genesixxbf3 Posté(e) 1 février 2015 Share Posté(e) 1 février 2015 Team Bliss Website Bliss Roms now has a new website with several features. Member sign-up, giveaways, weekly newsletter for members, staff information, downloads and the option to open support tickets for issues are just a few of the great features available on our website. Huge thanks to [MENTION=5346868]pjgraber03[/MENTION] for developing and maintaining our website. Team Bliss is a team consisting of developers and device maintainers that work on this project in our spare time to be able to give Android users a custom rom packed with features that will make a lasting impression. Team Bliss is pleased to present to you BlissPop Rom!BlissPop is one of the most highly customizable roms that you can install on your mobile device, and you will have a truly blissful experience.BlissPop is CM12 based, with some features added in, and we will continue to update features as they become available.A huge thanks to CyanogenMod for the source, and all the work and dedication their team puts in to keep us updated.We will keep up to date with the latest CM code, and updates will be posted on a regular basis. However, please do not ask for ETA's. We will update the links as soon as they become available. We will not tolerate any rudeness or anyone being disrespectful in this thread. We will do our best to answer your questions or concerns as soon as possible. Personalization OptionsCM12 Theme Manager (Early Development so there will be some bugs)-Deep Darkness theme by [MENTION=5686358]_moelle[/MENTION] includedStatus Bar-Clock & Date Options -Option to show seconds in time-Battery Options (Portrait, Landscape, Circle, Text or Hidden)-Battery Bar Options-Mobile & Wifi Network IconsOptions-Status Bar Header-Notification & System Icon Options-Traffic Monitor-Brightness Control-SuperUser Indicator-Notification Count-Weather-Notification Ticker-Carrier Label OptionsRecents Options-Clear All Button Tweaks-Option to show Google search bar in recents Menu-OmniSwitch (Option to replace recents menu with Omniswitch)Notification Drawer-Tile Options-Quick Setting Options-Quick & Smart Pulldown-Brightness Slider OptionsLockscreen Options-Disable Camera-Disable Dialer-Clock Widget SettingsPower Menu Options-Power Off-Reboot-Screenshot (with delay option)-Screen Record-Profile Switcher-Airplane Mode-User Switcher-Settings -Device Lockdown-Sound PanelButtons-Power Button End Call Option-Home Button Options-Back Button Wake Up Option-Menu Button Options-Search Button OptionsPie Control-Buttons Options-Style & Dimension Options-Trigger Options-VisibilityGesture Anywhere-Location Options-Trigger RegionsAnimations-Toast Animations-Listview Animations-System Animations-Scrolling Cache-Scrolling ModifiersApp Circle Bar-Choose what apps you want to show on the App Circle Bar-Trigger width, position and heightDevice Control-Control Kernel, CPU, GPU & Many Extra SettingsBliss Download Section-All current downloads for your convenienceAudioFX EqualizerDisplay Options-Wake Up on Charge-Prevent Accidential Wake Up-Double Tap to Sleep-Density-Reported Density-Screen Recorder-Color CalibrationSound & Notification Options-Media, Alarm & Ring Volume Options-Increasing Ring Volume-Call Vibration-Interruption Options-Notification Light Options-Battery Light Options-App Notification Options-Notification Access-Camera Shutter sound, Screenshot Sound, Safe Headset Volume-Less Frequent Notifications-Heads Up Notification with Snooze Timer & Time Out-SuperSU - Huge thanks to [MENTION=631273]Chainfire[/MENTION] Other Stuff Included-User Profiles-System Profiles-Location Options-Security Options-Privacy Options-Accounts & Sync-Language & Input-Backup & Reset-Accessibility -Printing-Performance Control-Developer Options-Rom & Hardware Information--Many other settings throughout the rom. Take some time to familiarize yourself with all the blissful options! BlissPop Sourcehttps://github.com/TeamBliss-LPTeamBliss Devices Sourcehttps://github.com/TeamBliss-Devices We recommend using either PA GApps, which are available for download HereORBanks GApps, which are available HereA huge thanks to [MENTION=2777334]TKruzze[/MENTION] for maintaining PA GApps!If you prefer another set of GApps, just make sure you use 5.0. Telechargement Team Bliss is not responsible in any way for anything that happens to your device in the process of flashing. Please familiarize yourself with flashing and custom rom use before attempting to flash the rom. Please make sure you download the correct version of BlissPop for your specific device. The links are labeled clearly. -Make sure you are rooted.-Make sure you have a custom recovery installed. (TWRP, CWM, Philz CWM)-Download the latest Bliss Rom & the latest GApps package. -Boot into recovery.-Perform a FULL factory wipe and wipe/system and dalvik cache as a precaution-Flash Bliss Rom-Flash GAPPs package-Reboot-First boot may take up to 10 minutes As you all know, Lollipop is new and there are going to be bugs. Please bear with us while we work on getting things updated, and all errors fixed. If you have a major bug to report that has not been reported already, and is not a known issue with CM, please take the following steps to report it to us. It will save you time, as well as us. -Bluetooth Streaming / Transfer issues on some devices. -Camera locks up at times, and will cause a reboot. -Download the Catlog app from the Play Store. There is also a donate version which you can purchase to show appreciation. -After downloading the Catlog app, go to the app settings, and change the log level to Debug. -Clear all previous logs and take the exact steps to produce the error you are receiving. -As soon as you receive the error (probably a force close), go straight into Catlog and stop the log recording. -Copy and paste the entire log either to Hastebin or Pastebin -Save the log, and copy and paste the link into the forum with a brief description of the error. -You can also open trouble tickets on our website for bugs. http://teambliss.x10host.com/BlissPop/ScreenShots/BPop.4jpg If you would like to donate for further development of Bliss Roms, (or to buy us a beer every now & again), visit this link: PayPal Donate LinkAny & all donations are greatly appreciated. The Bliss Team: Thanks to [MENTION=4396647]skyliner33v[/MENTION] for the wallpapers & boot animations. [MENTION=2490658]pimpmaneaton[/MENTION], [MENTION=5216756]jackeagle[/MENTION], [MENTION=5052522]nprev420[/MENTION], [MENTION=3987079]remicks[/MENTION], [MENTION=4442122]Deliberate[/MENTION], [MENTION=4003363]xboxfanj[/MENTION][MENTION=5159622]nerdyblonde[/MENTION], [MENTION=5168118]Vortex1969[/MENTION],[MENTION=5346868]pjgraber03[/MENTION], [MENTION=4279318]bracketslash[/MENTION],[MENTION=2975319]death2all110[/MENTION], [MENTION=928479]electrikjesus[/MENTION], [MENTION=6026679]kornfed[/MENTION], [MENTION=5686358]_moelle[/MENTION], [MENTION=2089878]asianflavor[/MENTION], [MENTION=3367894]Jiggs82[/MENTION], [MENTION=5776465]genesixxbf3[/MENTION]&& Thanks to a ton of other people who have contributed to the source that we used to build the rom! 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CarlitoG85 Posté(e) 1 février 2015 Share Posté(e) 1 février 2015 super initiative de ta part de faire ce sujet. Pour moi, la meilleure rom lollipop et la plus aboutie. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 1 février 2015 Auteur Share Posté(e) 1 février 2015 Je traduirai le sujet pendant la semaine excusez moi super initiative de ta part de faire ce sujet. Pour moi, la meilleure rom lollipop et la plus aboutie.Si tu as des recommandations ou des problèmes n'hésites pas à me le dire Erwan Membre de la TeamBliss Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zeldomar Posté(e) 1 février 2015 Share Posté(e) 1 février 2015 super initiative de ta part de faire ce sujet. Pour moi, la meilleure rom lollipop et la plus aboutie. Salut Carlito, A quelles roms la compares-tu stp ? Et en quoi l'as-tu trouvé meilleure ? Merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xili Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 je l'ai flashée hier soir ... je la trouve sympa du fait qu'il y ai le Pie contrôle intégré d'origine, et peux être même plus d'option de personnalisation que la RR un appareil photo qui semble tres complet, open camera, peu etre un peu long a la prise, mais ça doit pouvoir se régler pas de lag particulier, en tout cas rien ne m'a choqué... je suis avec le kernel d'origine ( render kernel 3.4 a priori) sans modification Ah si, j'ai eté surpris de capter correctement a des endroit ou je ne captais presque rien habituellement, et ce depuis plus d'un an avec différente rom ( slimkat et cloudy G3 principalement), faudra que je verifie si c'etait pas un coup de chance aujourd'hui ... a suivre donc dans les prochains jours Concernant l'autonomie,qui est un des points que je recherche, dur a dire pour le moment vu que je n'ai même pas fini mon premier cycle ... J'ai flashé hier j'etais a 100% avant le flash vers 23h, le temps de regarder un peu ce qu'il y avait sur la rom, faire tous les téléchargement d'appli en wifi, appliquer les sauvegardes de sms et autres, a 9h j’étais a 50% . Ce soir je suis a 30% de batterie , avec un peu plus de 2h de screen on ... voila pour le moment ... je vois ce que ça donnera dans les prochains jours 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cagerelafougere Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Merci pour ce retour complet à voir pour l'autonomie dans quelques jours... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 2 février 2015 Auteur Share Posté(e) 2 février 2015 J'utilise la rom depuis presque le début (en tant que développeur aussi ^^) et je tiens facilement la journée avec 4-5 h SOT 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cagerelafougere Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Pas de pb lors des appels ? Avec la RR ça raccroche quand je suis au téléphone.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 2 février 2015 Auteur Share Posté(e) 2 février 2015 Pas de pb lors des appels ? Avec la RR ça raccroche quand je suis au téléphone..Ça doit parce que le capteur de proximité ne détestais pas ton oreille je n'ai pas de problème avec ça même si je passe pas beaucoup d'appel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cagerelafougere Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Ça doit parce que le capteur de proximité ne détestais pas ton oreille je n'ai pas de problème avec ça même si je passe pas beaucoup d'appelOk merci je vais me laisser tente alors :) est ce qu'il y'a souvent des maj ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 2 février 2015 Auteur Share Posté(e) 2 février 2015 Ok merci je vais me laisser tente alors :) est ce qu'il y'a souvent des maj ?Ça dépend de moi et de mes collègues sinon c'est au moins une par semaines au plus ça peut être une toutes les heures regarde les dates des build Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cagerelafougere Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Ça dépend de moi et de mes collègues sinon c'est au moins une par semaines au plus ça peut être une toutes les heures regarde les dates des buildOk. Merci pour la réactivité. Je la télécharge demain et je fais un retour. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xili Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Ça dépend de moi et de mes collègues sinon c'est au moins une par semaines au plus ça peut être une toutes les heures regarde les dates des build donc tu fais partie de l'equipe qui developpe la rom ? j'ai quelques suggestions alors ^^, je sais pas si tu y pourra grand chose, mais on sait jamais Principalement au niveau du pie controle : les icones sont soit deformées, soit pas centrées (en hauteur), ce qui fait que esthétiquement c'est pas tip top :x Ensuite j'ai pas trouvé le moyen de mettre la lampe torche dans le pie, ou encore un raccourci pour les screenshots, alors que je trouve que c'est très pratique, c'est un peu dommage ( je sais que sur la rom slim, c'etait possible quand je l'utilisais) sinon pour le moment j'ai pas grand chose a reprocher ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 2 février 2015 Auteur Share Posté(e) 2 février 2015 donc tu fais partie de l'equipe qui developpe la rom ? j'ai quelques suggestions alors ^^, je sais pas si tu y pourra grand chose, mais on sait jamais Principalement au niveau du pie controle : les icones sont soit deformées, soit pas centrées (en hauteur), ce qui fait que esthétiquement c'est pas tip top :x Ensuite j'ai pas trouvé le moyen de mettre la lampe torche dans le pie, ou encore un raccourci pour les screenshots, alors que je trouve que c'est très pratique, c'est un peu dommage ( je sais que sur la rom slim, c'etait possible quand je l'utilisais) sinon pour le moment j'ai pas grand chose a reprocher ;) Piecontrol est encore en bêta on ajoutera des fonctionnalités bientôt Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Xili Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 super wait & see Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yac04 Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 bonjour , j'ai une petite question : pourquoi ne pas ajouter les badges notifications sur les icones ( mails , sms ... ) ? merci 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
metalliko Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Bonsoir, Ça vaut la peine de passer d'un CloudyG3 (4.4 LG rom) à une rom Lolipop ? Je voudrais avoir votre avis après avoir tester Lolipop, notamment sur : - La fluidité - Le réseau - les applications D'ailleurs au passage c'est possible d'installer les Apk d'LG sur une rom Lolipop ? Désolé de toute ces questions mais depuis que j'ai installé CloudyG3, je n'ai plus suivi l'actualité et j'ai pour ainsi dire "perdu la main" au niveau du bidouillage. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 2 février 2015 Share Posté(e) 2 février 2015 Pour ma part la BlissPop est une des pires ROM Lollipop, elle est lagué de partout et les animations sont laides. Je trouve la RR bien plus fluide et belle. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zeldomar Posté(e) 3 février 2015 Share Posté(e) 3 février 2015 Pour ma part la BlissPop est une des pires ROM Lollipop, elle est lagué de partout et les animations sont laides. Je trouve la RR bien plus fluide et belle. A ce point ! :) Pour la beauté, elle ne sont pas toutes identiques les rom AOSP Lollipop ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 3 février 2015 Share Posté(e) 3 février 2015 Je parle de la beauté, c'est pour les animations. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 3 février 2015 Auteur Share Posté(e) 3 février 2015 Pour ma part la BlissPop est une des pires ROM Lollipop, elle est lagué de partout et les animations sont laides. Je trouve la RR bien plus fluide et belle.Le problème c'est que l'on peut choisir les animations et ya les animations stock d'android qui marche comme sur toute les rom Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cdrixx Posté(e) 3 février 2015 Share Posté(e) 3 février 2015 bonjour , j'ai une petite question : pourquoi ne pas ajouter les badges notifications sur les icones ( mails , sms ... ) ? merci ca me manque beaucoup Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 3 février 2015 Auteur Share Posté(e) 3 février 2015 ca me manque beaucoupJustement on en parlait hier notre graphisme est sur le coup et sera peut être ajoutés avec la 2.0 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zeldomar Posté(e) 3 février 2015 Share Posté(e) 3 février 2015 Justement on en parlait hier notre graphisme est sur le coup et sera peut être ajoutés avec la 2.0 Hello, La rom est franco-française ? Votre unique base est CM12, tout le reste est développé par vos soins ? (et du code non repris d'autre rom) Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
genesixxbf3 Posté(e) 3 février 2015 Auteur Share Posté(e) 3 février 2015 (modifié) Hello, La rom est franco-française ? Votre unique base est CM12, tout le reste est développé par vos soins ? (et du code non repris d'autre rom) Merci Salut la rom est en franglais Oui développé par nos soins :) Modifié 3 février 2015 par genesixxbf3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
