[ROM][5.0.2][LRX22G][01/01] || Pure Shamu b3.7
Pure Shamu
Créée pour être une ROM stable et rapide à partir des sources. Je vais toujours tâcher d'être le plus stock possible tout en ajoutant des fonctionnalités afin d'être entre le style stock & AOSP.
La ROM utilise le kernel stock
@error311
Instructions :
¤ NE PAS EFFACER LA MEMOIRE INTERNE (wipe internal storage)
¤ Full wipe (cache, dalvik cache, data, system)
¤ Flash Pure Shamu b3.7
¤ Flash MINIMAL GAPPS (ou autre GAPPS)
¤ Flash (inutile si vous flasher un custom kernel ensuite) ROOT
¤ Enjoy
Fonctionnalités et changements :
- PLATFORM_VERSION=android-5.0.2_r1 || BUILD_ID=LRX22G
- Pure Settings
-- Battery percentage inside & out + toggle
-- Custom nav bar height
-- volume rocker wake toggle
-- volume key adjustment sound toggle
-- volume key cursor control
-- status bar brightness control
-- advanced reboot toggle - recovery, bootloader & soft reboot
-- kill app long press back option
-- customize clock & date
-- music playback controls
-- app manage
-- more still on it's way!
- A lot of optimizations, enhancements & fixes
- clear all recent apps
- busybox added
- material design aosp browser
- Audio & video fixed
- clock and time clickable in statusbar
- MTU changed to 1358
- use observer getting default apn
- make cast tile update when wifi status changes
- more scrolling improvements
- Google Play Movies, Netflix and chromcast fixed
- Location services
- data roaming turned off
- dialer added material design icon
- launcher3 allow rotation
- pure shamu vendor
- Enabled double tap to power
- removed force encryption w/ encryptable
- removed stock recovery
- changes for AT&T + Verizon
-- tether, volte changes
- ro.secure=0
- battery saving tweaks
- build.prop changes & additions
- configupdater & dma removed
- enable_target_debugging := true
- add support USB OTG
- rotation lock tile animation added
- double tap statusbar to sleep
- improved scroll cache
- removed vendor_module_check.mk
- removed check-product-copy-files
- WITH_DEXPREOPT := false
- comment out build date assert
- build L audio only
- UI tweaks
- hide system update
- enabled google backup
- remove unwanted stuff
- removed AOSP su
- allow su to gain root
- nexus binaries
- whatever I forgot
Changelog :
changelog 1/1/2015 b3.7:
-fixed back button size in landscape
-long press recents to switch to last open app
-disabled volume key sounds when waking device
-more base cleanup
-memory leak patch cleanup
-added volume panel material animation
-notification fix
-few string changes
-clear all app changes
-more performance enhancements
-more build cleanup
-proper uaprof url
-tap to pay url help
-playback control disabled when rocker wake is enabled
-allow volume up when using seek music track
-added ibflacencoder
-Pure Settings
--App Manage
---long press icon for app management in notification area and recent apps list
changelog 12/31 b3.6
-Verizon now has data again (sorry)
-At&t should be improved
-US Cellular fixes
-reverted browser for now due to hidden battery drain
-busybox updated
-few frameworks/base changes & improvements
changelog 12/25 b3.5
-browser icon updated (sorry about ugly old one lol)
-browser changed to blue
-browser fixes for incognito mode
-browser crash fix
-battery life enhancements
-telephoney changes
-more sprint/Verizon changes
changelog 12/21 b3.4
-Pure settings
-- Playback Control added | long press volume skip tracks | toggle on/off
-Browser: settings force close fixed
-Browser: new icon
-Browser: updated to material design
-Browser: auto hide address bar
-more changes for sprint/vzn
-more OTG changes/crash fix
-more fixes
-few new aosp commits added
-removed double tap to sleep completely for now
-more build additions
changelog 12/20 b3.3
-update PLATFORM_VERSION=android-5.0.2_r1 || BUILD_ID=LRX22G
-merged
-added clock & date to pure settings
-- show clock on/off toggle
-- align center or right
-- show PM/AM options
-- show date options
-- change color options
-- date style & format options
-added VoiceWakeup
-Allow override of DUN settings
-make clock and time clickable in statusbar
-fix syntax error
-fix mastermute return
-fix incorrect usage of bool
-MTU changed to 1358
-use observer getting default apn
-make cast tile update when wifi status changes
-Dialer lookup
-more scrolling improvements
-updated proximity wake code
-more code cleanup
-updated translations
-more vendor changes
-build cleaned up alot
-disabled double tap statusbar to sleep for now
-build no longer file based
Change log 12/17 b3.2:
-battery percentage inside battery and out list select
-rotation lock tile animation added
-double tap statusbar to sleep
-fixed unmount /systen
-fixed build problems
-improved brightness slider behavior
-fix to avoid ui freeze problem
-improved scroll cache
changelog 12/11 & 12/12 b3-b3.1:
-t cdma fixed (Verizon users please let me know)
-enabled bsp
-build maintenance & fixes
-user changed to root
-build.prop additions
-vendor updated
-stagefright plugins
-ramdisk
-init.d
-debugging enabled (again)
-dexpreopt false
-more compression
--opticharger
-ua fix
-synced
-block mode
-default wallpaper changed to stock nexus 6
-system ui overlay changes
-*unmounts is still an issue, sorry.*
changelog 12/08 b2.95:
-Netflix works again (temp fix)
-synced
-code cleanup
changelog b2.9 12/07
-changed pa apn to stock nexus 6 apn.
-fix memory leak issue in app settings
-sync
-build changes
- alarm changed to Argon
-few vendor changes
-mmc discard
-odex
changelog b2.8 12/04
-fixed navbar issue
-build id overrides
-small bug fix
-build changes
-sprint users report back please
Pure Shamu b2.7 12/03
- android-5.0.1_r1 LRX22C
-few fixes
Pure Shamu b2.6 12/01
-build prop changes/additions
-configupdater & dma apks removed
-added back in few drm libs
-changed default ringtone to Titania / notification to Tethys
-code cleanup
-trimmed battery percentage spacing
-few fixes
-recent sync
Pure Shamu b2.5 11/28
-Pure settings
-battery status percentage not native
-status bar brightness control
-advanced reboot - recovery, bootloader & soft reboot
-kill app moved to pure settings
-clear all recent apps
-build.prop changes
-data roaming turned off
-dialer added material design icon
-launcher3 allow rotation
-added back in location services
-fixed backup services
-busybox added
-removed aosp openwnn, protools, calendar, voice dialer
-pure shamu vendor
-fixed audio & video issues
-few enhancements and fixes
Pure Shamu Beta build 2.3 changelog | November 26, 2014
-Pure settings*
--fixed battery percentage toggle
--added volume rocker wake toggle
--added volume key adjustment sound toggle
--added volume key cursor control
-developer options*
--added kill app long press back option
-build
--fixed permission issues
--launcher3 build shamu
--fixed empty ringtones
--fixed use lollipop audio
--bunch more i will post when i get home
Pure Shamu Beta build 2 nov 24
-public release
Source : http://forum.xda-developers.com/nexus-6/development/rom-pure-shamu-beta-2-0-t2952604
Modifié par Elpatii
