ROM ILLUSION V2.1 14/07/2013
Salut a tous ,fervent testeur de rom,j ai flashé sur celle ci sur xda
Elle regroupe tous les features des autres teams que nous connaissons deja
Ce qui peut la distinguer des autres c est le style des sms entierement parametrables comme celle de la blackbean et le caractere d ecriture est diiférent
Je vous mets les images de mon nexus ce sera plus parlant et a la suite je vous mets les détails de la rompost-131579-0-00509600-1372268398_thumb.post-131579-0-68677900-1372268415_thumb.post-131579-0-56924500-1372268429_thumb.
Illusion is BACK!!! We'd like to give HUGE credits to SLIM Roms for an incredible base! We'd also like to give credit to , Paranoid Android, AOKP, TeamBaked, CyanogenMod. These people helped make what you guys are using (about to use) what it is today smile.gif.
FEATURES
Quote:
Dark UI
Permissions Management
  • LCD Density Settings
  • Per-App DPI Settings
  • StockUI
  • PhabletUI
  • TabletUI
Illusion Settings & ROM Control:
  • Per-App Permissions Manager
  • Dual Pane
  • Low Battery Warning
  • cLock
  • Custom Hardware Keys
  • Widgets Viewpager
  • Notification Drawer Options
  • Power sound on plug-in/plug-out
  • Custom Lockscreen Sliders & Shortcuts
  • Navbar Customizations
  • PIE Controls
  • Power Menu Controls
  • Power Widget Settings
  • Custom QuickSettings
  • Custom Statusbar Options
  • Custom Sounds Settings
  • Custom Phone Settings
  • Custom MMS Settings
  • Integrated Superuser
  • Trebuchet
  • 3.4.x Kernel base
  • ......Much more in detail
BE SOCIAL
Please follow us on Google plus or hop in and say hello
For nexus support )info)questions)comments)Release notes)) You can visit me Google plus
KNOWN ISSUES
Quote:
  • Let me know...
Changelog
INSTALLATION:
If coming from a different rom please do a clean flash
If updating from an earlier version wipe caches flash rom flash gapps wipe caches again and reboot.
LATEST RELEASE, CHANGELOG, AND GAPPS
Code:
CHANGES
INSTALLATION:
If coming from a different rom please do a clean flashIf updating from an earlier version wipe caches flash rom flash gapps wipe caches again and reboot. 2.0 to 2.1 I do recommend a clean install font changes and theme changes
DOWNLOAD
please support development by hitting the thanks button or help out by donating
Plus le lien pour rajouter l apk Camera et galley
https://docs.google....RcGc/edit?pli=1
Modifié par loki97231
  • Like 2
Le système de réglage de PA, pouvoir modifier la taille, le mode d'affichage et la couleur de chaque application. (Barre de notification et de navigation)
J'adore ce système, tu peux rendre ton tel vraiment harmonieux :P
Envoyé depuis mon Nexus 4 avec Tapatalk
Modifié par Madinina
Comment ne pas aimer ? :D pouvoir assortir la couleur de ta barre de notification avec chacune de tes applications je sais pas je trouve ça vraiment cool ! Mais c'est vrai que le fait de le faire pour chaque appli ça peut paraître lourd, au début je croyais même que c'était automatique.. Oui oui on a tous des rêves :D
Et bah ça fait bien le longtemps que je n'ai pas post mais il faut dire que cette ROM est une pure merveille pour le moment.
Le thème keylime pie et particulièrement bien fait. La ROM est fluide, pour le moment. La batterie est correct avec kernel de base.
Ayant pratiquement tout testé et étant un éternel insatisfait je recommande celle la, qui de plus est en version beta ;-)
1er retour après 1h d'utilisation.
(+) Beaucoup d'option - Réglages leds inclus, vraiment un point positif par rapport a PA
- Réglages sms, contact et téléphones
Fluidité
Thème "KeyLimePie" vraiment classe
(-) Après un redémarrage le PIE a tout simplement disparu, j'ai été obliger de faire un wipe cache. A voir avec d'autres reboot si c'est un réel problème ou seulement isolé.
(?) Quid de l'autonomie? je ne peux pas juger maintenant, trop peu utiliser.
Quel est le Kernel inclus dans la ROM ?
Madinina j ai flashé le franco milestone 2 aucun soucis
Welcome monkey lol .J aime bien le style d écriture de la ROM . Dans les paramètres téléphone on peut ajouter une blacklist, pour ceux qui sont sur be ans you faut paramétrer les Apn pour que les MMS passent
Moi qui ne pensait pas 1seconde quitter la pa je reste finalement sur l'illusion :D
Un bonheur cette rom, et c'est seulement la v1 beta ! En plus les réglages paranoid vont être implémenter prochainement what else ?
Deux petits défauts que j'ai noter tout de même. Pour les options de redémarrages il y simplement.. Redémarrer, Recovery et fastboot aurait été un plus mais sera sûrement ajouter dans les prochaines releases et j'ai quelques fois avec certaines applications un bug de barre de notification
Envoyé depuis mon Nexus 4 en utilisant Tapatalk 4 Beta
La ROM est optimisé linaro ou pas ?
il ne semble pas quel soit optimisé façon linaro mais n'en demeure pas moins une rom tres stable et fluide.
une V2 est dans les starting block, il ne lui reste que quelques ajustement :)
