ablackswan Posté(e) 29 janvier 2013 Share Posté(e) 29 janvier 2013 (modifié) This is a continuation of KonstaT's fantastic work with CM10. All the same things as written there also apply here. In particular, constructive discussion is welcome, whining and bitching is not.Download: cm-10-20130514-NIGHTLY-blade.zip http://www.mediafire...qd8bbvmi9801246 SHA1: d229012359d52bda243957e4644dca76bb7aef16 MD5: 1787d3a2ea071e1faae6070adfe932f3 gapps-jb-20121017-KonstaKANG.zip http://www.mediafire...qscnhfuadsujki1 SHA1: 1aa25bd25fe5cab6758739c1afd1c6f0d1ef0025 MD5: 9979601a6b32b0d4e147f5be79b4f01e Old builds: cm-10-20130328-NIGHTLY-blade.zip http://www.mediafire...c868u2l8c53489d SHA1: 076d9f0f14af12e3e05f24956aeb48f792d06b90 MD5: 7e1709e6f87ca0da35e528e2ec676c09 Working: RIL (mobile network & data) Wifi (& Wifi tethering) Bluetooth (& BT tethering) GPS Audio (playback/input/routing/headphones/etc) FM radio Hardware vsync events (i.e. Project Butter) Hardware acceleration and OpenGL rendering Hardware video decoding & encoding Camera (photos, camcorder & panorama) SD card USB storage & adb USB tethering Browser Touchscreen/multi-touch Sensors LEDs Not working: ? Sources: Device Proprietaries Kernel Thanks: CyanogenMod team, KonstaT & everyone who's been working on CM10 2013-05-14 low memory killer from 3.4 kernel (thanks to plaguedbypenguins) reduced wifi scan timeout / faster wifi reconnect (thanks to plaguedbypenguins) updated Blade settings (thanks to KonstaT) updated terminal emulator libraries 2013-03-28 fix graphical glitches in navbar/statusbar (like this) limit number of hidden apps fix switching off FM audio in some cases (more info) update Effem (bugfixes, in-call muting) 2013-03-18 change build type to 'NIGHTLY' FM radio RDS support new FM radio app: Effem fix photo editor crashes (disables effects that didn't work) fix camera crashes reduce navigation bar size to 36dp update URL in device info 2013-02-26 fix corruption in Trebuchet's icon label rendering add and improve FM radio support libpower tunings update KGSL from CAF, fixes GPU out of memory issues (i.e. white textures and the like) 2013-01-29 hardware vsync events (i.e. Project Butter) switch to legacy camera (until panorama is fixed) prefer RGB565 pixel format for opaque surfaces and bitmaps reenable 16bpp drawing cache use RGB565 pixel format for wallpaper Sujet original http://www.modaco.co...-konstats-work/ Modifié 17 mai 2013 par ablackswan Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phoenamandre Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 J'ai cette rom, mais le tethering ne fonctionne pas. Je peux l'activer, mais pas d'internet sur l'ordinateur. Des idées ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 (modifié) Euh...il fonctionne très bien. Par défaut, lorsqu'il est activé, tu le vois comme une box appelée AndroidAP. :) Modifié 30 janvier 2013 par mickajo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elexod Posté(e) 31 janvier 2013 Share Posté(e) 31 janvier 2013 C'est quoi la différence avec l'autre CM10 ? ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ablackswan Posté(e) 31 janvier 2013 Auteur Share Posté(e) 31 janvier 2013 une réactivité et fluidité accrue Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
facil Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 salut, les gains sont ils vraiment significatifs? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 Honnêtement? Non pas grande différence... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
facil Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 Merci, je posais la question car je trouve que CM10 c'est bien quand c'est fraîchement installé, a partir du moment ou tu as plus de trois applis.... ça rame très fort. Je pense repartir sur de 2.3 du coup Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phoenamandre Posté(e) 2 février 2013 Share Posté(e) 2 février 2013 CM9 est toujours très bonne. Le seul problème est qu'ils n'ont pas inclus de quoi décoder la HQ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 2 février 2013 Share Posté(e) 2 février 2013 Merci, je posais la question car je trouve que CM10 c'est bien quand c'est fraîchement installé, a partir du moment ou tu as plus de trois applis.... ça rame très fort. Je pense repartir sur de 2.3 du coup T'as quoi comme TPT? Des fois, ça explique des choses ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ablackswan Posté(e) 2 février 2013 Auteur Share Posté(e) 2 février 2013 CM9 est toujours très bonne. Le seul problème est qu'ils n'ont pas inclus de quoi décoder la HQ Et a priori ça n'existera jamais. Le projet butter est fonctionnel maintenant et le format de pixel a été revu à la baisse pour une meilleure fluidité Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipflip Posté(e) 6 février 2013 Share Posté(e) 6 février 2013 J'utilise cette version depuis ce week-end et pour le moment c'est nikel. Pas de plantage d'affichage, plus besoin d'aller forcer la recherche réseau pour me connecter en 3G. Niveau fluidité comme avant il arrive d'avoir des ralentissements sans raison particulière. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Je suis tenté... car je trouve aussi que ma CM10 4.1.2 KonstaKang (10-20121124) rame de trop :( Tiens, puis-je installer cette version sur la mienne sans tout perdre ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 (modifié) Normalement un Wipe Cache + Wipe Dalvik devraient suffire. Fais tout de même un backup avant, au cazoù... :) Modifié 7 février 2013 par mickajo 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Normalement un Wipe Cache + Wipe Dalvik devraient suffit. Fais tout de même un backup avant, au cazoù... :) Merci Mick ;)C'est celle-ci que tu as installée sur ton Blade ? Si oui, tu la trouves effectivement plus réactive ? Pour ma part, c'est l'intervention de flipflip qui me déciderait à changer car j'en ai ras-la-coupe de devoir rebooter mon smartphone pour accrocher un réseau 3G. J'utilise cette version depuis ce week-end et pour le moment c'est nikel. Pas de plantage d'affichage, plus besoin d'aller forcer la recherche réseau pour me connecter en 3G. Niveau fluidité comme avant il arrive d'avoir des ralentissements sans raison particulière. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Oui c'est ce que j'ai. Après, je m'en suis pas trop servi (je suis passé sur le Nexus 4) mais elle ne semble pas spécialement plus réactive que les versions "officielles". Elle corrige seulement certains petits bugs et pas de problèmes de réseau en vue ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 18 février 2013 Share Posté(e) 18 février 2013 Hummm... aucun changement chez moi par rapport à la dernière version de Konsta. Ah, si ! la batterie se vide maintenant complètement en 24h00 sans utilisation de la bête. Grrrr, je vais commencer à détester ce smartphone :mellow: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 18 février 2013 Share Posté(e) 18 février 2013 T'as calibré? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 18 février 2013 Share Posté(e) 18 février 2013 Vi, mais rien n'a changé :( Je devrais peut-être passer en 4.2.2 pour tester. Si pas de changement, je retourne en 2.3.5 :huh: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mum Posté(e) 18 février 2013 Share Posté(e) 18 février 2013 Vi, mais rien n'a changé :( Je devrais peut-être passer en 4.2.2 pour tester. Si pas de changement, je retourne en 2.3.5 :huh: Hein ? Sinon la CM10 de Konstat fonctionne bien et a une bonne autonomie, il faut bien faire les WIpe, format system et tout. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mum Posté(e) 19 mars 2013 Share Posté(e) 19 mars 2013 2013-03-18 change build type to 'NIGHTLY' FM radio RDS support new FM radio app: Effem fix photo editor crashes (disables effects that didn't work) fix camera crashes reduce navigation bar size to 36dp update URL in device info 2013-02-26 fix corruption in Trebuchet's icon label rendering add and improve FM radio support libpower tunings update KGSL from CAF, fixes GPU out of memory issues (i.e. white textures and the like) news MAJ cm-10-20130318-NIGHTLY-blade.zip http://www.mediafire.com/?afnr0kapvgh4k4h SHA1: 5d8c9915b72ae4d61ea15b81e01a1ec71e080ca0 MD5: 3c2d3483084c35cd9adedeea6b7d2872 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bolido Posté(e) 19 mars 2013 Share Posté(e) 19 mars 2013 installée. La radio marche nickel ! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bolido Posté(e) 8 avril 2013 Share Posté(e) 8 avril 2013 cm-10-20130328-NIGHTLY-blade.zip http://www.mediafire...c868u2l8c53489d SHA1: 076d9f0f14af12e3e05f24956aeb48f792d06b90 MD5: 7e1709e6f87ca0da35e528e2ec676c09 Changelog: 2013-03-28 fix graphical glitches in navbar/statusbar (like this) limit number of hidden apps fix switching off FM audio in some cases (more info) update Effem (bugfixes, in-call muting) Pas encore installée..... Peut-être ce soir ! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 8 avril 2013 Share Posté(e) 8 avril 2013 Installée depuis sa sortie et nickel! J'hésite beaucoup entre rester sur celle ci ou passer sur la 4.2 mais s'il n'y a que très peu de différences... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bolido Posté(e) 8 avril 2013 Share Posté(e) 8 avril 2013 Installée depuis sa sortie et nickel! Cool et merci pour le retour ! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
