mnlk2 Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) l'info vien de XDA, je n'ai pas pu tester moi meme, mon bootloader etant deja deverrouiller mais si quelqu'un se sent de tenter l'avanture ^^ ce qu'il faut : 1. Nexus One 2. Android SDK 3. Transcend 4gig Class 6 card (recommendé) 4. un CERVEAUX (IMPORTANT!!!) 5. ce fichier > http://www.megaupload.com/?d=WGNJJN50 Step 0:Ensure that there is no update.zip on the root of the card. Go to Settings > Application > Development and turn on USB Debugging. This should save you headaches. Extract all files to SDK folder (eg: C:\android-sdk\tools) Step 1: Booting into bootloader - Power off your phone first, hold vol- and press power to switch it on Step 2: In CMD, cd to the SDK folder and run loop.bat and then enter recovery by press power button Step 3: To see if adb find your devices in recovery Yes -> Press control + c to stop the loop No -> Hold power and then press vol+ to show the menu and reboot the phone. Repeat step 1-3. ps: I cannot connect adb before I change my sd card to transcend card Step 4: Select apply update.zip, it should be fail but it gives adb permission to write sdcard Step 5: Run "adb push ota.zip /sdcard/update.zip" Run "adb push busybox /sdcard" Step 6: Type "adb push update.zip /sdcard/update.zip" but do not run the code!!!!! Step 7: Select apply update.zip again and press enter to run the code above half second later Step 8: If success, you will see "Gaining root access" on the screen. If not, you will see some errors. Repeat step 5-7 till you success. Step 9: Now, your phone is rooted Step 10: adb push flash_image /system/bin (If it doesn't work, you can push it via root explorer) Step 11: Flash custom recovery image and do a nandroid backup Step 12: Play your phone with different roms source: http://forum.xda-developers.com/showthread.php?t=708123 desolé j'ai la flemme de tout traduire pour le moment, je le ferai surement plus tard, la g pas dormi de la nuit, je suis naze et faut que j'aille au taff :'( Modifié 23 juin 2010 par mnlk2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
webyves Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) euh ... ca permet de metre a jour vers froyo ? ou ca permet juste de faire fonctionner les appli "root only" ?? EDIT : j'ai cru comprendre via step 11-12 que l'on pourrais mettre a jour vers froyo sans faire sauter sa garantie logiciel EDIT 2 : il y aurait un petit genie ou 2 pour confirmer que ca marche et faire une procedure en Francais dans le texte et pourquoi pas une explication par derriere pour changer de rom (mettre un FRF72 par exemple :p) dans ses conditions d'utilisation Modifié 23 juin 2010 par webyves Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mephissto Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Tu peux déjà avoir FroYo sans perdre la garantis. Perso j'étais en 2.2 avant de rooter mon N1 pour mettre Cyanogen. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 @mephissto : Hum tu peux developper la methode ou filer un lien, ca m interesse Édit (billcat74) : Suppression de la citation du message situé juste au dessus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mephissto Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) Par contre j'ai peut être pas précisé, il faut avoir un Nexus One importé des USA, aux dernieres nouvelles ça marche pas avec ceux vendu en France par SFR. Pour passer de ERE27 à FRF50 : http://goo.gl/VX2Q Pour passer de FRF50 à FRF72 : http://goo.gl/3QNF Modifié 23 juin 2010 par mephissto Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Hum c est bien ce qui me semblait, donc pas de possibilitee pour moi d'utiliser des roms custo sans deverouiller le bootloader (sauf si la methode ci dessus marche) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mnlk2 Posté(e) 23 juin 2010 Auteur Share Posté(e) 23 juin 2010 (modifié) la methode marche, le seul probleme est de troouver une carte SD compatible avec la manip, perso j'en ai essayer 4 avant d'en avoir une qui marche (c'etait une no name classe 4) j'avais deja un bootloader deverouiller, mais ca devrai passer sans le deverouiller Modifié 23 juin 2010 par mnlk2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 @mnlk2 : Tu avais quelle version de build a la base? Édit (billcat74) : Suppression de la citation du message situé juste au dessus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mnlk2 Posté(e) 23 juin 2010 Auteur Share Posté(e) 23 juin 2010 j'ai essayer avec une ERE27 et une FRF50 et ca a marcher sans souci, donc les autres ca doit aller aussi je pense Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
drakaz Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) Je suis vert d'avoir déverrouillé mon bootloader :D Bon en même temps, c'est plus pratique de l'avoir déverrouillé pour utiliser le mode fastboot. Modifié 23 juin 2010 par drakaz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
griph Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 On pouvait pas le savoir, la méthode en question n'a même pas 3 semaines.. ça fait 6 mois que j'ai fait sauter le bootloader. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 j'ai essayer avec une ERE27 et une FRF50 et ca a marcher sans souci, donc les autres ca doit aller aussi je pense Moi j ai tente avec plusieurs sd card et je n arrive pas a reconnaitre le telephone, pourtant sur le pc en utilisation normal adb le reconnais bien. Qu est ce que j'ai loupé? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cédriiic Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Cette méthode nécessite : What we need:1. Nexus One with FRF72 et non seulement un nexus :) Donc pour ceux qui sont sur les nexus vendu par SFR ... :mad: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 je pense que ca depend plus de la sd card que de la version du build Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
griph Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) Ça dépend, du build et de la carte SD. C'est pour qu'il demande d'avoir un cerveau. ;) https://www.frandroid.com/22219/nexus-one-root-masquer-le-cadenas-de-demarrage/ Modifié 23 juin 2010 par griph Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flipper Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 @griph : Oui, merci pour le coup du cerveau, sauf que si tu lit le thread xda, il y en a pour qui ca a marche avec un autre build que celui preconisé (voir au dessus aussi)...et je pense que c est un peu aléatoire le fait que adb se lance au moment du fastboot Édit (billcat74) : Suppression de la citation du message situé juste au dessus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
griph Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Le cerveau n'est pas de moi mais du monsieur qui a porté ce hak. De plus FroYo est recommandé, oui ça a pu marcher, mais les risques de brique sont grands. Tente ta chance si tu veux. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
thomlenormand Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Juste une question, pourquoi les risques de brique sont grands sur un N1 avec le build SFR? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
griph Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 (modifié) Si FroYo en version FRF72 est recommandé, je pense pas que ce soit du vent. De plus, dans ce même sujet sur XDA, certains utilisateurs ont dû s'y prendre à 4 cartes SD pour y arriver. Edit: La brique, tu peux ne pas en revenir tout simplement, surtout dans ce genre de cas. Il faut bien préparer tout ses outils avant d'attaquer. Modifié 23 juin 2010 par griph Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
webyves Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 hum ... brique ?? le fromage ?? c'est quoi ?? j'imagine que c'est un plantage ... si c'est bien un plantage comment on en reviens de la brique ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gaelito Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 souvent on en revient pas. Ton telephone devient une brique Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
billcat74 Posté(e) 23 juin 2010 Share Posté(e) 23 juin 2010 Un presse papier ! Un tutorial en français est disponible ici. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
