[ROM] Xperia Retsu 4.0.4
Salut.
Je partage ma trouvaille : une ROM style Xperia pour le clone du WCS, le MyPhone A848i Duo. Elle tourne sous ICS (logique en même temps)
Seul inconvenient : faut installer la ROM en restaurant une sauvegarde avec CWM.
Je suis en train de la tester et elle fonctionne pas trop mal pour le moment :)
http://www.pinoyden....?topic=250489.0
522551_495507700485992_443517576_a.jpg562311_499508146752614_1778005604_a.jpg577031_499508113419284_1678261428_a.jpg
Based on Alpha Rom v1.4 by Jade Dupaya
Features:
-Zipaligned apk's
-Modified stock kernel w/ init.d support
-Custom logo
-Custom boot animation
-Edited icon pack
-Removed some bloatwares
-Alpha tweaks
What's New?
-Xperia Z Launcher
-Xperia Icons
-Xperia like Settings with wallpaper
-Xperia Widgets (Clock, Walkman, Photos, Live Weather Widget, On and Off tools, Torch, TrackID)
-Added Walkman Music App
-Added Xperia Album App (Gallery
-Added Xperia Movies App (Video Player)
-Upgraded to 8 mega pixel Camera
-Added Rom Toolbox
-Added Root Explorer
-Added Reverse Tethering App (Plug and Play -No need PC side Application)
-Added Playstation Mobile App (Sony Store)
-Added Google Chrome Browser
-Added Xplore App
-Updated SuperSU v1.25
-Injected Xperia UI Sounds and Ringtone
-Injected Bravia Engine 2
-Custom Boot logo is now SONY
-Custom Boot Animation (XPERIA T James Bond Phone)
-Improved UI & Stability
-Injected CrossBreeder (better than Seeder)
-Added Playstation Emulator (Fpse) download http://db.tt/s61aY35s (BIOS)
-Already Extended Data Repartitioned (2.5GB Internal User memory)
-Can Transfer apps to SD via settings - apps - choose application - move to phone memory (MicroSD)
-Clean Rom & Lightweight (Removed some bloatwares)
-Improved battery consumptioned from previous Rom (Xperia Nexus v1)
-Sony Like Status bar icons (battery, Wifi, Signal, Network Data) *Note for Blue and Green Sim colos Only.
*some apps are Disabled such as Facebook and Maps, to Enable them go to Settings-Apps-All-Find the app-then Select Enable
Walkman Features:
-ClearAudio+
-Sound Enchancements from Xperia
-Clear Bass
-Surround Sound (VPT)
-Clear Stereo
-Dynamic normaliser
-Very Cool Visualiser
-xLoud
*Note Disable the MusicFX in (Settings-Apps-All-MusicFX-Disable) You dont it.
CrossBreeder Features:
-Reduce Lag (same as Seeder)
-No Application (Automatic)
-DNS Speed up (Improved Browsing Speed)
-Tether Boost
-Clean Adblock
-Doesn't Consume battery like the Old Seeder App on Xperia Nexus Rom
Instructions:
Your Rom must be Extended data Repartioned before Restoring this ROM
Go here:
http://www.facebook....48751265288256/
1.) Download and Extract the file (clockworkmodXperia.zip) to "Root Folder" on SDcard.
2.) Turn off your Device and Enter recovery Mode. (Volme up + Volume down + Power Button)
3.) On the Clockworkmod Recovery Select "Back up and restore".
4.) choose "Restore" date 2013-03-11.
5.) Reboot your device! Don't wipe data/ Factory Reset
Download Link:
http://depositfiles....files/y6xa1g7in
l installation de cette ROM semble différente... pas trop bien compris la maniere de faire j aimerais pourtant la tester pour utiliser autre chose que la stock wiko...et comparer
Il faut avoir le recovery clockworkmod. Tu décompresses le fichier et copies le dossier clockworkmod à la racine de ta carte sd. Tu cliques sur fusionner et remplacer si ils te demandent. Ensuite dans le recovery tu vas dans backup and restore et tu fais un restore avec le fichier de backup qui était contenu dans l'archive. Enfait, c'est juste le backup qui a été fait par le mec.
Franchement la ROM n'apporte rien d'interessant...
Bon, après l'avoir utilisé pendant quelques heures, un seul truc m'a dérangé.. La connexion internet marche aléatoirement: l'icône 3G ou H est active, mais ça n'affiche rien, comme si la Data était désactivée.
Je reviens à une ROM stock, mais elle est franchement sympa.
Toutes ces applications Xperia peuvent être facilement installées manuellement. C'est bien la seule chose qu'apporte la ROM.
J'ai presque fini de la télécharger (il reste 13 minutes, c'est beau le 60ko/s ), je vous dirais ce que j'en pense :)
login -> Oh, la rom à l'air quand même d'apporter pas mal de truc aussi hein. Pas que les applis xperia même si c'est son but à la base.
Franchement, le wifi ne marche pas (testé avec le kernel donné, stock et pdroid), 3g qui saute et qui revient pas sauf si on désactive la 3G et qu'on la réactive mais elle repart 2 minutes après, l'autonomie est pas super, mais alors pas vraiment. On a certain numéro de téléphone de l'auteur, les noms de ses musiques, le nom de ses films ect... bref, pas à conseiller. :/ Dommage, car prometteuse.
Je ne la testerai pas pour la semaine, je n'arrive pas à avoir de la 3g (je suis chez Free)
Très belle rom, mais pas optimisé pour le WCS ^^
Vérifie tes apn, moi j'étais configuré sur Orange Entreprise et non Orange Internet (exemple pour sosh)
On dirait que les avis sont partagés sur cette rom ...est ce qu'il y a vraiment des soucis techniques pour les trucs essentiels 3G , WIfi ? ou bien ce sont des réglages mal effectués?
Je tenterais bien le test pour voir de par moi- meme mais tout a l'heure impossible de la telecharger ....je reessaie plus tard .
Merci pour vos retours ...
Non, sa supprime pas les autres backup, mais copie les sur l'ordi au cas où. :)
En tout cas, je n'ai pas de wifi (capte la box, demande le mot de passe ect... mais après marque désactivé et ne veux pas se connecter) la 3g marche puis ne marche plus alors que le logo 3g est encore la je suis obligé de la désactiver et la réactiver... :/ Dommage, car très fluide et sympa comme rom :)
i
Mes APN sont correctement configurés, mais la Data sautait aussi toutes les deux minutes.
La ROM est assez belle, très fluide, le launcher Xperia (bien que gourmand) aussi, mais effectivement, certains problèmes sont gênants. Ne pas oublier que cette ROM est faite pour un "clone" du Slim, pas pour le Slim. :)
A voir si sur la page Facebook, il y a des mises à jour, je crois que la 1.4 est sortie.
Bon après pour la data, je ne peux pas dire je suis sur le forfait 2€ :P
Nouvelle version il me semble (à confirmer):
  • New Xperia Launcher with settings
  • Revamp User Interface
  • Added more Xperia Status bar Icons
  • Added More Xperia Widgets
  • Fix Google Play issue from previous version
  • 8.0 Mega Pixels Camera with Improved Auto Focus Accuracy and Improved HDR Camera setting for Low Light and improved dynamic range (more details in shadow areas)
  • Different Version of Walkman Music App
  • Added A919 Tool (thanks to A919 Group)
  • Improved Stability
  • Added One Battery Saver from XDA (For those who want battery saving app)
Deux liens dispo:
http://uploaded.net/file/htcba178
http://depositfiles....files/yzpv9w05p
Xperia Boot Logo:
http://db.tt/1DPffcnw
*Note Flash thru CWM
Le tout vu sur: https://www.facebook...ps/myphonea848/
Modifié par Francois53
