loki97231 Posté(e) 30 juin 2013 Share Posté(e) 30 juin 2013 Salut les gars,je vous présente cette rom que j'ai découverte hier sur XDA ,je suis friand de test ,et je trouve celle ci pas mal Pas rapport a toutes les roms que nous connaissons ,elle change un peu au niveau des softkeys,le style d ecriture me fait penser au font sony sketch ,le franco milestone 3 est intégré,et il y a une plethore de sons de notif et de melodies Par contre pour ceux qui aiment Halo ,elle n est pas dans cette rom ,treve de bavardage ,bon test pour ceux qui ont la maladie du flash comme moi Hi, Welcome to AlienDroid 3.0. The previous versions of AlienDroid were extremely succesful I decided to update the ROM and give it life again, but this time for the Nexus 4. This ROM focuses mostly on the user experience and not silly benchmarks or useless optimization. The Nexus 4 is perfectly capable of handleing Android 4.2 without any of the optimization that all the other ROMS are giving it. I made this ROM to appeal to the user in Speed, Stability, and Featurefull. This ROM is extremely fast and has lots of little tweaks that make it so speedy. It also has incredible stability as its built off the latest stable Cyanogenmod. Last but not least this ROM has really cool features and tweaks that you won't find anywhere else. Currently this is a beta-ish release as it does not include all the things I want it to inlcude such as the AlienMods app that were working on to bring to the next update. I really hope you enjoy this ROM. Android 4.2.2 With Bits of Android 4.3 added into it. (Look Below) Android 4.3 GE SunBeam Wallpaper Android 4.3 GE Boot Animation Android 4.3 Camera New Font (Slightly changed to be subtly better but not to intrusive to the Android Look) New UI Sounds (Thanks to the UKG Team) New Soft Key Buttons (Removable once AlienMods gets released) Android 4.2 Launcher with Landscape support Lockscreen Landscape Support As well Beats + Xlouder (Thanks Misledz) Audio optimization for best sound Sony Walkman Music Player 30 Music Steps for more flexibility to sound control Smooth Scrolling Hack Sony Bravia Engine 2 Sysctl Battery Saving Scripts SecretSauce Scripts SuperCharged Scripts Modification to .so files for more Smoothness, Butter. Removed Apps, files not seen fit for the ROM Full Gapps Integration Latest Google Play Apps Flash Working and Preinstalled Franco Kernel Milestone 3 Installed Battery Saving Optimizations added Removed Camera Lockscreen Widget Ill update the list as I update the ROM. So Many More, Just Flash It (Backup First) Screenshot 1 Screenshot 2 Screenshot 3 Screenshot 4 Screenshot 5 Screenshot 6 AlienDroid V3.0 B1 - Download Here, Mirror 1 (Thanks to Swirly05) V3.0 B1 First Release For Mako. No Bugs BACKUP Wipe Data, Cache, Dalvik, etc. Install ROM NO NEED TO INSTALL GAPPS, THERE PRELOADED Enjoy Cyanogenmod UKG Team Misledz Powerpoint45 franciscofranco Google PM Me if i missed you. Sorry. Right now this is the first release of this ROM for mako, this is more of a beta since it does not include all of the features i want it to include at the moment. There are great things planned for this ROM if you decide to stick around. Me and Powerpoint45 are working on an amazing app that is sorta like a mod shop or like a Cydia Store that will only be available for this ROM. We already have the majority of it done and we should be done by next week. I will post screenshots of the app and explain it a bit more once we release it. Thanks Lien vers le commentaire Partager sur d’autres sites More sharing options...
iAndrowind Posté(e) 30 juin 2013 Share Posté(e) 30 juin 2013 Cette ROM intégrant des fonctionnalités comme la dernière google cam, franco kernel M3 ou encore Beats+xlouder semble intéressant. Par contre elle ne semble pas intégrer de wifi fix comme avec les drivers Prima. Donc attente de retours. C'est quoi le lien XDA ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
loki97231 Posté(e) 30 juin 2013 Auteur Share Posté(e) 30 juin 2013 Attends je te mets le lien xda ,ben moi je m en sers et pour l instant j en suis content Ca sers a quoi le wifi fix http://forum.xda-developers.com/forumdisplay.php?f=1911 Lien vers le commentaire Partager sur d’autres sites More sharing options...
julz Posté(e) 30 juin 2013 Share Posté(e) 30 juin 2013 le fix wifi pour les notifications qui arrivent 2h après lorsque tu es connecté en wifi. pas si grave... Lien vers le commentaire Partager sur d’autres sites More sharing options...
loki97231 Posté(e) 30 juin 2013 Auteur Share Posté(e) 30 juin 2013 Ah ok ben ecoutes tout à l air d etre ok for me Lien vers le commentaire Partager sur d’autres sites More sharing options...
loki97231 Posté(e) 1 juillet 2013 Auteur Share Posté(e) 1 juillet 2013 Par contre je n arrive pas afficher les paramètres rapides comme sur screenshot de présentation Envoyé depuis mon Nexus 4 en utilisant Tapatalk 4 Beta Lien vers le commentaire Partager sur d’autres sites More sharing options...
iAndrowind Posté(e) 1 juillet 2013 Share Posté(e) 1 juillet 2013 Bon comme j'ai lu le titre trop vite, j'avais pas fait gaffe c'est encore une version bêta. Donc j'attends une éventuelle RC. Lien vers le commentaire Partager sur d’autres sites More sharing options...
nexusgilles Posté(e) 1 juillet 2013 Share Posté(e) 1 juillet 2013 j'ai tester deux jour ensemble bon manque personnalisation statu bar est une version sans gappps car il y a trop je vais attendre l'évolution B) Lien vers le commentaire Partager sur d’autres sites More sharing options...
David Dessi Posté(e) 1 juillet 2013 Share Posté(e) 1 juillet 2013 Bon loki, comme tu t'en doute, j'ai testé ^_^ Mais je suis vite revenu à la Illusion, pas assez de réglages à mon goût :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
loki97231 Posté(e) 1 juillet 2013 Auteur Share Posté(e) 1 juillet 2013 Merci Monkey lol je mets les roms que je decouvre pour diversifier un peu lol Lien vers le commentaire Partager sur d’autres sites More sharing options...
David Dessi Posté(e) 1 juillet 2013 Share Posté(e) 1 juillet 2013 Merci à toi de nous faire découvrir toutes ces roms plutôt ! :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
