[ROM] 13/12 | Fulmics ROM 8.0 ◦ v30N ◦ Tweaks | HUB | OTA ◦ MM 6.0 ◦ All variants
Ni FrAndroid, ni XDA, ni le Dev et ni moi ne peut être responsable en cas de problème important
La source, "ICI"
Je ne fait que présenter la Rom pour ne pas polluer les autres post.
xpirt
http%3A%2F%2Ffulmics.com%2Fimg%2Fdonate.
Donations help A LOT during development, buying me a coffee you will keep me awake at night so I can add more tweaks and mods
http%3A%2F%2Fi.imgur.com%2FVsM4Jio.pnghttp%3A%2F%2Fi.imgur.com%2F5TTErvR.pnghttp%3A%2F%2Fi.imgur.com%2FN0KaN4X.png
- @Cloudyfa, @6ril1, @Skin1980, @BlackSoulxxx, @ccass
- @renzetti.s, @piaoxue99, @AbbasM234, @spiderio, @auras76
- @loserskater, @Goldie, @MattBooth, @tdunham, @venkat kamesh
- @baadnewz, @lyapota, Team Venom
- @metalboy94, @hoangnova, @darkera13, @Morningstar, @big88moe, @Robshr, @zmeeed1
- AOSP, CM Team, MoKee, Euphoria-OS
XDA:DevDB Information
Fulmics ROM for LG G3 - MM, ROM for the LG G3
Contributors
xpirt
Source Code: opensource.lge.com
ROM OS Version: 6.0.x Marshmallow
ROM Kernel: Linux 3.4.x
Version Information
Status: Stable
Current Stable Version: 6.0
Stable Release Date: 2016-08-16
Created 2016-01-30
Last Updated 2016-08-16
Full ROMs
Old downloads:
  Révéler le contenu masqué
OTAs
Fulmics ROM 8.0 (December 13th)
Updates
  • Updated Magisk to latest 14.0 version
  • Updated Magisk Manager to latest 5.4.3 version
  • Updated aroma installation and GPS servers
Additions
  • Added 4K Video support for YouTube app
Fixes
  • Some fixes and stability improvements
  • Old changelog:
ROM Info
  • Android 6.0 (MRA58K) + some 6.0.1 patches
  • Based on LG v30N
  • Full UX 5.0 from latest LG G5 v10D base
  • Multi-carrier support
  • Root, busybox and init.d support
  • Sysro / Sysrw binaries
  • Battery life, performance and memory improvements
  • Improved ART verification and compilation
  • Stripped debugging info for improved performance
  • Sqlite support
  • Disabled logging & removed bloatware
  • YouTube 4K support
  • Knock ON with 3 taps minimum
  • LG G5 features:
    • Camera Time-lapse
    • Camera Snap Mode
    • Video Editor with Effects
  • Miniview from LG V10
  • Fulmics Tweaks - tons of tweaks!
  • Fulmics HUB - download mods/addons/kernels/etc directly on your phone!
  • Fulmics OTA - keep up to date with latest fixes!
  • APM (Advanced Power Menu: Reboot, Hot Reboot, Recovery, Safe Mode)
  • Camera: 60 FPS (FullHD), 64Bit (4k), 100% Quality (jpeg)
Aroma Installer
  • Model selection (F400S/F400L/F400K, D850, D851, D852, D855, LS990, US990, VS985, D856, D857, D858/HK, D859)
  • Sharpening Mod (Disabled, 25%, 50%, 75%, Stock)
  • CTT Mod
  • Custom LG apps removing
  • Custom Google apps removing
  • Custom addons installation (VIPER4Android, Sound Boost)
  • GPS Region fix
  • Custom apps removing
Désolé mais je ne me suis pas foulé, c'est vrai,  :P:P :P mais du coup tous le monde peut en parler ici  :)
Modifié par GaelGroove
Mise à jour de la Rom
  • Like 6
Sur tous les fronts lol
Juste une precision si vous avez un D855 ne flasher sutout pas la version 3.0 sous peine de bootloop mais uniquement la 3.1
Envoyé de mon LG-D855 en utilisant Tapatalk
Modifié par McSpee
  • Like 2
Merci. je viens d'installer la 3.1. Dans les tweaks on peut modifier la taille de la navbar mais les icônes gardent toujours la même taille, c'est normal?
Edit: en fait après 2 redémarrages les icônes ont bien changé de taille.
Modifié par siberian56
Petit retour de galère....
Mise à jour du twrp en 3.0
Lancement de l'installation de fulmics 3.1 et blocage du tel. Obligé de retirer la batterie et repassage en twrp antérieur.
Donc lancement de l'install. Tout parfait.
Redémarrage et là après le logo LG, retour sur twrp.... ???
Donc retour sur laN&N...
J'ai loupé un truc ? Et twrp en 3.0 n'est pas compatible avec l'aroma installeur.....
Apres un flash de kernel custom raté ( :rolleyes:) j'ai reflashé la Fulmics depuis TRWP3.0 et je n'ai pas eu de soucis.
Par contre j'ai des soucis de reboot avec cette Rom. mais c'est très aléatoire et je soupçonne une mauvaise combinaison d'applis plutôt que la rom elle même.
Modifié par Holaf
Donc tu as réussi à installer la fulmics.... Étrange... J'ai dû faire une boulette quelque part. Pour ma part, l'aroma ne se lançait pas sous twrp 3.0. J'avais un écran figé. Donc je retire la batterie et recovery. Puis passage en 2.8.7. Installation de la fulmics. Puis redémarrage du tel et après le logo LG, retour sur recovery direct.
Donc, je suis resté sur la N&N.
Si ça parle à quelqu'un, je suis preneur !
  Le 10/02/2016 à 11:24, camrl167 a dit :
Pour ma part un wipe cache/système /dalvik sur twrp3. 0 puis flash de la fumics3. 1.
Rom très stable. Kernel d'origine, pas de xposed. 57000antutuu. Tout est ok, une rom parfaite. Pas de bug, des tweaks fulmics utiles et sans excès. Good job !
57000 pts antutu !!!!
Whaouuu. T'es le seul ou d'autres aussi on le même score ?
