Alienex Posté(e) 17 janvier 2015 Share Posté(e) 17 janvier 2015 Caractéristiques de la ROM : * Sabermod 4.8.4 GCC Toolchain* Kernel based on @franciscofranco kernel* LCD KCAL control* Disabled forced encryption* Tweaked CPU governors* Voltage control* CPU overclocking* FauxSound* LiquidSmooth build optimizations* Black UI* Linaro and Code Aurora Optimizations* Custom toast animations* Option to disable screenshot noise* Built in superuser options with Root access options* Call blacklist options* SMS rate limiting option* Filter spam notifications* Per app control for Lockscreen notifications* Configurable 0, 90, 180 and 270 degree rotation* Safe headset volume option* Less annoying sound notifications option* Option to use volume keys to control media volume anytime* Option to custimize device hostname* Option to not wake up device when charge is plugged/unplugged* Volume rocker wake up* IME switcher notification control* Option to disable fullscreen keyboard* Force autorotation on IME* Option to force show enter key* CM's Privacy Guard* Increasing ringtone option* Dark UI (primarily in Settings for now)* Screen Density changer* Statusbar clock customization* Option to disable searchbar in recents* Statusbar brightness control* Double tap statusbar to sleep control* Custom Lockscreen shortcuts* Extra info about your device (About phone/tablet)* Custom Liquid Logo in about phone/tablet* Google bug report and ota removed* Option to show kernel toolchain and other info by tapping kernel version in about phone/tablet* Timeout and instant lock options added to slide unlock instead of just secure keyguard options* Developer options enabled by default* Navigation bar height control* Show application package name in app info* LiquidSmooth Stats and Updater added* Partition size info* Option to disable immersive messages Téléchargement et installation de la ROM - v4 ROM : http://drdevs.com/devs/teamliquid/Nightly/Nexus_6/LS-LP-v4.0-2015-01-17-liquid_shamu.zipKERNEL : LiquidSmooth Kernel (flashable zip)SUPERSU : Flash newest SuperSU 1 / Pour les personnes n'ayant pas rooté et installé le custom recovery sur leur téléphone commencez par ici : https://forum.frandroid.com/topic/212782-toolkit-root-en-1-click-nexus-root-toolkit-v202-windows-mac/ 2 / Une fois rooté et après avoir installer un custom recovery : Redémarrez en recovery mod : appuyez sur POWER VOLUME BAS et VOLUME HAUT en même temps, un menu apparaîtra utilisez les touche volume pour naviguer et la touche power pour sélectionner le menu RECOVERY MODE Une fois dans le recovery (Team Win Recovery) : Wipe -> Swipe to factory reset Install -> LiquidKernel_shamu-01_08_2015.zip Install -> LS-LP-v4.0-2015-01-14-liquid_shamu.zip (la date du fichier peux varier selon la version que vous avez prise) Install -> UPDATE-SuperSU-v2.40.zip Redémarrez votre téléphone et le tour est joué ! LIEN DE LA SOURCE : http://forum.xda-developers.com/nexus-6/development/rom-liquidsmooth-v4-nexus-6-97-t2973469 Screenshots Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
