. v0.1 -Based on 4.2.1 + Greenblue's patch added -Skip track via long press volume button -Expandable volume panel -3way reboot -T9 dialer -Back to kill app -Expose Rotation Lock -Volume Wakeup -Some speed hacks + Tweak -etc.. V0.2 -MMS features -themed dialer -rom control part(FC) V0.3 -integrate kevdliu's Quick toggle(temporary!)(sorry, haven't integrated to rom control yet) -more performance improvements and optimization -init.d -update to latest vanilla device tree by greenblue -Bug fixed(Some FC) -Statusbar stuffs -etc...can't remember..;p v0.3.1 Bug fix V0.5.2 Updated supersu Revert some tweaks Bug fixes Fix some build-errors Change some icons in quick settings v0.8 -fix busybot stuff(Thanks androidphone2012) -Allow all widgets in lockscreen(Thanks kevdliu) -Revert greenblue's keylayout(fixing cropping); Set density to 220; I guess PIN doesn't cropping anymore. -Some commits from aosp-More tweaks(No effect in battery, i guess) -volume wake fix -Fixed bootanimation delay -Improved MMS.apk -SystemUI: Statusbar Clock and Date actions -etc... V1.0 -revert to greenblue's layout fix; DPI is now 240. -volume button to move cursor -init.d fix V1.1 -Removed Greenblue's lockscreen layout fix -New Layout fix;No more SIM PIN layout cropping. -Solved FC in certain app(e.g. XDA app, Tapatalk...etc) -IME Switcher ON/OFF -Few Commits in MMS.apk -Add CLIENTID request to dhcpcd service -Little bit Code cleanup v1.3(milestone 1) -Now "Skip track via long press volume button" works in 3rd party music app -Stock theme. except dialer -Clock layout fixed -Short pressing clock in notification panel opens deskclock.apk, Long pressing clock opens Alarm -SystemUI: fix delay in applying am/pm setting for notification clock -Disabled Rotation Lock/Auto brightness by default -Use appropriate notify method instead -Call to equals() comparing different types -Few commits from aosp. -Fix RAM leaking -Now LatimIME includes gesture typing. not alen1901's prebuilt, built-from-source. -Clear All button(Recent apps) -TTF Camera add-on; Not built from source. See 3rd post. -Few optimizations. -etc..Can't remember v1.9[**Experimental Build**] -Lockscreen Targets -Re-enable magnetic targets -Back-to-kill popup toast -Don't raise volume on skip track -Powerkey shutter(it doesn't work.Don't Enable it; it causes FC! DON'T HAVE TO REPORT, GONNA BE FIXED IN NEXT VERSION) -Facebook Sync(romanbb) -Some telephony Stuff -Removed kevdliu's toggle -AOKP Toggles.(Clock<E Toggle causes FC for now :/ - DON'T HAVE TO REPORT, GONNA BE FIXED IN NEXT VERSION) -Fix possible NPE -Add framework definition to include Torch -Some MMS improvements -Few Commits from aosp -CM functions; Phone part - vibrate on answer, vibrate on call waiting, vibrate on hang up, vibrate every 45 seconds -Few Speed improvements, not sure.. -Cleaned up codes(strings, etc) -Bug fixes v1.10 -private release v1.12 -private release v2.0 -More improvements in MMS.apk -Now Jellyshot supports TTF camera -Fixed Gallery FC when Powershutter enabled -changed source location of Quick settings -Quick pulldown (CM logic, only right side) -Removed CM clock stuff(Many people are suffering from layout issue.. :/) -Aokp style clock.(No color settings, I removed it) -Removed Busybox-installer script from update-script;Changed installer style(init.d) -Removed Duplicated Ringtone -Stop Debugging in some actions.. -Added some translations -Fixed some NFC Related bug -Gesture typing keyboard is no more "built-from-source" because that caused FC in some keyboard apps -Removed Circle battery style(only Percentage style exists; I removed because NS is too small for reading that number) -Changed some strings -Fast scroll in Settings>applications -Screenshot : Pass current user -Update the JNI spec link, and remove a dead link. -Little bit improved calendar(not function) -Cleaned up source -added power mode support -GlobalActions: Fix possible race condition when showing dialog. -enable copy/paste for google talk -Quick settings Torch tile : Torch.apk doesn't needed anymore, it's included in framework. -No more LTE Tile -Added Screen off tile -Fixed Bluetooth tile -Fixed Wifi AP tile -Fixed Wifi tile -Fixed quick toggles layout(landscape mode) -QuickSettings: fix vibrate and silence toggle not updating -add "Turn Wi-Fi off" action to the "open networks available" notification -SystemUI: refactor fast charge toggle(You must grant Superuser permission(com.android.settings) to use it) -fix derp space/tab -Fixed aapt warnings -Fixed PLMN Stuffs -Reduced stuttering -Removes Settings from gallery -Refactoring ResolverActivity.java -Re-use existing thread -Optimize drawHardwareAccelerated method in Editor class -...More commits from aosp.. -...etc! v2.1(milestone 2) -Fixed init.d placeholder not installed -Fixed busybox-installer script -TIME_TICK was not occurred for one hour(commit from aosp) -Fixed NPE in IME Selector method("FC in some keyboard apps" issue and IME Tile FC fixed) -Fixed memory leaking when web browsing -Send all types of file via bluetooth -Re-enabled gesture typing keyboard because this wasn't reason for "FC in some keyboard apps(fixed anyway)" issue -I forgot to add TTF camera in v2.0; it added in this version! v2.2(private release) v2.2.5 -Support OTA via goomanager!(get goomanager in play store) -Highlight the clear button in the recents view when clicked -Give more permission to QS -Added Sound/Vib/Silent tile -Fixed GPS tile -Fixed NFC tile issue -Removed GB Remaining stuffs -Changed background(?) location which is same as 4.1.x -Changed translation error(portugese), thanks for reporting -Fixed typo in settings part, thanks for reporting -QS Pull down:Since 70% is too much for me, so changed to 80% -Changed source location(QS) -Fixed MMS.apk FC in chinese language. -Changed "long press volume button to skip track" logic a bit -Removed unnecessary behavior -Optimization in lockscreen : little bit.. -SystemUI: show date on 2 lines in status bar -Zygote: Restrict slave mountspace so Dalvik apps can mount system-wide volumes -Fixed some MMS.apk issue, and more improvements v2.4 ,v2.4.5, v2.5 -private release v2.6 -Fixed "Show date on 2 lines in status bar" shows strangely in Korean language -Re-fixed NFC tile -Revert "Zygote: Restrict slave mountspace so Dalvik apps can mount system-wide volumes" -Quick QS pulldown:left/right/off -Swipe the line in notification panel buttom bar to Switch between Notification center and Quick Settings(Video :) -Cleaned up sources. Some lines doesn't need for features -Long-pressing Settings button opens "app selection" popup, same behavior as "clock tile" -Reverted "Remove remaining GB Stuff(theme)"; Gonna be added better one made by kindkenki -Fixed Gallery/Camera Stuff(FC) -extend PreferenceActivity for title text on a single pane mode -Fixed Off-centerness of lockscreen handle when changing DPI -Fixed Some FC and errors Settings app(commits from aosp) -use holo style ic_grabber v2.8 -Fix some phone.apk issue when cpu is high-loaded(commit from aosp) -Dismiss touch in "load network list" dialog(commit from aosp) -NetworkSettings: Cannot dismiss progress dialog sometimes.(commit from aosp) -Some mms.apk improvements -Long pressing settings tile directs you to QS Rom control -Long pressing display tile directs you to Display settings -New power menu tile by rascarlo -Settings: use DefaultContainerService for all file operations -Launcher2:New N4 background -LauncherModel: Optimize loading -Fix Launcher2 FC(sometimes) -Notification panel clock behavior(CM logic):clock->deskclock.apk(doesn't work yet), date->Calendar -Revert "Re-implement magnetic targets" -Korean translations by kindkenki -More power-saving tweaks -Bug fixed found by myself -updated supersu/su binary to v1.0 -improved audio stuff(fix stuttering, memory leak, etc) -Browser: Changed user agent location -etc v2.10 -Updated to JOP40G(4.2.1_r1.2) -Boosting tweak stuff(verified) -remove long click clock stuff in expanded header(prevents clock tile fc for now) -Brightness Slider -Torch method::CM(doesn't work yet, do not report) -Lockscreen Background(doesn't work yet, do not report) -Auto retrieval MMS -Few commits from aosp -Fix gps tile -CM circle battery, again! -SystemUI: highlight quick settings and notification clear buttons Actually make use of the drawables bestowed upon us by the Google -Fixes and additions for Korean translation(thanks kindkenki) -Prevent audio players starting on startup. -add missing lines for Category -updated super su to v1.04 -Stability++ v2.11 -fixed Torch tile -More korean translations by kindkenki -MMS improvements -Lockscreen background::not yet. sorry XDA : http://forum.xda-dev...d.php?t=2023699 Modifié 17 février 2013 par benjiwolff Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 2 décembre 2012 Share Posté(e) 2 décembre 2012 Tu pourra faire un retour sur l'autonomie ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjiwolff Posté(e) 2 décembre 2012 Auteur Share Posté(e) 2 décembre 2012 Ça fait 10h que je l'utilise et j'en suis a 50% en utilisation normale. En plus j'ai oublié de désactivé le wifi ;) Et je suis sur le kernel marmite :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ludotaz Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 Bonjour Inutilisable, reboot en boucle juste après procedure d'installation. Une idée ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Snouki Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 tu as bien fait tes wipe? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ludotaz Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 Oui, le logo x coloré pendant 5 bonnes minutes, je vois très vite fait le bureau avec verrouillage, ça passe au code pin (nouvelle présentation) à peine 2 secondes et reboot. Ça fait ça en boucle. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Snouki Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 sa me faisait sa aussi sur la première 4.2 fait wipe all et factoty reset puis installe la ROM, reboot et après gapps et su Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ludotaz Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 Je vais réessayer. Je crois qu'une autre version est sortie. Par contre les gapps avec photosphère, etc... (2eme lien gapps sur le topic de la ROM xda) fonctionne ? Je ne vois pas de lien pour télécharger la dernière version. Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 La version 0.3 est disponible http://d-h.st/pPY V0.2-MMS features -themed dialer -rom control part(FC) V0.3 -integrate kevdliu's Quick toggle(temporary!)(sorry' date=' haven't integrated to rom control yet) -more performance improvements and optimization -init.d -update to latest vanilla device tree by greenblue -Bug fixed(Some FC) -Statusbar stuffs -etc...can't remember..;p[/quote'] Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ludotaz Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 J'ai pris la 0.3.1 enfin les liens ont été mis à jour. Tout fonctionne nickel pour l'instant. Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nexorg Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 J'ai installé la0.1 ce matin ...effectivement il faut redémarrer avant de flasher les gapps sinon bootloop ! Pour l'instant que du bonheur avec le kernel marmite ! J'installerai les mises a jour en rentrant ce soir Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
STEF SPICA Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 (modifié) Salut à tous, je viens de CM10 et ai installé par curiosité cette ROM, plutôt bien pour l'instant. Qqu'un peut me donner son avis sur le kernel a utilisé et un lien si pas trop demandé ; ). Merci ... Edit : Et oui quelles GAPPS faut il utiliser, celles qui sont sur GOO.IM ou celles qui sont XDA ? Merci à tous ... Modifié 3 décembre 2012 par STEPHANDROID Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Snouki Posté(e) 3 décembre 2012 Share Posté(e) 3 décembre 2012 c'est les même gapps, pour le kernel fait toi déjà une idée avec l'original Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ludotaz Posté(e) 4 décembre 2012 Share Posté(e) 4 décembre 2012 Retour à miui. Trop de fc aléatoires et retour au code pin carte sim. Maintenant que j'en ai testé un paquet de ROM, je préfère rester sur des roms plus "connus" , moins bidouillée. Peut être après plusieurs maj je réessayerai, pour l'instant je me calme et reviens sur miui. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjiwolff Posté(e) 4 décembre 2012 Auteur Share Posté(e) 4 décembre 2012 C'est étrange que tu ais tous ces problèmes... Moi j'en ai pas encore croisé... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nexorg Posté(e) 4 décembre 2012 Share Posté(e) 4 décembre 2012 oui c'est étrange, pour ma part je le trouve réactive, aucun fc, le seul soucis que j'ai eu c'est le bouton raccourcis dans la barre de notif qui a disparue, mais qui est revenue apres un reboot ! j'aime beaucoup ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
luchotluchot Posté(e) 4 décembre 2012 Share Posté(e) 4 décembre 2012 Ou peut on trouver une liste de kernel compatible avec la 4.2.1? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 4 décembre 2012 Share Posté(e) 4 décembre 2012 Air kernel Marmite Trinity Les trois sont compatibles 4.2.*. Pour plus d'informations sur ces kernels va sur XDA Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
luchotluchot Posté(e) 4 décembre 2012 Share Posté(e) 4 décembre 2012 Merci beaucoup Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Spv57640 Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 (modifié) Et voilà, ROM installée :-) Je verrais plus tard pour le kernel, celui d'origine a l'air de bien fonctionner ! Modifié 5 décembre 2012 par Spv57640 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Avez vous remarqué cela sur la V0.5.2 : - Disparition de la réponse rapide dans la barre de notifications - Horloge placé au centre Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjiwolff Posté(e) 5 décembre 2012 Auteur Share Posté(e) 5 décembre 2012 Je ne l'ai pas installée la 0.3.1 me va bien pour le moment :) Tu l'as installée avec un wipe all ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Ouais Wipe All -> install Rom -> reboot -> install GAPPS -> reboot -> Install Kernel -> reboot Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
benjiwolff Posté(e) 5 décembre 2012 Auteur Share Posté(e) 5 décembre 2012 Faut pas réactiver la réponse rapide dans les paramètres sms ? Pour l'heure je sais pas du tout... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Spv57640 Posté(e) 5 décembre 2012 Share Posté(e) 5 décembre 2012 Je suis en 0.5 et j'ai eu la réponse rapide en barre de notif' sans rien toucher. Par contre, j'ai déjà eu 2 reboots intempestifs :-/ Envoyé depuis mon Nexus S avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
