cédric Posté(e) 27 janvier 2013 Share Posté(e) 27 janvier 2013 (modifié) [ROM] Android Revolution HD 11.2 | High Quality & Performance | XXCML2 | Jelly Bean Lien XDA: http://forum.xda-dev...d.php?t=2119547 Veuillez lire attentivement le poste avant d'installer la ROM. System details: Android 4.1.2 (Jelly Bean) - latest official Samsung N8000XXCML2 firmware This is improved version of stock ROM - no visual changes! Very fast, clean & stable! Multi-language (WWE) Full Arabic and Hebrew languages support! (ICS feature) For Samsung Galaxy Note 10.1 (N8000, N8010, N8013) Thanks to Samsung for the base firmware Included kernel details: Stock kernel (the most stable)ROM details: Removed software (CPU) rendering - full Exynos 4 Quad (GPU) rendering Fully optimized and tweaked ROOT (su + SuperSu Permissions - Thanks to chainfire) Unsecured boot.img Newest BusyBox RAM optimizations System signatures check enabled for system security and safety Improved virtual memory management Speed optimizations Enabled GPU UI rendering Data, cache and system partitions mounting tweaks Bloatware applications removed All /system applications updated to latest available All /data applications updated to latest available Improved camera performance Improved CPU governors performance Most optimal system scheduler Disabled kernel debugging for better performance Zipaligned (Improved RAM management) Zipalign on boot (for user applications on data partition) Fully de-odexed init.d scripts (BusyBox run-parts) support Auto init.d permissions set on boot sysro/sysrw commands support Excellent battery life! Improved EXT4 performance OpenVPN support Most up-to-date system files permissions Adobe Flash Player support for Jelly Bean Support almost 24h a day ...and many more! You need: Samsung Galaxy Note 10.1 (N8000, N8010, N8013) Custom Recovery "High On Android" Comment flasher: Télécharger la ROM et placez-la sur votre carte SD ( sur votre carte SD externe si vous en avez une). Démarrez votre téléphone en mode RECOVERY Dans le menu principal, sélectionnez "install zip from sdcard" Sélectionnez "choose zip from sdcard" et choisissez la ROM Android Revolution Vous pouvez faire un wipe data en option dans AROMA Après le flash, redémarrez l'appareil Downloads:Android Revolution HD 11.2--- MD5 Checksum: 398969DA14C88476B3FBC51BDA56ADE7 --- http://android-revol...r-site-var.html Changelogs: Android Revolution HD 11.2--- release date: 3 March 2014 --- Re-deodexed using latest smali/baksmali Removed zipaligned on boot because every .apk is zipaligned already Moved init.d trigger back to ramdisk Updated tune2fs binary Updated sqlite binary Other minor changes and fixes Included and updated applications: --- Data partition --- Adobe Flash Player 11.1.115.81 (Android 4.0+) Adobe Flash Player 11.1.111.73 (Android 2.0+) Adobe Reader 11.1.3 Dropbox 2.3.12.10 ES File Explorer 3.1.0.3 Facebook 6.0.0.28.28 Twitter 5.1.4 --- System partition ---GmsCore 4.2.39 (Android 2.3+ / SDK 9) Gmail 4.7.2 (Android 4.0+ / SDK 14) Gmail 2.3.6 (Android 2.2+ / SDK 10) Google Play 4.5.10 Push Service 1.2.4.7 (Samsung devices) SuperUser 1.0.3.0 SuperSU 1.93 --- Aroma installer ---Google Hangouts 2.0.303 (Android 2.3+ / SDK 9) Google Maps 6.14.4 (Android 2.2+ / SDK 8) Google Maps 7.6.1 (Android 4.0.3+) Google Plus 4.3.0.62241793 (Android 3.0+ / SDK 11) Google Street 1.8.1.2 (Android 2.2+ / SDK 8) Google YouTube 5.3.32 (Android 2.2+ / SDK 8) Google TalkBack 3.5.1 (Android 2.2+ / SDK 8) Google Chrome 33.0.1750.136 (Android 4.0+ / SDK 14) Google Music 5.4.1409N.1014766(Android 2.2+ / SDK 8) Google Keep 2.1.01 (Android 4.0+ / SDK 14) Google Drive 1.2.563.31 (Android 2.3+ / SDK 9) Google Search 3.2.17.1009776 (Android 4.1+ / SDK 16) Google Search 1.4.1.338691 (Android 4.0.3) Google Search 1.1.2.64376 (Android 2.3.5) Compatibility Pack pour N8010 et N8013 V11.1 http://www.stockyrom.de/?wpdmact=process&did=MTUuaG90bGluaw== Battery MOD et 4-Way Reboot Menu http://forum.xda-dev...836&postcount=4 InkEffect http://forum.xda-dev...d.php?t=2131684 Multi Fenêtres https://play.google....3dtYW5hZ2VyIl0. Modifié 17 avril 2014 par Cédric 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 28 janvier 2013 Share Posté(e) 28 janvier 2013 (modifié) Haha tu m'as devancé, je comptais faire un topic pour cette rom. Tu l'as installée ? Edit: je viens de voir ta signature ^^ Modifié 28 janvier 2013 par PuNkA.YaNoU Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cédric Posté(e) 28 janvier 2013 Auteur Share Posté(e) 28 janvier 2013 Oui installes la pour tester elle est vraiment super fluide. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 28 janvier 2013 Share Posté(e) 28 janvier 2013 Elle est enorme cette rom ! Pas besoin de oc... ( d'ailleurs par reussi), le multi app fonctionne, le clavier alternatif aussi.... Le battery mod idem. Je conseille aussi le teste de ce mod pour avoir vraiment un thème vraiment, mais vraiment très beau... : http://forum.xda-developers.com/showthread.php?t=2111691 Mix theme, ou comment passer d'un note classique à l'esthétique.... Je regrette la perte des full inverted apps quand même, bien quavec un jeu de sauveguarde on puisse récupérer presque entièrement gmail et google play en noir... J'avoue être conquis! Envoyé depuis mon GT-N8000 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 28 janvier 2013 Share Posté(e) 28 janvier 2013 Je suis en train de telecharger la 2.2, trop envie de voir le résultat ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
choupaki69 Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 bonjour, j'ai une note 10.1 mais la N8020 (wifi et 4g) la rom fonctionnerais t"elle? si oui je pense que je devrais me passer de la data ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 :wacko: cherche sauveguarde ou apk de gmail et google play en inverted .., grrr..... Merci au vénérable qui partagera... Envoyé depuis mon GT-N8000 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cédric Posté(e) 29 janvier 2013 Auteur Share Posté(e) 29 janvier 2013 bonjour, j'ai une note 10.1 mais la N8020 (wifi et 4g) la rom fonctionnerais t"elle? si oui je pense que je devrais me passer de la data ?? Tu pourras l'installer mais tu perdras surement la 4g et je ne crois pas qu'il y ai de patch de prévu pour la N8020. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 (modifié) Elle est enorme cette rom ! Pas besoin de oc... ( d'ailleurs par reussi), le multi app fonctionne, le clavier alternatif aussi.... Le battery mod idem. Je conseille aussi le teste de ce mod pour avoir vraiment un thème vraiment, mais vraiment très beau... : http://forum.xda-developers.com/showthread.php?t=2111691 Mix theme, ou comment passer d'un note classique à l'esthétique.... Je regrette la perte des full inverted apps quand même, bien quavec un jeu de sauveguarde on puisse récupérer presque entièrement gmail et google play en noir... J'avoue être conquis! Envoyé depuis mon GT-N8000 avec Tapatalk Allez zou j'installe :) Si t'arrive à obtenir le lien pour le thème, je suis preneur !!! Modifié 29 janvier 2013 par PuNkA.YaNoU Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 (modifié) Je serai preneur des apk google play et "gmail bleu" issu de la redemption, c'est à dire inversé. Une âme charitable ? Envoyé depuis mon GT-N8000 avec Tapatalk Modifié 29 janvier 2013 par elyo94 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 Wouah il est top ce thème !!!! La rom aussi d'ailleurs ^^ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
netzo97 Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 comment on fait pour le telecharger? :-( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 Il faut cliquer sur thanks, envoyer un mp au développeur et il t'envoie le lien ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 (modifié) Sérieux personne n'a de sauveguarde de ces 2 apps ? Sinon, la v3 est sortie, 1, 32 au demarrage... Envoyé depuis mon GT-N8000 avec Tapatalk Modifié 30 janvier 2013 par elyo94 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Sérieux personne n'a de sauveguarde de ces 2 apps ? Sinon, la v3 est sortie, 1, 32 au demarrage... Envoyé depuis mon GT-N8000 avec Tapatalk Non j'ai pas, désolé :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Arf install et reinstall :/ Envoyé depuis mon GT-N8000 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 (modifié) Et ouai :/ Bon en tout cas cette rom déchire bien et on est sûr d'avoir un suivi sur celle là ;) Modifié 30 janvier 2013 par PuNkA.YaNoU Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 sur le mix theme aussi ! il en est à la V10, et quel taff!!! rien vu d'aussi abouti avant ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Ha je suis en v13 moi :) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
netzo97 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 qui aurait l'aimabilité de m'envoyer le thèeme car il ne me répond pas :-( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 31 janvier 2013 Share Posté(e) 31 janvier 2013 qui aurait l'aimabilité de m'envoyer le thèeme car il ne me répond pas :-( Insiste un peu plus ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elyo94 Posté(e) 31 janvier 2013 Share Posté(e) 31 janvier 2013 Ha je suis en v13 moi :) Itou itou Envoyé depuis mon GT-N8000 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
f5bsf Posté(e) 31 janvier 2013 Share Posté(e) 31 janvier 2013 bonjour à tous J ai installé le theme mais ma tablette reste bloquée sur le logo de démarage :( J ai effectué tous les wipes Si quelqu'un a une idée :) merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PuNkA.YaNoU Posté(e) 31 janvier 2013 Share Posté(e) 31 janvier 2013 Pas besoin de wipe pour flasher le thème. T'es resté bloqué combien de temps sur le logo Samsung ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cédric Posté(e) 31 janvier 2013 Auteur Share Posté(e) 31 janvier 2013 Apparemment darkman va essayer d'inclure le kernel de la N8010 et 8013 dans le pack de compatibilité. @PuNkA.YaNoU notre responsable de section,tu peux pas nous faire des sections général, dev.... se serait sympa et plus lisible B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
