Billouetaudrey Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 (modifié) Voila une rom qui peut plaire a pas mal de monde ;) Un mix de CM PA et AOKP Je n'ai pas tester personnellement, car il n'y a pas le PIE ( prévue pour les prochaines version ;) A vous de jouer :D Des screenshots sont disponible sur le site de téléchargement Why is this ROM "taking CyanogenMod to the next level? CyanogenMod does not want to include many customizations like they did in cm7 But why not? We want to customize our phones! This ROM adds more options and cherries to CyanogenMod' date=' cherry picked from the CM gerrit, Google gerrit, AOKP gerrit, SGT7, TeamEOS, TeamBAKED and ParanoidAndroid Basically this is one big mixture of all the great ROMs out here! Stock but still highly customizable the way we like it [center'][/center] Instructions: Download all the needed files (ROM, Gapps) Boot into recovery Flash the ROM.zip Flash Gapps ROM: ROMs can be found here Download portal Gapps: PA gapps can be found here http://goo.im/devs/p....2-20130108.zip Zowie93 Team douche Team KANG CNA SGT7 TeamBAKED TeamEOS ParanoidAndroid Pabx nimrodity Build 4: MD5: D624351A6BE6A9CF76BF8377842B195B SHA1: A161AA2B1689C609F4906645C0B6AFF259FD3397 Quote: Added transparency settings (doesn't work well with PA Colors for now) Added signal text settings and colors Updated PAPrefs Fixed navring placement Made tablet notification panel pretty Added navbar height settings Fixed lockscreen wallpaper (doesn't work with transparent status/nav bar on lockscreen) Added ROW sched and made it the default Changed battery to CyanogenMod their implantation Fixed no clock option Fixed signal layout alignment Added nicer signal images Build 3: MD5: 630CEE4F1E5CBA2F19A08F7063303E64 SHA1: 287C7BA59E690CBE18EC8BD01C0A34680DB41AF6 Quote: Merged android-4.2.1_r1.2 (JOP40G) Kernel: Sound control - Ezekeel SLQB - Ezekeel SIO Sched - Ezekeel fsynccontrol - Ezekeel FastCharge - Chad Froubel PackageManager: Restrict system packages to protected storage Framework - SystemUI: LastApp Toggle SystemUI: respect global vibrate settings in the statusbar Fixed FastCharge toggle Volume button cursor control Fix left over glow Frameworks Audio/Video: Merge upstream with CAF Frameworks telephony: Merge upstream with CyanogenMod Policy: Fixed potential NPE Phone: Updated call parameters Contacts: Fixed potential NPE Fix threads running after entering call log, possibly affecting battery life Allow quick pre-selection of filter range Cleanup code and make call data processing asynchronous Fix display of missed calls when filtering for call type and sorting by count Wpa supplicant: Fix regression in LEAP Settings: Fixed random tab title Deleted non working clock color option (PA Colors controls it anyways) CMFileManager: Merge upstream with CyanogenMod LockClock: Merge upstream with CyanogenMod Build 2: MD5: C62CA969F318BB53D14A3876FE62F583 SHA1: D3E1F6DEFA2B463DEC5FC0E8F4491DB243A31BA5 Fixed bootanimation Fixed pattern lock settings Fixed Phone application settings Custom vibration per contact CallStats/Log fixes & improvements from CM Remove the dark pixel artifacts from the nav bar back arrow Fix for home wake/unlock sometimes waking and unlocking during the same keypress A lot of small under the hood tweaks and fixes Build 1: MD5: C95F135409D8E39285A1A79C859005CE SHA1: 60D31866ADE60B645438FC1C83989FEA1D78854D Initial Release No PA Pie i'm sorry Source : http://forum.xda-dev...d.php?t=2124838 Modifié 12 février 2013 par Billouetaudrey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 T'en a mis du temps.....;) depuis mon nExUs pRiMe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Dès que le Pie sort sur cette ROM je test :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Avec les Pie, et un suivi assez long (pour corriger tous les bugs et mettre à jour), sa pourrais être intéressant. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 30 janvier 2013 Auteur Share Posté(e) 30 janvier 2013 T'en a mis du temps.....;)depuis mon nExUs pRiMe Mais tu m'as pas devancer, donc ca me va :P Envoyé depuis mon Transformer TF101 avec Tapatalk Dès que le Pie sort sur cette ROM je test :) idem si je resiste jusque la :) Envoyé depuis mon Transformer TF101 avec Tapatalk T'en a mis du temps.....;)depuis mon nExUs pRiMe Clair mais tu m'as pas devancer, donc ca me va :D Envoyé depuis mon Transformer TF101 avec Tapatalk je test aussi dès la sortie avec Pie ;) Et je donnerai un max d'info ;) Envoyé depuis mon Transformer TF101 avec Tapatalk 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Norisano Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Mais les Pie vous les prenez pas avec LMT ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Mais les Pie vous les prenez pas avec LMT ? Pas aussi bien que ceux de PA, pourtant c'est quasi identique. Mais ceux de PA sont mieux ... depuis mon nExUs pRiMe 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Norisano Posté(e) 30 janvier 2013 Share Posté(e) 30 janvier 2013 Ah elle me donne envie cette paranoïde ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 31 janvier 2013 Auteur Share Posté(e) 31 janvier 2013 (modifié) J'ai pas pu résister, je me suis lancé ;) Excellente rom, tous les tweaks en une seule rom :) Si j'en trouve d'autre, je vous les donnerai ;) Si des questions, hésitez pas ;) Bug rencontrés : - Toggle Fast Charge fonctionne pas - Using tablet mode the navbar looks "split": one half (the actual navbar) has a color, while the statusbar another. i couldn't fix this in hybrid properties. -Sometimes the clock is not white but holo blue ( Horloge se met en bleu au lieu de blanc ) -Misaligned battery icon (already reported many times) ( Probleme d'icone batterie, je vois pas lequel ... ) -Custom color (per app) does not apply to the battery icon. ( La couleur de batterie ne change pas pour les applis per app color ) - Force close quand on veut aller dans la parametre de l'application Téléphone Modifié 31 janvier 2013 par Billouetaudrey 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barrac28 Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 C'est exactement la rom que je cherchais!! Encore quelques petits bug, et une autonomie moyenne mais pour 1ere build, c juste énorme!!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 1 février 2013 Auteur Share Posté(e) 1 février 2013 C'est exactement la rom que je cherchais!!Encore quelques petits bug, et une autonomie moyenne mais pour 1ere build, c juste énorme!!!! Héhé :) tu as changer de kernel ? Envoyé depuis mon Transformer TF101 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 1 février 2013 Auteur Share Posté(e) 1 février 2013 Génial le ISAS sur lmt... Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 Génial le ISAS sur lmt... Envoyé depuis mon Galaxy Nexus avec Tapatalk Kezako? depuis mon nExUs pRiMe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Crackmort Posté(e) 1 février 2013 Share Posté(e) 1 février 2013 J'espère que c'est pas " Institute of Space and Astronautical Science " ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 1 février 2013 Auteur Share Posté(e) 1 février 2013 Kezako? depuis mon nExUs pRiMe Les gestes invisibles Tu choisi l'action pour un slide au 8 coins du tel Par ex, en bas a droite, tu slide en diagonale et tu met l'action Recent etc... A tester... Envoyé depuis mon Transformer TF101 avec Tapatalk Invisible Swipe AreaS Envoyé depuis mon Galaxy Nexus avec Tapatalk 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
napster_666 Posté(e) 6 février 2013 Share Posté(e) 6 février 2013 Nouvelle version disponible ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 6 février 2013 Auteur Share Posté(e) 6 février 2013 Build2 qui n'apporte pas grand chose... Envoyé depuis mon Transformer TF101 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 6 février 2013 Auteur Share Posté(e) 6 février 2013 (modifié) Build3 :-) Build 3: MD5: 630CEE4F1E5CBA2F19A08F7063303E64 SHA1: 287C7BA59E690CBE18EC8BD01C0A34680DB41AF6 Quote: Merged android-4.2.1_r1.2 (JOP40G) Kernel: Sound control - Ezekeel SLQB - Ezekeel SIO Sched - Ezekeel fsynccontrol - Ezekeel FastCharge - Chad Froubel PackageManager: Restrict system packages to protected storage Framework - SystemUI: LastApp Toggle SystemUI: respect global vibrate settings in the statusbar Fixed FastCharge toggle Volume button cursor control Fix left over glow Frameworks Audio/Video: Merge upstream with CAF Frameworks telephony: Merge upstream with CyanogenMod Policy: Fixed potential NPE Phone: Updated call parameters Contacts: Fixed potential NPE Fix threads running after entering call log, possibly affecting battery life Allow quick pre-selection of filter range Cleanup code and make call data processing asynchronous Fix display of missed calls when filtering for call type and sorting by count Wpa supplicant: Fix regression in LEAP Settings: Fixed random tab title Deleted non working clock color option (PA Colors controls it anyways) CMFileManager: Merge upstream with CyanogenMod LockClock: Merge upstream with CyanogenMod Envoyé depuis mon Transformer TF101 avec Tapatalk Modifié 7 février 2013 par Billouetaudrey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SouSouleBarbu Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Hummmm, ça me semble intéressant tout ça... Vous l'utilisez tous les jours? La batterie tient bien? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 7 février 2013 Auteur Share Posté(e) 7 février 2013 (modifié) Hummmm, ça me semble intéressant tout ça... Vous l'utilisez tous les jours? La batterie tient bien? Merci Oui je l'utilise tous les jours, sous leankernel bonne batterie, aujourd'hui je test avec kernel de base;-) Envoyé depuis mon Galaxy Nexus avec Tapatalk Modifié 7 février 2013 par Billouetaudrey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SouSouleBarbu Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Merci, jveux bien que tu nous fasse un retour d'ici qq jours ac le kernel de base stp. Merci! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
napster_666 Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 La pie est elle integré dans la build 3 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 7 février 2013 Auteur Share Posté(e) 7 février 2013 La pie est elle integré dans la build 3 ? Nope mais lmt marche très bien... Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 7 février 2013 Auteur Share Posté(e) 7 février 2013 Merci, jveux bien que tu nous fasse un retour d'ici qq jours ac le kernel de base stp. Merci! No soucis, je dis ca samedi :-) Envoyé depuis mon Transformer TF101 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 9 février 2013 Auteur Share Posté(e) 9 février 2013 Jour 1 : 22h pour 2h d'écran Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
