gui3gui Posté(e) 12 avril 2013 Share Posté(e) 12 avril 2013 (modifié) Avant tout propos, ni moi ni le forum ne peuvent être responsables des désagréments qui puvent vous arriver ! [Rom] JB 4.2.2 Jellybam v7.5 A propos :Bonjour comme demandé par certains voici le topic de la jellybam v7.4 disponible depuis quelques jours et tournant sous JB 4.2.2 (Si, si! ;) )C'est une rom AOKP et paronoid; c'est à dire qu'elle est basée sur les sources de cyanogen et permet en outre de choisir le dpi de chaque application. Changelog : JELLYBAM Project name: android_build.igio90 – Cleanup!.igio90 – Revert “build/core: Build in ISOC++11 mode if possible”.Eugene San (eugenesan) – fix graphite optimization support.nocoast – Added more of the original linaro optimizations to default.Daniel MM – Carbon power.franco-c – Don’t build emulator.aaronpoweruser – Graphite optimizatoin flags.aaronpoweruser – Make gcc 4.6 default and non O3.Bernhard Rosenkraenzer – build/core: Build in ISOC++11 mode if possible.Steve Spear – Add strict_aliasing..Stevespear426 – GCC 4.7 O3 and aliasing Optimizations.Stevespear426 – Use GCC 4.7 from google.Nick Kralevich – x86: enable FORTIFY_SOURCE.Ben Cheng – Export TARGET_GCC_VERSION as an env variable..Ben Cheng – [ARM] Extend the usage of TARGET_GCC_VERSION for gdb and arm-eabi-*..Andrew Hsieh – Add TARGET_GCC_VERSIONJELLYBAM Project name: android_frameworks_native.igio90 – Revert “Merge commit ‘fb5cb4e’ into bam6-pyramid”.Bernhard Rosenkraenzer – frameworks/base: Make sure Singleton instantiations are exportedCyanogenMod Project name: android_frameworks_av.Haynes Mathew George – libstagefright: Squashed audio fixes from CodeAurora.Steve Kondik – Silence error when DASH player isn’t presentJELLYBAM Project name: android_frameworks_base.igio90 – FIx: PhabletUI NavBar in landscape.igio90 – services: don’t clear wallpaper when SystemUI disconnects. When we restart SystemUI (or the user), sometimes the wallpaper would get cleared. This patch just captures its originating component and if that is our SystemUI component, ignore the event. Change-Id: I3e159dc2c013e7d7e552e3c0cef55e3ab970ca87.Ian Rogers – Recognize odex files in memory accounting..Elliott Hughes – Remove the fixed-length buffer in DdmHandleNativeHeap.getLeakInfo..PrimeDirective – remove hardcoded -fno-strict-aliasing from F/B/core/jni.Nick Kralevich – convert jint to uint32_t..You Kim – StringBlock_nativeCreate: Possible Leak.You Kim – Leak in ToneGenerator_native_setupJELLYBAM Project name: android_vendor_htc.igio90 – RUBY Everywhere.Dorian Snyder – shooter/shootervm: don’t copy thermald and mpdecision.igio90 – we need libDxOAF for jewel too!.igio90 – Moving libDxOAF to the right placeJELLYBAM Project name: jellybam_vendor.igio90 – Fix pa prefs icons.igio90 – OMG!.igio90 – N8000: various fixes Signed-off-by: igio90.igio90 – N8000 fix dependencies Signed-off-by: igio90.igio90 – Mako: Track paranoidandroid kernel Signed-off-by: igio90.igio90 – p4 and p4wifi Signed-off-by: igio90.igio90 – Updating tf300t and tf700t pa overlays Signed-off-by: igio90.igio90 – BAMModder: New touchwiz and samsung keyboard (2/2).igio90 – r950 aka US Cellular Note 2.igio90 – Ace and ruby.. where? everywhere! Signed-off-by: igio90.igio90 – Bump to 7.4.igio90 – tf700t and tf300t fixup.igio90 – su640: typo everywhere.igio90 – su640: the right branch :S.igio90 – su640 dependencies.igio90 – p5110: fix typo.igio90 – Pyramid: Manifest and dependencies.igio90 – Tracking new libhardware for shooter*.igio90 – typo.igio90 – Custom frameworks av and native for shooter builds.igio90 – We should use their camera and gallery!.igio90 – Tracking all shooter device tree.igio90 – Shooteru/vm: fix typo Signed-off-by: igio90.igio90 – Shooteru, Shootervm and initial su640 Signed-off-by: igio90.igio90 – cleanup.igio90 – n800, p920, tf300t and tf700t custom device track Signed-off-by: igio90.igio90 – Shooter: i need to sleep a bit more.igio90 – Shooter: Another typo fix.igio90 – Revert “Shooter: Moving libhardware-legacy to dependencies”.igio90 – Shooter: Moving libhardware-legacy to dependencies.igio90 – Fix typo.igio90 – Shooter: cleanup.igio90 – Ville: derp.igio90 – Shooooooter final manifest and deps Signed-off-by: igio90.igio90 – Shooter everywhereCyanogenMod Project name: proprietary_vendor_samsung.Steve Kondik – Revert “d2: Update Adreno driver”.Steve Kondik – Add t0lteatt/t0ltetmo blobsJELLYBAM Project name: platform_manifest.igio90 – Tracking own recovery.igio90 – Tracking own trebuchet.igio90 – missing remote.igio90 – We need this for gcc 4.7.igio90 – Moving custom devices to vendors depsJELLYBAM Project name: platform_manifest.igio90 – Tracking own recovery.igio90 – Tracking own trebuchet.igio90 – missing remote.igio90 – We need this for gcc 4.7.igio90 – Moving custom devices to vendors depsCyanogenMod Project name: jellybam.igio90 – Added r950 to the toolchain.igio90 – Pyramid: we can buil it up in the chain! yeah.igio90 – su640: build with toolchain.igio90 – Build shooter, shooteru and shootervm with toolchain.igio90 – Updating release scriptsJELLYBAM Project name: android_bootable_recovery.Domenico – First BAM modded image (experimental)JELLYBAM Project name: android_packages_apps_Calculator.DelPETER – Calculator : reorganize and add french translation.Ondrej Zima – Czech: fixed tranlation, fixed string order, added missing and fixed order again.Michael Bestas – Calculator: Reorganize Greek translationsCyanogenMod Project name: android_packages_apps_DSPManager.Michael Bestas – DSPManager: Reorganize Greek translationsJELLYBAM Project name: android_packages_apps_DeskClock.Andrew Jiang – DeskClock: Simplified Chinese Translations.Andrew Neal – Add empty view when no alarms are set.djMesias – es_ES: Add spanish translation.Tamás Tóth – Added hungarian translation for no_alarms.tompopielarczyk – DeskClock: Update Polish language.Jacob Overgaard Madsen – DeskClock: New Danish string and adjustment.Gustavo – PT-BR: Update translations.xavihernandez – DeskClock: update French translation.pvolkov – Update Russian Translation-DeskClock-CM10.1.isimobile – Afrikaans translations: Added missing items.Danny Baumann – Update German translation..Marco Brohet – DeskClock: NL translations.Francesco – DeskClock: Update italian translation.Ondrej Zima – Czech: added missing strings, changed translation strings order.Takuo Kitame – DeskClock: update Japanese translation.Michael Bestas – DeskClock: Reorganize Greek translationsJELLYBAM Project name: android_packages_apps_Calendar.Marco Brohet – Calendar: NL translations.DelPETER – Calendar : add french translation.Michael Bestas – Calendar: Reorganize Greek translationsJELLYBAM Project name: android_packages_apps_Settings.igio90 – Port forward: Lockscreen camera widget on/off Signed-off-by: igio90.igio90 – BAMModder: New touchwiz and samsung keyboard (1/2).igio90 – Call our helpers!.igio90 – HoloBam: Restart trebuchet on toggle change (1/2).igio90 – Typo.igio90 – Tracking the new bam-android.com website.igio90 – Restart SystemUI to change Signal/WiFi clusters when text selected.igio90 – QuickSettings : Use stock layouts / fix userTile.igio90 – ROMStats: fix up preview screen Signed-off-by: igio90JELLYBAM Project name: android_packages_apps_Email.Danny Baumann – Update German translation..DelPETER – Email : reorganize and add french translationJELLYBAM Project name: android_packages_apps_Phone.igio90 – String update and cleanup Signed-off-by: igio90.Danny Baumann – Indicate call wait state in call title instead of only showing a toast..djMesias – es_ES: Add spanish translation.Tamás Tóth – Added hungarian translation.tompopielarczyk – Phone: Update Polish translation.rheeze – Phone: Update italian translation.Gustavo – PT-BR: Update translations.pvolkov – Update Russian Translation-Phone-CM10.1.isimobile – Afrikaans translations: Added missing items.Marco Brohet – Phone: Dutch translations.DelPETER – Phone : reorganize and add french translation.Vavooon – Fix wrong Phone captions.Quarx2k – Add support for proprietary libaudio voice quality filter.igio90 – Phone: Fixup settings NPEJELLYBAM Project name: android_packages_apps_Mms.igio90 – String cleanup Signed-off-by: igio90.djMesias – es_ES: Update spanish translations.Gustavo – PT-BR: Update translation.tompopielarczyk – MMS: Update Polish language.Vladimir Belkov – Update Russian translation: Mms.Tamás Tóth – Added hungarian translation.DelPETER – Mms : reorganize and add french translation.Francesco – Mms: Update italian translation.DvTonder – Mms: Updated ‘Mark as read’ notification action iconJELLYBAM Project name: android_packages_apps_Camera.djMesias – es_ES: Add spanish translations.rheeze – Camera: Update italian translation.Michael Bestas – Camera: Reorganize Greek translations.Muhammed Nazim – Add Danish Translations.Muhammed Nazim – Add French Translations.Muhammed Nazim – Add German Translations.Konstantinas Arefjevas – Add Lithuanian Translations.Muhammed Nazim – Add Polish Translations.jt1134 – Camera: add additional picture resolutionsCyanogenMod Project name: android_packages_apps_CMFileManager.Michael Bestas – CMFM: Reorganize Greek translations.Junwen Sun – CMFM: Protect AssociationsDialog from NPECyanogenMod Project name: android_packages_apps_Browser.Michael Bestas – Browser: Reorganize Greek translationsJELLYBAM Project name: android_packages_apps_Trebuchet.Jorge Ruesga – Revert “Wallpapers update”.igio90 – Wallpapers update.drcmda – 4.2.2 cleanup.Veeti Paananen – Show the uninstall button by default when dragging from the app drawer.Matthias Bosc – Trebuchet Settings: add setDisplayHomeAsUpEnabled.Jorge Ruesga – Trebuchet: force close in dock (Trebuchet) with raised default page count.Jorge Ruesga – Trebuchet: Default workspace fixesCyanogenMod Project name: android_packages_apps_Bluetooth.Michael Bestas – Bluetooth: Reorganize Greek translations Les bugs que j'ai rescencé pour l'instant : l'horloge s'affiche en double dans la barre de notifications (sera résolu dans la version 7.5 dispo dimanche, selon le développeur)Si vous ajoutez, le toogle power dans les raccourcis vous aurez un ui has crashed, qui tournera en boucle et ne peut être résolu que par un wipe data.Pour autant, c'est très fluide et tout fonctionne, à mon sens. En outre elle est ultra personnalisable ! ;) Installer la rom; deux étapes : Pour l'installer (et je ne suis pas responsable s'il vous arrive un problème), il faut convenir comme la cromi tournant en 4.2.1, c'est à dire en flashant d'abord un nouveau TWRP : Comment installer un nouveau TWRP TF700 - OPTIONAL STEP 1 – INSTALLING TWRP 2.5 on 10.6.1.14.4Si votre tf700 posséde un bootloader déverrouillé et tourne sous la version 4.2.1 / 10.6.1.14.4 Asus Stock ROM, il est nécessaire de flasher un custom recovery comme TWRP:TWRP XDA Thread Si vous êtes déjà rooté uitlisez alors goomanager pour installer le dernier TWRP via le menu et installer le en ouvrant le scriptOU :Téléchargez le fichier Install Recovery package , extrayez le quelque part et lancez le fichier Scott's TF700T Recovery Install Tool.bat lorsque votre Tablette est connectée à votre pc sous windows.Cela devrait installer le TWRP pour vous.Install Recovery Tool DOWNLOAD TF700 - OPTIONAL STEP 2 – Je possède déjà un custom recovery installé Si votre bootloader est déjà déverouillé et que vous tournez sous une version basée sur JB 4.1.1/10.4.4.25 comme la rom CleanROM Inheritance 3.x et en outre vous avez un custom recovery installé:Il est recommandé d'installer le Bootloader Recovery suivant comme étant la manière la plus sure pour pouvoir ensuite installer Jellybam. Le fichier peut être flashé à partir de n'importe quel recovery personnalisé TF700 World Wide WW SKU Users: 10.6.1.14.4 WW Bootloader and TWRP 2.5 DOWNLOAD md5: ac21e41b1345682bef4bd09b16726961 TF700 North American US SKU Users: 10.6.1.14.4 US Bootloader and TWRP 2.5 DOWNLOAD md5: 81e40bac1906bdcb6172e236dcc5969d CELA DEVRAIT PRENDRE TOUT JUSTE 1 MINUTE POUR FLASHER ET OBTENIR UNE BARRE BLEUE COMPLETE. NE PANIQUEZ PAS! Après avoir flashé votre tabllette, elle va redémarer sous votre rom actuelle, mais vous aurez bien le nouveau recovery et TWRP installé. Source : http://forum.xda-dev...d.php?t=2223492 Flasher la jellybam Une fois le TWRP, installé il suffit de télécharger le fichier de la jellybam : http://goo.im/devs/J...inity - tf700t/ Vous faites une copie de vos sauvegardes titanium backup, sur votre ordi (j'ai eu personnellement un petit souci après l'avoir flashé d'où ma recommandation) Vous la transférez à la racine de la mémoire interne, car le nouveaur recovery ne reconnait pas la carte sd. Vous redémarrez en recovery; appui long Power + volume bas : Vous faites d'abord un wipe data, puis vous sélectionnez le fichier de la jellybam que vous flashez et vous pouvez faire un wipe dalvik + cache avant de redémarrez. Normalement vous êtes maintenant sous jellybam! ;) Source : http://www.bam-android.com Pour ma part, je l'ai flashé en partant d'une custom, après avoir flashé le nouveau TWRP, donné plus haut ; j'étais sous la Cleanrom, 3.4.7. Je n'ai pas essayé de l'installer en partant de la rom asus stock 4.2.1, donc si certains ont des retours, ils sont les bienvenus ! Je vais ajouter des captures d'écran rapidement et un petit test sous quadran ! ;)La version 7.5 est déjà annoncée pour dimanche ! ;) Modifié 16 avril 2013 par gui3gui Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mich41 Posté(e) 12 avril 2013 Share Posté(e) 12 avril 2013 Tu veux bien dire que tu l'as flashée directement à partir du CWM en étant sous CleanRom 3.4.7 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 12 avril 2013 Auteur Share Posté(e) 12 avril 2013 Tu veux bien dire que tu l'as flashée directement à partir du CWM en étant sous CleanRom 3.4.7 ? À non toutes mes confuses, je voulais dire au contraire que j'ai d'abord flasher le nouveau twrp mais en partant de la cleanrom 3.4.7. Je modifie ce que j'ai dit plus haut. Merci d'y avoir pensé ! Envoyé depuis mon ASUS Transformer Pad TF700T avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
vinceeeskater Posté(e) 13 avril 2013 Share Posté(e) 13 avril 2013 Merci pour cette rom je vais la tester, par contre pour faire une mise a jour de la rom comment tu fais car tu n'y pas expliqué ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 13 avril 2013 Auteur Share Posté(e) 13 avril 2013 Merci pour cette rom je vais la tester, par contre pour faire une mise a jour de la rom comment tu fais car tu n'y pas expliqué ? Tu télécharges la nouvelle version et tu flashes par dessus l'ancienne version. Si tu as d'autres questions n'hésite pas ! ;-) Envoyé depuis mon GT-I9100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 15 avril 2013 Auteur Share Posté(e) 15 avril 2013 La version 7.5 est disponible. Envoyé depuis mon ASUS Transformer Pad TF700T avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mich41 Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 (modifié) @gui3gui=> donc, si j'ai tout bien compris : 1 - j'installe le TWRP 2.2. 2 - je flashe cette ROM 7.5. 3 - je peux flasher derrière une de ces deux là ? CROMi-Xenogenesis 4.2: This is a true 4.2.x ROM for the TF700 with all sorts of goodies TF700 Stock Upgrade (Bootloader and 4.2.1): The newest ROM from ASUS, including 4.2.1! Car je pense que sbdags ne suivra plus les cleanrom inheritance... Modifié 16 avril 2013 par mich41 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 16 avril 2013 Auteur Share Posté(e) 16 avril 2013 En toute logique oui car pour ma part, j'ai flashé ces deux roms dans l'ordre inverse ! ;-) Envoyé depuis mon GT-I9100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mich41 Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 Oui, c'est le copier-coller, mais c'est aussi mon intention. Allez, c'est parti ! :) Autre chose avant de faire une connerie : - Le BL reste déverrouillé ? - Perd-on le root ? j'ai cru voir que non. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hdcine Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 Salut mich41, Pour ne pas faire de conneries jettes un oeil sur ce post ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 16 avril 2013 Auteur Share Posté(e) 16 avril 2013 (modifié) Pour ma part, le bl est toujours déverrouillé et le root est conservé. Après, depuis que j'ai ma tablette, je n'ai jamais fait une seule maj en ota, j'ai toujours fait en manuel ou installer des roms customs qui comprenaient la mise à jour. Sinon la v7.6 est déjà annoncée par igio ! ;-) Édit : vu que tu flashes la cromi, tu pourrais faire un fichier zip, de l'application appareil photo / caméra qui possède plein d'options sympathiques, si c'est possible bien sûr ! ;-) Envoyé depuis mon GT-I9100 avec Tapatalk Modifié 16 avril 2013 par gui3gui Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mich41 Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 Merci à gui3gui et hdcine :) TWRP puis JellyBam installés sans problème. Que je n'aime toujours pas TWRP !! Y a-t-il un moyen de supprimer ce verrou à chaque action ? La ROM 7.5.0 est bien, mais je m'attendais à plus rapide, d'après ce que j'avais lu sur un autre topic. Par contre, page de paramètres impressionnante. Suis-je obligé de passer par la Stock upgrade 4.2.1 avant d'installer la CROMI-X, puisque je suis déjà en 4.2.2 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hdcine Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 (modifié) Pour déactiver le verrou tu vas dans Settings - Screen - tu décoches Enable screen timeout ou tu augmentes le délai. Tu peux installer directement la Cromi, par contre je te conseille de faire un full wipe pour ne pas avoir de problèmes, Wipe - Advanced Wipe - cocher Dalvik Cache, System, Cache et Data. Un thème sympa pour TWRP. Modifié 16 avril 2013 par hdcine Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mich41 Posté(e) 16 avril 2013 Share Posté(e) 16 avril 2013 Super, merci pour les 2 tuyaux :) Merci pour les 2 tuyaux :) @gui3gui=> tu dois avoir un pb de carte SD, j'ai flashé depuis la microSD (ça me surprenait, alors j'ai essayé et c'est bon). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 20 avril 2013 Auteur Share Posté(e) 20 avril 2013 La version 7.6 est disponible ! ;-) Envoyé depuis mon ASUS Transformer Pad TF700T avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
managerre17 Posté(e) 8 mai 2013 Share Posté(e) 8 mai 2013 J'ai suivi le tuto, prob la tablette ne redémarre pas ( bloqué sur le logo Asus ) !!!!!!! Merci pour les retours Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
managerre17 Posté(e) 8 mai 2013 Share Posté(e) 8 mai 2013 Prob avec cette Rom , j'ai installé sans difficultés la CROMI-Xenogenesis ( pour rappel j'étais auparavant en Cleanrom 3.4.7 ( 104.4.25 wwOdex) j'ai seulement mis à jour le TWRP de V 2.4.10 en 2.5.0.0 et l'install c'est passée sans soucis la 1ére fois Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hugme Posté(e) 16 mai 2013 Share Posté(e) 16 mai 2013 Impossible d'installer jellybam pour moi, au reboot j'ai le logo ASUS qui reste. Pourtant j'ai suivi le tuto à la lettre... Quelqu'un à les mêmes symptômes ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hdcine Posté(e) 16 mai 2013 Share Posté(e) 16 mai 2013 Idem sur le S3, il semble y avoir un problème au niveau de la compilation de la rom, il faut attendre un correctif. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hugme Posté(e) 16 mai 2013 Share Posté(e) 16 mai 2013 et impossible de reinstaller la cleanrom ??? je n'y comprends rien. Ca marchait pourtant avant. J'ai accés au fastboot mais lors du flash ca marque failed. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gui3gui Posté(e) 16 mai 2013 Auteur Share Posté(e) 16 mai 2013 Pour ma part, j'ai eu quelques soucis pour installer la cromi x, sur la jellybam. J'aime beaucoup la jellybam, mais je regrettais certaines fonctions disponibles sur la cromi. Dans mes souvenirs pour y parvenir, j'ai fait un wipe data, puis j'ai flashé le twrp, alors qu'il était déjà installé puis la cromi, en espérant aider ! ;-) Envoyé depuis mon ASUS Transformer Pad TF700T avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hdcine Posté(e) 16 mai 2013 Share Posté(e) 16 mai 2013 Sinon fais un full wipe, dans Wipe - Advanced Wipe - cocher Dalvik Cache, System, Cache et Data. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hugme Posté(e) 16 mai 2013 Share Posté(e) 16 mai 2013 Rien à faire, j'ai essayé toutes vos manip, mais le résultat est toujours le même : "fail". Je vais essayer avec d'autres versions, mais ca sent le retour sav... Merci dans tous les cas pour votre aide. Finalement c'est bon j'ai pris la version odex de cleanrom, je n'ai pas compris pourquoi la deodex ne passe pas. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hdcine Posté(e) 17 mai 2013 Share Posté(e) 17 mai 2013 Ton fichier doit être corrompu, essayes de le re-télécharger. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
manga3 Posté(e) 27 mai 2013 Share Posté(e) 27 mai 2013 Bonjour, je suis en 4.1.1/10.4.4.25 CleanROM Inheritance, tablette unlocked, j'ai installé le bootloader 10.6.1.14.4 WW Bootloader and TWRP 2.5, puis jellybam 7.8.0 dernier jus comme indiqué sur le tuto.... le problème c'est que la tablette ne boot pas, logo asus fixe et rien d'autre... j'ai bien une première fois la barre bleu qui s'affiche, puis ça reboote et la, tablette figée. avez vous une solution à ce petit soucis.. merci par avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
