[SCRIPTs][TWEAKs]Fly-On Mod™V4.0 Alpha3/Feel The Smoothness!/Upd:03/07/13
Salut, pour changer un peu, je propose un post sur un très bon script :
Fly On Mod
Caractéristiques :
-Min-Free and LowMemoryKiller enabled.
-Zip-aligning apps while Booting.
-Turbo Charged,Makes Your launcher very smooth!!
-system tweaks.
-Improved SD Card speed write/read!
-Autonomie amélioré.
-Better Multitasking.
-Sqlite and Database Tweaks.
-Network TCP tweaks.
-sysctl tweaks.
-Kernel and VM tweaks and improvements.
-file system speedup.
-Ext4 tweaks.
-Plein d'autre tweaks pour améliorer performance et autonomie!
Exigences :
-Android Gingerbread 2.3.x
-Root
-Kernel supportant init.d
-ClockWorkMod(4 or higher)
- 1MB d'espace libre in /system
Dans le paquet :
+/etc/init.d/ scripts:
-ram_manager
-09sdcardspeedfix
-darky_zipalign
-98system_tweak
-sqlite_optimize
-remountCM_fullext4(CM version only)
+/system/xbin/:
-sqlite3
-zipalign
+/system/lib/
-libncurses.so(stock version only)
zip.gifFly-On_ram_manager_gamers.zip - [Click for QR Code] (127.3 KB, 2511 views) zip.gifFly-On_ram_manager_multitasking.zip - [Click for QR Code] (127.3 KB, 2448 views) zip.gifFly-On_ram_manager_Balanced.zip - [Click for QR Code] (127.3 KB, 1730 views) zip.gifFly-On_ram_manager_Nexus.zip - [Click for QR Code] (127.3 KB, 522 views) zip.gifFly-On_ram_manager_Hard_multitasking.zip - [Click for QR Code] (127.4 KB, 1445 views) zip.gifFly-On_EXT4_tweak.zip - [Click for QR Code] (127.3 KB, 564 views) zip.gifSigned_Fly-On_Mod™_V4.0-Alpha2.zip - [Click for QR Code] (1.49 MB, 654 views) zip.gifSigned_Fly-On_Mod™_V4.0-uninstaller.zip - [Click for QR Code] (126.3 KB, 205 views) zip.gifSigned_Fly-On_Mod™_V4.0-Alpha3.zip - [Click for QR Code] (3.03 MB, 13 views)
Change Log:
Fly-On V0.1:(8/4/2013)
initial release.
Fly-On V0.2:(16/4/2013)
-re-writed and cleaned script.
-New zip-aligning script based on Darky's zip-aligning script.
-Adjusted Values to be adapted to this device hardware.
-Deleted touch sensitivity tweaks(useless).
-Corrected Min-free values.
-Many other minor stuff...
Fly-On V0.3:(17/4/2013)
(If you are coming from an old version,below V0.3 you will need to delete all scripts in your /system/etc/init.d folder)
Now Fly-On Mod is a full package of scripts:
-Replaced the main Fly-On script with 3 scripts to avoid any functionality problem and ensure more stability (S98system_tweak,05LagFixer,09sdcardspeedfix)
-Added some useful build.prop Tweaks(for better performance and battery life)
-Fixed the Low memory killer bug with the new Lagfixer script.
Fly-On V0.4:(17/4/2013)
-New SQlite_optimize script .
-New Script For Network TCP optimizations.
-Adjusted Min-Free Values for better Multitasking!
Fly-On V0.5:(19/4/2013)
-Fixed permissions Via Updater-script to Make sure that scripts are properly working!
-Some cleaning to the S98system_tweak script!
Fly-On V0.6:(20/4/2013)
Delete all old Fly-On scripts before installing V0.6!
this update contains various improvements bugfixes and changes with a full new script:
-Deleted 05Lag_fixer script!
-Deleted S97network_tweaks!
-New 08Fly_engine script with a lot of tweaks and improvements:
+Full Memory management
+Sysctl tweaks
+Kernel and VM tweaks
+File system speedUp
+Ext4 tweaks
+Improved Wifi_Idle for better battery Life!
-Updated zip-aligning script for faster zip-aligning and short boot time!
Fly-On V0.7:(21/4/2013)
-added xbin to make sure that zipalign and fly_engine scripts are working properly!
-Now with two versions:
+Stock version for Stock gingerbread samsung roms and roms based on samsung roms!
+CM version for cyanogenmod7/9/10 Based roms and AOSP GB/ICS/JB roms too!
Fly-On V0.8:(22/4/2013)
-Fixed errors on Fly_engine script.
-Added I/O scheduler tweaks.
Fly-On V0.9:(25/4/2013)
-Fixed sqlite3 bin permissions.
-Removed journalism on EXT4 partition(greatly increase I/O).
-added remountCM_fullext4 script for CM version.
Fly-On V1.0:(27/4/2013)
If you are coming from Fly-On V0.9 there is no need to delete the old scripts!
-deleted fly_engine script(contain a lot of errors,I will be working on rewriting it).
-added a new ram_manager script (Full memory fix and management).
-fixed proper permissions for all scripts.
Fly-On V1.1(29/4/2013)
-Deleted swapon tweak as it's only causing troubles!
-heavily modified updater-script to make the /system/etc/init.d folder clean while installing the Mod!(there is no longer need to delete scripts manually)
Fly-On V1.2(2/5/2013)
-added new script 02logdelete1 to delete logs+tombstones!Huge thank to -CALIBAN666- for the idea and the big help!
-updated the updater-script with more scripts to delete in init.d folder
-Fly-on mod is now more stable than before!
Fly-On V1.3(3/5/2013)
-Fixed sdcard readahead speed(need some testing)
-Under the request of some users the ram_manager script is now separated from the CWM flashable zip and It has it's own CWM package!
-Under the request of some users the ram_manager script is now with two version : one for multitasking and the other one for hard gamers!
-Some cleaning to the 98system_tweaks script(deleted unseful stuff)
Fly-On V1.4:(7/5/2013)
-New Ram manager config(Balanced)for people with moderate apps use!
-Tried to fix deletelog script(I'm not sure need testing)
Fly-On V1.5:(9/5/2013)
-Fully Re-writed Fly_engine script ensuring maximum compatibility with:
+I/O scheduler tweaks(choose noop for maximum compatibility).
+File system speedup.
+Various sysctl tweaks - Kernel, VM, file system!
Fly-On V1.6:(10/5/2013)
-Fixed Bug with 02logdelete1 script,thanks to -CALIBAN666- !
-Renamed 085Fly_engine to Fly_engine to provide any invalid argument!
-Added Openvpn binary.
-Some minor fixes to the Fly_engine script.
Fly-On V1.7:(11/5/2013)
-Updated 02logdelete1 script with new features and improvements thanks to : -CALIBAN666- .
-Added Default.prop which contains Extra fly_engine tweaks!
-Deleted some tweaks from Fly_engine script(the ones that could conflict with 98system_tweak script).
-Fixed proper Fly_engine script permissions through the Updater-script.
Fly-On V1.8(12/5/2013)
-New RAM manager config(Nexus)It's the original Google config!
-Updated sqlite3 binary
-Modified the CWM installation package to make It detect your android version and install the binaries according to it!
Fly-On V1.9:(13/5/2013)
-Modified Fly_engine script with some tweaks added:
+tune2fs feature(Disable journalism).
+Disabled normalize sleeper.
+Deleted I/O specific tweak for noop I/O scheduler.(Feel free to use any scheduler with Fly-On)
Fly-On V2.0:(15/5/2013)
-Added new RAM manager(hard multitasking)!
-Added new script to improve your touchscreen sensitivity !
-Delete 02deletelog1 for know(will be back after fixing bugs on It).
-Now you can install It over adrenaline engine/velocity directly(Edited CWM installation script).
-Fixed a small error in 98system_tweak script.
Fly-On V2.1:(17/5/2013)
-Fully reworked 98system_tweak script with:
+Lesser script size(from 23kb to 19kb).
+ Edited many values for more smoothness and better battery life.
-Some few modifications to the Fly_engine script.
-Added many info to the first post!
Fly-On V2.2:(18/5/2013)
-02logdelete script is back and it's working properly!
-Fixed a small error in 98system_tweak.
-Reduced 98system_tweak size from 19KB to 17KB.
Fly-On V2.3:(20/5/2013)
-Heavily Edited 98system_tweak with:
+New governor Tweaks!
+Edited many values for better performance/battery life.
+Deleted few lines that are causing issue on some phones!
Fly-On V2.4:(23/5/2013)
-Fixed 02logdelete1 script!Now It's working properly thanks to :vampire: !
-New script 98fly_core It's the fusion of 98system_tweak and Fly_engine scripts(to avoid any incompatibility/stability issues).
-Removed "Disable EXT4 journalism" feature as It's incompatible with many devices that runs a system partition other than ETX4.
Fly-On V2.5:(27/5/2013)
-Fully reworked 09sdcardspeedfix script(reduced size from 3Kb to 1Kb).
-Some cleaning to the zipalign script.
Fly-On V2.6:(31/5/2013)
-Cleaned up 98Fly_core script.
-Some misc changes to the sqlite_optimize script.
Fly-On V2.7:(1/6/2013)
-Reverted back to old 09sdcardspeedfix script(compatible with more devices).
-Fixed a small bug with the 98fly_core script.
-Deleted s78sensitive_touchscreen script for now.
Fly-On V2.8:(2/6/2013)
-New zipalign data script used to zipalign apps on /data at every 48H.
-New sqlite optimizing system at every 48H.
-Deleted remountCM_fullext4 from CM version (another step to make Fly-On more universal).
Fly-On V3.0:(5/6/2013)
-fixed a small issue in 98fly_core script.
-Reworked the 02logdelete1 script.
-Reworked zipaligndata script.
-Reverted back to old sqlite optimizing script.
-Added partition remount tweaks for I9300 in a single package.
-Added Fly-on uninstaller for Version 2.4+ .
Fly-On V3.0 RC0:(9/6/2013)
-Added NOS entropy seeder generator engine,big thank to Exit_Only.
-Added hosts file for ad blocking.
-Fixed uninstaller(no more need to mount /system).
Fly-On V3.0 RC1:(18/06/2013)
-Added NOS entropy init.d script with light/moderate/aggressive profiles and sets moderate by defaults thanks again to EXIT_ONLY !
-Added new 99logdelete script to execute 02logdelete1 script properly at boot thanks to Erikeleria!
-Many minor changes.
Fly-On Mod™ V4.0 Alpha1:(30/06/2013)
-Renamed to : Fly-On Mod™
-Updated and Fixed Nos entropy engine,Now it has:
+Feature to switch Entropy on/off(Nos entropy engine is off by default).
+Two governors light and moderate.
-New 03kill_media_server which kills media server when unused to save battery!
-Redesigned the updater-script which will now:
+Wipe dalvik cache/boot cache while installing Fly-On Mod.
+Delete some old nos entropy parts.
+Fixes Nos entropy engine Permissions.
-Some other minor Fixes and changes.
-Redesigned the Thread with more info(Still a work-in-progress due to lack of time)
Fly-On Mod™ V4.0 Alpha2:(01/07/2013)
-From now on there will be only one version for AOSP based Roms(like CM) and stock Roms too.
-Added Uninstaller compatible with V4.0 only check the FAQ.
-Fixed a minor issue on NOS entropy engine.(fixed missing rngd_state permissions)
-Updated sqlite3 binary.
-Fully rewritten the updater-script with better look.
-Corrected some few missing permissions.
-updated scripts description in /system/etc/init.d/ .
-Deleted swap tweak from 98fly_core script and cleaned the script up.
Fly-On Mod™ V4.0 Alpha3:(03/07/2013)
-Now using hosts file from here with 283540 domains blocked (Adware/Malware/Spyware/Blotware) Big thank to BSDgeek_Jake.
-Fixed permissions for framework through the updater-script(might fix issues for some users).
-Delete network security related tweaks from 98fly_core script.
-Deleted some parts of default.prop that was conflicting with 98fly_core script.
-Some other minor changes.
source : http://forum.xda-dev...d.php?t=2226373
Modifié par Teoandro
  • Réponses 155
  • Vues 23,6k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Most Popular Posts
  • y'a un duel x-dreameur vs akram ?? :o faut choisir son camp ? y'a des paris ouverts ? Cordialement... :P
  • GaLaXyAcE
    GaLaXyAcE
    Certaines valeurs :P
  • GaLaXyAcE
    GaLaXyAcE
    C'est vrai que c'est très français ça aussi :P
Merci du partage, je le suivais sur xda, mais je ne l'ai jamais tester ;)
  • Auteur
Moi je l'ai teste et elle rend la rom super fluide :)
  • Auteur
Perso ce script est meilleur :-)
Pas équivalent à Project Silk ! Silk répond plus rapidement j'trouve :3
  • Auteur
Chacun ces préférences :-)
ses* ! Après chacun ses goûts hein ;) Bah moi c'est Silk car il fait plus de trucs bien que les autres scripts voilà ^^
ses* ! car il fait plus de trucs bien que les autres scripts voilà ^^
  • Auteur
Mdrr c'est compliqué le français ;-)
On dit du chinois et du japonais, mais le français fait également de ces langues hyper complexes ;)
  • Auteur
T'a tout à fait raison :-)
Il va y avoir une autre mise à jour dans les jours à venir qui va incorporer le nouveau script de Slaid dans Fly-On Mod ;)
Oh mais tu n'es plus à la page toi :P, la 1.2 est sorti depuis hier déjà !! ;)
  • Auteur
Dsl pour le retard, post a jour ;)
  • Auteur
Nouvelle version dispo ;)
Merci : post à jour :)
