Alienex Posté(e) 31 mai 2013 Share Posté(e) 31 mai 2013 (modifié) -Ce Kernel fonctionne seulement avec le Samsung GT-I9505 EUR Ce kernel a été crée sur la base du code source update1 de Samsung, Rooté avec la dernière version de SuperSu v1.30.Features:Built from Samsung sources Update2Init.d supportBusybox (/sbin)Built with Stock ARM Toolchain 4.6AutoRoot with SuperSU (If Not Rooted)NFS built-in kernelCIFSand NTFS File System built as modules (Stored on "/lib/modules")ExFAT sdcard supportStweak App supportDisabled Wifi multicast for lower battery drain (Thanks to Entropy512 and GokhanMoral)Tweaked Ondemand CPU Governor for better performance/power balanceEnabled available stock CPU governors (conservative, powersave,interactive)Disabled Android LoggerAndroid Logger switch trough Stweaks App (No Reboot required)Disabled some useless tracersimproved Ondemand CPU Governor tweaks for faster responseIncreased timeout for some bad sdcards Changelog 1.5:Updated Root to 1.41Updated InitRamfs/exFAT to MGAMany Battery life tweaks (MC Sched and Ondemand CPU Gov)Changelog 1.4:Patched with Samsung kernel sources update 2Updated Root to 1.34NFS Built-in kernelUpdated InitRamfs to MF4Some Battery life tweaksChangelog 1.3.3:Patched with ME4 Samsung kernel sources (Thanks to Faux)Updated Root to 1.32Updated InitRamfs to MF2Some Battery life tweaksChangelog 1.3.2:Lower Ondemand CPU up_thresholdAuto Wipe cache and dalvik_cacheFew other fixesChangelog 1.3.1:ExFAT Sdcard support (Thanks to AndreiLux)Enable Sdcard encryptionUpdate Root files V1.30 (Thanks to Chainfire)Disabled Android LoggerAndroid Logger switch trough Stweaks App (No Reboot required) (Thanks to AndiP)CIFS/NFS/NTFS built as modules (located on /system/lib/modules)Disabled some useless tracersIncreased timeout for some bad sdcards (Thanks to AndreiLux and AndiP)improved Ondemand CPU Governor tweaks for faster responseChangelog 1.2:Disabled Wifi multicast for less battery drain (Thanks to Entropy512 and GokhanMoral)Tweaked Ondemand CPU Governor for better performance/power balanceEnabled available stock CPU governors (conservative, powersave,interactive)Removed NTFS support (you can mount it trough Cifs)Changelog 1.1:CIFS, EFS, NTFS support (built as modules “/system/lib/modules”)Stweak App support (Just introducing some basic stock options, more to come on next updates)Keep your busybox (/system/xbin” or “/system/bin”) on rebootSome Ram and Battery life tweaksInitial release:Built from Samsung sources Update1Init.d supportBusyboxBuilt with Stock ARM Toolchain 4.6AutoRoot with SuperSU v1.25 Download. Sources: http://forum.xda-developers.com/showthread.php?t=2281738 http://server01.xdafileserver.nl/index.php?dir=Wanamlite%2FGS4-LTE-I9505%2FKernel%2F1.5 Modifié 30 juillet 2013 par alienex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bastdut Posté(e) 27 juillet 2013 Share Posté(e) 27 juillet 2013 Nouvelle version 1.5 dispo! ;) Lien de téléchargement: cliquez ici Source officielle: XDA 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
raphoudu57 Posté(e) 28 juillet 2013 Share Posté(e) 28 juillet 2013 Des soucis avec la 1.5 je crois,non? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alienex Posté(e) 30 juillet 2013 Auteur Share Posté(e) 30 juillet 2013 Non aucun pour ma part Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
raphoudu57 Posté(e) 30 juillet 2013 Share Posté(e) 30 juillet 2013 J'en ai pas non plus ;) Mais il y a eu de mauvais retour sur xda, je demande ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
