napster_666 Posté(e) 7 février 2013 Share Posté(e) 7 février 2013 Description Please report any bugs to me in this thread/PM with a logcat or detailed description of what caused the error. All credits go the the Rootbox team. Original thread here: http://forum.xda-developers.com/show....php?t=1898798 RootBox Description Vanilla RootBox is built straight from RootBox sources and always carries a very light installation with no extra/useless apps. This means, you can enjoy a pure Android experience combined with AOKP/CM features and some CM cherry-picks. Keep in mind Jelly Bean is only at the beginning stage of development and there will be minor bugs. Every RootBox releases are stable and always up to the challenge for a daily usage. I personally have a high standard when it comes to releases and this is why this project always meets the expectations of users. If you're wondering how this ROM differs from any other AOKP roms out there, I only have one thing to say: Try it yourself and choose the one that meets your requirements. Features * Based on JB 4.2.1- Built from RootBox Sources * AOKP Features * CM Profiles * Per App DPI * Per App Tablet UI * Per App Language * Navigation Bar Colour * Lockscreen vibration option * Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting) * Phone: Noise Suppression * MMS: Message rate alerts (Modify SMS message limit for alert) * MMS: Fully Customizable MMS Theme * MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line) * Option to control cursor in text fields using volume keys * Home button call answer (Accessibility Option) * Variable size pattern lockscreen * RootBox Settings including: ** Lockscreen Shortcuts (Paranoid) ** Expanded Desktop ** LockClock (Chronus) ** Screen Security Features (Unlock options) Recommended Installation Steps Coming from another Custom ROM: 1. Wipe Data/Factory Reset 2. Flash RootBox zip 3. Flash JB GAPPS - http://goo.im/gapps/gapps-jb-20121212-signed.zip 4. Wipe Dalvik Cache 5. Reboot Coming from stock ROM: 1. Root Phone 2. Wipe Data/Factory Reset (This does not affect your Internal/External storage) 3. Flash RootBox zip 4. Flash JB GAPPS - http://goo.im/gapps/gapps-jb-20121212-signed.zip 5. Wipe Dalvik Cache 6. Reboot Upgrading RootBox versions: 1. Download RootBox update 2. Flash RootBox update 3. Flash JB GAPPS - http://goo.im/gapps/gapps-jb-20121212-signed.zip 4. Wipe Cache (Optional) 5. Wipe Dalvik Cache (Optional) 6. Reboot RootBox Sources www.github.com/Root-Box Included Kernel imoseyon Leankernel v5.8 from here: http://rootzwiki.com/topic/13299-ker...l-47-58-11712/ Download Get it from here: http://d-h.st/nmN Old builds Build 1: http://d-h.st/tgu Build 2: http://d-h.st/kpM Build 3: http://d-h.st/BWS Build 4: http://d-h.st/57P Build 5: http://d-h.st/z8I Changelog Any noteworthy changes will be included in the 2nd post. Bugs * Don't know this is the first build * AOKP/CM BUGS Donations * bajee11 * CM * AOKP Credits/Thanks To: * AOKP * Teamhacksung * The CyanogenMod Project * rovo89 - For his excellent work on Xposed Framework * Paranoid Android * Rodries * Pier * BigDenn - Logo, bootanimation and wallpapers Source : XDA Lien vers le commentaire Partager sur d’autres sites More sharing options...
cyrille2b Posté(e) 11 février 2013 Share Posté(e) 11 février 2013 bonne rom basée sur l'aokp, avec une touche de cm et de parandroid... pie est intégré aussi a la rom enfin une rom bien complète sur la customisation, j’adhère .. seul défaut pour moi pgm qui ne fonctionne pas avec le kernel de base, le tel bug direct et un bon redémarrage s'ensuit... Lien vers le commentaire Partager sur d’autres sites More sharing options...
