Mise à jour 12 November 2013 pour le 550 et 551
Gontie
Merci. Finalement, j'ai trouvé aussi chez Asus.
Donc :
1        Update phone APN version to 105.
2        Update Houdini 5.0.2
3        Fixed camera can not open sometimes when using zenflash
4        Improve volume of recording video will increase and decrease alternately.
5        Do not config Routing.Configure.HWCodec.Playback.Mixers.Headset when using FM.
6         Fixed some BLE device can not auto reconnect
7        Improve service stability
8        Improve modem stability from crash
9        Improve call stability
10        Improve signal bar stability for sim 2
11        Quick Settings: Change "Reading Mode" button as "Bluelight filter"
12        Improve SysteM UI stability and modify Japanese strings
13        Improve lockscreen UI and stability
14        Fix Homescreen Wallpaper randomly lost previous settings and half black screen issue
15        Snap View-add reset Snap View password function
16        Fix Contacts search failure issue when default language was set as HK Chinese
17        Improve Auto start manager stability and fix FB broadcast issue
18        Improve Task Manager UI and rotation stability
19        Fix calculator stability issue and UI bug under Quick Memo App
20        Improve Launcher and Multi user stability from System and framework
21        Fix Google Voice incoming call source issue and the failure to change to Google Voice number
22        Fix the issue that miss call counts failed to disappear on home when Multi user
23        Improve File Manager stability
24        Add ASUS ZenUI PC Suite
25        Fix all touch gestures to be enabled when change back to owner mode
26        Fix ASUS Browser issue
27        Fix the issue that Audio Wizard cannot  be launched when turn off BT
28        3rd party app update
29        Update touch FW
30        Update JP IME ATOK to v 1.0.1
31        Modify Japanese strings in Power Saver App
32        Fixed turn on the camera must unlock by using zenmotion issue
33        Fixed an error message shows up after removing privacy mode and adding new user immediately issue.
34        Fixed wallpaper needs to have second clicks for reaction issue.
35        Fixed built-in browser features a new incognito window has no effect issue.
36        Fixed close contacts shows other programs issue.
37        Fixed built-in calendar Click settings will flash issue.
38        Fixed ringtones into vibrate mode when the camera is off camera sounds issue.
39        Fixed volume keys to adjust the ring abnormaliy issue.
40        Fixed wallpaper Figure has been broken issue.
41        Fixed after the system optimization, message management have stopped running issue.
42        Add Battery charging ready reminder feature.
43        Enable FM Radio for Turkey
Pas encore pu la faire, mais j'espère que le point 41 réglera mes problèmes de notifications SMS (incident remonté chez expert Asus qui a lui-même constaté ce bug). La gestion de l'auto-rotation a semble-t-il été étudiée, je crois comprendre (point 18).
Modifié par Frodon035
Sur les forums, je n'ai vuq ue des propriétaires de 551 qui l'ont reçu, pas de 550. A voir...
Edit, la mise à jour est posté aussi sur les Zenforums pour la 550.
Modifié par Gontie
Une petite animation sur l'écran de déverrouillage quand on est en charge rapide est apparu...
perso je l'ai pas, elle doit être activable quelque part mais j'ai pas trouvé :)
Sur 551, cette MAJ a résolu mon problème de notifications sonores SMS. Concernant la batterie, aucune différence avec avant, je tiens toujours 2-3 jours. Pour le moment, rien à signaler, tout roule.
Oui j'ai remarqué aussi que les notifications fonctionnent correctement ...
Le souci de Edge/3G semble aussi résolu et la batterie tient toujours aussi peu ...
