ROM SLIMKAT OFFICIAL 6 (4.4.4)
Pour mon premier post, je vous informe du portage de la ROM SLIMKAT OFFICIAL 6 de SLIMROM ( 4.4.4 ) sur le moto X.
Plus abouti que CM a mon goût ( sur RAZR HD en tout cas ) et surtout le multitache qui est plus logique.
Unique SlimRoms Features   SlimRoms feature overview   The real dark Slim
Invert the whole ROM including Gapps with one click.
Slim Recents
A complete replacement of the AOSP recents screen to allow better multitasking, along with marking favourite apps.
Notification drawer and lockscreen shortcuts
Access your most important apps from everywhere.
Custom Quick Settings Tiles
Why just settings? Use whatever you want.
SlimPIE
Based on CM's PIE, inspired by PA's PIE with a light touch of Slim. A true community feature.
Notification reminder
 An easy way to quickly set short reminders to show on the notification drawer.
Slim dialer
 A full replacement of the official Google closed source dialer with added features.
Camera
Discover our unique Camera feature......two of them we show here
Pour l'installation c'est du classique !
Installation Instructions
SlimKat installation instructions
Be sure to follow these instructions to the letter.
  1. The first thing to do is to make sure you have the latest recovery installed.
      • Note that recommended recovery (CWM or TWRP) varies from device to device so make sure you check our forums for your device's thread and install the recommended recovery stated in the OP. The easiest way to flash the recovery is to either use Goo Manager app for TWRP or Rom Manager app for CWM.
  1. Download latest SlimKat and latest gapps and put on your sd card.
      • You’ll find the latest SlimKat for your device here.
      • And look for the latest SlimKat gapps here
  1. Reboot to recovery.
  1. In recovery make a full wipe as per these instructions:
      • In CWM perform wipe data/factory reset and in mounts and storage section format system.
      • In TWRP choose advanced in wipe section and wipe dalvik cache, cache, system and data.
  1. Flash SlimKat rom zip.
  1. Flash SlimKat gapps zip.
  1. Reboot, setup and enjoy.
LE LIEN POUR LA ROM : http://www.slimroms.net/index.php/downloads/dlsearch/viewdownload/1252-moto-msm8960dt/12002-slim-moto-msm8960dt-4-4-4-build-6-official-5248
LE LIEN POUR LES GAPPS ( toutes) : http://slimroms.net/index.php/downloads/dlsearch/viewdownload/1150-addons4-4/12059-slim-full-gapps-4-4-4-build-6-112
Voila si vous avez des questions n'hésitez pas !
Sinon voici l'adresse du forum slimrom : http://forum.slimroms.net/
  • 4 weeks later...
