Nojito Posté(e) 13 mars 2013 Share Posté(e) 13 mars 2013 (modifié) Changelog: 1.5 beta Hardware key remapping/disable added manta support Phone/Phablet/Tablet UI modes d2 fixes across the board Huge system core revamp (credit nocoast) Navbar options (credit winner00) new framework based bootani Features: Here are just a few of our features: Android 4.2.2 PIE Xposed Framework (May cause stability or performance issues - use at your own risk!) Comprehensive speed enhancements, including Linaro -O3 and processor-specific optimizations Unofficial Voodoo Sound support on Note 2 and i9300 devices. Option to hide lockscreen hints Carousel lockscreen Customizable lockscreen buttons and sliders Chronus clock widget Customizable hardware and software keys Transparent navbar and status bar Customizable navbar ring Navbar arrow keys Navigation bar widgets Customizable power menu Notification power widget Notification brightness adjustment Customizable quicksettings panel Statusbar mods including center clock and color LCD Density Theme engine Quiet hours Volume rocker music controls Full Rotation Customizable battery and notification light More that haven't even been mentioned, and more to come! Changelog de la v1.6 : -We've fixed PIE! It no longer decides to be invisible from time to time. -We fixed the battery charge light! None of us use it but apparently you guys are just nuts for it! -Dark Carbon! Huge props to Slim Roms for coming up with this unique and awesome feature. -Lockscreen theming -CM skinny battery is back! -Volume key lock on silent mode option -Backup tool - if you're flashing a new version of Carbon and already have the required version of gapps installed, it will be backed up and restored during install. This applies to system apps and custom host files as well. Please note that you should only dirty flash from Carbon to Carbon. It's ok if it's another version or a nightly - just not over other roms. Super handy for you crack flashers. Make sure you've got the most recent Gapps though, and if you're flashing from a factory reset, you'll still need to install it after install of course. -Long pressing the "clear recents" button clears the cache -3.4 kernel on D2xxx devices. It's finally stable enough where we're comfortable with this - remember to only flash other 3.4 kernels or it will not boot as there are rom-level dependencies. -AOKP's awesome new navbar settings -NFC polling mode for when you want to keep your screen off and scan tags -MMS and call "breathe" feature. Makes the notification icon fade in and out. -Mute dings when changing volume -Disable/enable CRT effect on screen on/off. -3rd party keyboard bug fixed -deodexed again -stability and speed enhancements -a million other little things as well - we basically don't even sleep anymore. Screenshots: Version nightly : http://goo.im/devs/c.../maguro/nightly Version Stable : http://goo.im/devs/carbon/maguro/release Installation : Recovery Wipe all Flash ROM Flash gapps Reboot Mise a jour: Recovery Flash ROM Flash gapps Wipe cache et dalvik/cache Reboot Source XDA : http://forum.xda-dev...d.php?t=2136851 Modifié 8 mai 2013 par Nojito 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
José Pascual Posté(e) 13 mars 2013 Share Posté(e) 13 mars 2013 Attention, tu t'es trompé dans le lien xda, celui que tu as posté va vers Paranoid. Le bon est celui là : http://forum.xda-developers.com/showthread.php?t=2136851 Sinon j'avais vu ce topic dans la semaine, cette ROM m'a fait un peu de l'oeil, mais je pense que je vais passer mon chemin, je ne peux plus vivre sans dpi changer par application. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dav59300 Posté(e) 13 mars 2013 Share Posté(e) 13 mars 2013 Changelog: 1.5 beta Hardware key remapping/disable added manta support Phone/Phablet/Tablet UI modes d2 fixes across the board Huge system core revamp (credit nocoast) Navbar options (credit winner00) new framework based bootani Features: Here are just a few of our features: Android 4.2.2 PIE Xposed Framework (May cause stability or performance issues - use at your own risk!) Comprehensive speed enhancements, including Linaro -O3 and processor-specific optimizations Unofficial Voodoo Sound support on Note 2 and i9300 devices. Option to hide lockscreen hints Carousel lockscreen Customizable lockscreen buttons and sliders Chronus clock widget Customizable hardware and software keys Transparent navbar and status bar Customizable navbar ring Navbar arrow keys Navigation bar widgets Customizable power menu Notification power widget Notification brightness adjustment Customizable quicksettings panel Statusbar mods including center clock and color LCD Density Theme engine Quiet hours Volume rocker music controls Full Rotation Customizable battery and notification light More that haven't even been mentioned, and more to come! Screenshots: Version nightly : http://goo.im/devs/c.../maguro/nightly Version Stable : http://goo.im/devs/c...n/maguro/stable Gapps 4.2: http://goo.im/gapp Installation : Recovery Wipe all Flash ROM Flash gapps Reboot Mise a jour: Recovery Flash ROM Flash gapps Wipe cache et dalvik/cache Reboot Gapps 4.2: http://goo.im/devs/carbon/extras Source XDA : http://http://forum....d.php?t=2136851 simpa mais pour quel samrphone ou tablette Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
aureldelp Posté(e) 13 mars 2013 Share Posté(e) 13 mars 2013 vu que l'on est sur le topic Nexus à mon avis c'est pour .............................................. le Nexus....... mais je peux me tromper.............. 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 13 mars 2013 Share Posté(e) 13 mars 2013 vu que l'on est sur le topic Nexus à mon avis c'est pour .............................................. le Nexus.......mais je peux me tromper.............. Pas pour iphone plutôt ? OK je sors ;-) Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 13 mars 2013 Auteur Share Posté(e) 13 mars 2013 (modifié) Attention, tu t'es trompé dans le lien xda, celui que tu as posté va vers Paranoid. Le bon est celui là : http://forum.xda-dev...d.php?t=2136851 En effet, et je m'en excuse. Voilà c'est changer. Sinon, même si le kernel d'origine marche bien. Je suis depuis 2 jours sur AK Purity v30. L'autonomie semble encore meilleure. Lien : http://forum.xda-dev...d.php?t=1883298 Modifié 13 mars 2013 par Nojito Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 15 mars 2013 Auteur Share Posté(e) 15 mars 2013 Sinon j'avais vu ce topic dans la semaine, cette ROM m'a fait un peu de l'oeil, mais je pense que je vais passer mon chemin, je ne peux plus vivre sans dpi changer par application. Je viens de remarquer que le réglage du dpi par application est présent. Cette rom est vraiment très complète en personnalisation ! Je te conseil de la tester. Par contre je ne sais pas ce qu'est le dpi. Si tu pouvais m'expliquer sont utilité en quelques mots. Je t'en remercie d'avance. Tapatalké depuis mon Nexus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
José Pascual Posté(e) 15 mars 2013 Share Posté(e) 15 mars 2013 (modifié) Pour parler grossièrement, ça change la "taille" de l'appli à l'écran. Par exemple quand tu ouvres tes sms, tu vois 6 conversations d'un coup d'oeil (chiffre totalement arbitraire), tu peux changer cette taille pour en voir plus. Perso je trouve ça vachement utile sur le Google Play Musique (vu le nombre d'artistes que j'ai, je dois glisser mon doigt je sais pas combien de fois sur l'écran pour arriver tout en bas si je change pas le dpi) ou pour Chrome. Modifié 15 mars 2013 par Seosamh Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 15 mars 2013 Share Posté(e) 15 mars 2013 C'est avec le xposed le dpi par app ? Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 16 mars 2013 Auteur Share Posté(e) 16 mars 2013 (modifié) Merci pour l'explication :rolleyes: C'est avec le xposed le dpi par app ? Envoyé depuis mon Galaxy Nexus avec Tapatalk Oui c'est bien ça. Tapatalké depuis mon Nexus. Modifié 16 mars 2013 par Nojito Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tom Lee Posté(e) 1 avril 2013 Share Posté(e) 1 avril 2013 Mise à jour! Version 1.6!!! :D http://goo.im/devs/carbon/maguro Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 4 avril 2013 Auteur Share Posté(e) 4 avril 2013 Changelog de la v1.6 :-We've fixed PIE! It no longer decides to be invisible from time to time. -We fixed the battery charge light! None of us use it but apparently you guys are just nuts for it! -Dark Carbon! Huge props to Slim Roms for coming up with this unique and awesome feature. -Lockscreen theming -CM skinny battery is back! -Volume key lock on silent mode option -Backup tool - if you're flashing a new version of Carbon and already have the required version of gapps installed, it will be backed up and restored during install. This applies to system apps and custom host files as well. Please note that you should only dirty flash from Carbon to Carbon. It's ok if it's another version or a nightly - just not over other roms. Super handy for you crack flashers. Make sure you've got the most recent Gapps though, and if you're flashing from a factory reset, you'll still need to install it after install of course. -Long pressing the "clear recents" button clears the cache -3.4 kernel on D2xxx devices. It's finally stable enough where we're comfortable with this - remember to only flash other 3.4 kernels or it will not boot as there are rom-level dependencies. -AOKP's awesome new navbar settings -NFC polling mode for when you want to keep your screen off and scan tags -MMS and call "breathe" feature. Makes the notification icon fade in and out. -Mute dings when changing volume -Disable/enable CRT effect on screen on/off. -3rd party keyboard bug fixed -deodexed again -stability and speed enhancements -a million other little things as well - we basically don't even sleep anymore. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bahahmed91 Posté(e) 19 avril 2013 Share Posté(e) 19 avril 2013 hello there, this rom seems craaziii :) lov the screen.. but i can't install it on my gtab p1000... pliz hellllp :mellow: ... thx euuuhhh... dzl pr les non-anglofone.. je vlai dir ke jariv pa a installer cett rom sr ma gtab p1000.. les models sont bien le nexus et le p1000 nespa.. svp aidé moiiii... ell matir trooooo :emo_im_money_mouth: .. lool Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 19 avril 2013 Share Posté(e) 19 avril 2013 hello there, this rom seems craaziii :) lov the screen.. but i can't install it on my gtab p1000... pliz hellllp :mellow: ... thxeuuuhhh... dzl pr les non-anglofone.. je vlai dir ke jariv pa a installer cett rom sr ma gtab p1000.. les models sont bien le nexus et le p1000 nespa.. svp aidé moiiii... ell matir trooooo :emo_im_money_mouth: .. lool Premièrement apprend a écrire correctement...... Deuxièmement c'est pour un Gnex pour ton bouzin va en section approprié. depuis mon pHoNe 5 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 28 avril 2013 Auteur Share Posté(e) 28 avril 2013 (modifié) Quelques ajout sympa dans les dernières nightly. - Ajout des lockscreen ribbons. - Ajout des notifications ribbons. - Ajout des quick settings ribbons. - Ajout des AOKP swipe ribbons. - Ajout d'un menu "Hybrid". Avec les paramètres de PARANOID ANDROID. Elle est de plus en plus parfaite cette rom :) Modifié 28 avril 2013 par Nojito 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 28 avril 2013 Share Posté(e) 28 avril 2013 (modifié) C'est quoi les ribbons :) Edit ; j'ai installer la Nightly 2804, et je n'ai pas Hybrid ? ... Envoyé depuis mon Transformer avec Tapatalk Modifié 28 avril 2013 par Billouetaudrey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 28 avril 2013 Auteur Share Posté(e) 28 avril 2013 (modifié) Les ribbons sont des raccourcis. J'ai la dernière experimental du 27, et j'ai le menu hybrid. Regarde dans les paramètres principaux, pas dans les paramètres Carbon. Je vais mettre la 28, et je reviens vers toi. ;) Sinon je suis passé au fancy kernel, ça roxe plutôt pas mal :P Modifié 28 avril 2013 par Nojito Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 28 avril 2013 Share Posté(e) 28 avril 2013 L'hybrid a été enlever sur la 28 ... Bug et Lag apparemment .. Merci pour les Ribbons ;) Ok pour fancy, perso je tourne soit sur Butter Kernel soit sur AK... Envoyé depuis mon Transformer avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jrb95 Posté(e) 29 avril 2013 Share Posté(e) 29 avril 2013 Les ribbons sont des raccourcis. J'ai la dernière experimental du 27, et j'ai le menu hybrid. Regarde dans les paramètres principaux, pas dans les paramètres Carbon. Je vais mettre la 28, et je reviens vers toi. ;) Sinon je suis passé au fancy kernel, ça roxe plutôt pas mal :P As-tu essayé le AK070 ? c'est avec que j'obtiens les meilleures perf. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 29 avril 2013 Auteur Share Posté(e) 29 avril 2013 (modifié) L'hybrid a été enlever sur la 28 ... Bug et Lag apparemment ..Merci pour les Ribbons ;) Ok pour fancy, perso je tourne soit sur Butter Kernel soit sur AK... Envoyé depuis mon Transformer avec Tapatalk Merci pour l'info sur l'instabilité. J'ai le même problème qu'un gars sur xda, impossible de flasher 28. Il reste éternellement sur le bootanimation. Même en repassant sur une stable, la 28 veut pas. Je dois sûrement faire un full wipe, je verrais ca ce soir. Tapatalké depuis un Nexus As-tu essayé le AK070 ? c'est avec que j'obtiens les meilleures perf. J'ai pas mal tourner sur AK, et dernièrement sur Rubik. J'ai voulu tester fancy car j'ai trouvé les réglages complet d'un gars sur xda. Quels sont tes réglages sur AK070 ? Tapatalké depuis un Nexus Voici le lien vers les réglages fancy kernel : http://forum.xda-developers.com/showthread.php?t= Tapatalké depuis un Nexus Modifié 29 avril 2013 par Nojito Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 29 avril 2013 Share Posté(e) 29 avril 2013 Je suis retourné sur la Domination ... plus fluide et l'hybrid est présent ;) Envoyé depuis mon Transformer avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jrb95 Posté(e) 29 avril 2013 Share Posté(e) 29 avril 2013 Merci pour l'info sur l'instabilité. J'ai le même problème qu'un gars sur xda, impossible de flasher 28. Il reste éternellement sur le bootanimation. Même en repassant sur une stable, la 28 veut pas. Je dois sûrement faire un full wipe, je verrais ca ce soir. Tapatalké depuis un Nexus J'ai pas mal tourner sur AK, et dernièrement sur Rubik. J'ai voulu tester fancy car j'ai trouvé les réglages complet d'un gars sur xda. Quels sont tes réglages sur AK070 ? Tapatalké depuis un Nexus Voici le lien vers les réglages fancy kernel : http://forum.xda-dev...owthread.php?t= Tapatalké depuis un Nexus Réglages d'origine. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 29 avril 2013 Auteur Share Posté(e) 29 avril 2013 Ok, je te tiendrais au courant de l'évolution du mode hybrid sous carbon. Vu la réactivité des dev, c'est pour bientôt. Personnellement, je ne l'avais même pas tester, ça ne m'intéresse pas. Sinon je serais déjà sous Paranoid :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nojito Posté(e) 29 avril 2013 Auteur Share Posté(e) 29 avril 2013 Réglages d'origine. Je suis repasser sous AK. J'ai trouvé ces réglages sur Xda qui vont plutôt bien. Je te laisse tester B) ROM: Carbon ROM Nightly from the 29th of April Kernel: AK Diamond v225 TCP Congestion Control: Westwood Governor: Interactive Max freq: 1200 Min freq: 350 Max Screen Off: 700 Max Screen On 350 Modifications: - Temperature throttle on 80 - Vibration down to 100 - Battery extender to 97 - Content Adaptive Brightness On - Multicore Powersaving to 0 - Dynamic FSYNC disabled - Min SmartReflex: 700 Scheduler: CFQ @ 512 Colour: franco settings Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 4 mai 2013 Share Posté(e) 4 mai 2013 Carbon 1.7 dispo. depuis mon pHoNe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
