Lecture de données d'une base de données MySQL avec JSON
Novice en programmation Android, je cherche à lire des données sur une base de données externes MySQL, mais j'ai une erreur lors de la lecture de celles-ci..
J'ai cette erreur dans le logcat :
05-25 09:31:59.107 2325-4890/com.example.petotmarc.cftcfranche_comte E/AndroidRuntime: FATAL EXCEPTION: AsyncTask #1
Process: com.example.petotmarc.cftcfranche_comte, PID: 2325
java.lang.RuntimeException: An error occurred while executing doInBackground()
at android.os.AsyncTask$3.done(AsyncTask.java:309)
at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:354)
at java.util.concurrent.FutureTask.setException(FutureTask.java:223)
at java.util.concurrent.FutureTask.run(FutureTask.java:242)
at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:234)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
at java.lang.Thread.run(Thread.java:818)
Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.String org.json.JSONObject.toString()' on a null object reference
at com.example.petotmarc.cftcfranche_comte.ArticleActivity$LoadAllArticles.doInBackground(ArticleActivity.java:145)
at com.example.petotmarc.cftcfranche_comte.ArticleActivity$LoadAllArticles.doInBackground(ArticleActivity.java:120)
at android.os.AsyncTask$2.call(AsyncTask.java:295)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
Voici mon code :
public class ArticleActivity extends ListActivity {
    // Progress Dialog
    private ProgressDialog pDialog;
    // Creating JSON Parser object
    JSONParser jParser = new JSONParser();
    ArrayList<HashMap<String, String>> articlesList;
    // url to get all products list
    private static String url_all_article = "http://10.0.2.2/GestionArticle/getAllArticle.php";
    // JSON Node names
    private static final String TAG_SUCCESS = "success";
    private static final String TAG_ARTICLES = "articles";
    private static final String TAG_ID = "idArticle";
    private static final String TAG_TITRE = "titre";
    private static final String TAG_DATEARTICLE = "dateArticle";
    private static final String TAG_HEUREARTICLE = "heureArticle";
    // products JSONArray
    JSONArray articles = null;
@[member=override]
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_article);
        if (android.os.Build.VERSION.SDK_INT > 9) {
            StrictMode.ThreadPolicy policy = new StrictMode.ThreadPolicy.Builder().permitAll().build();
            StrictMode.setThreadPolicy(policy);
            System.out.println("*** My thread is now configured to allow connection");
        //Hashmap for ListView
        articlesList = new ArrayList<HashMap<String, String>>();
        new LoadAllArticles().execute();
        // Get listview
        ListView lv = getListView();
class LoadAllArticles extends AsyncTask<String, String, String> {
             * Before starting background thread Show Progress Dialog
            @[member=override]
            protected void onPreExecute() {
                super.onPreExecute();
                pDialog = new ProgressDialog(ArticleActivity.this);
                pDialog.setMessage("Chargement des articles. Attendez s'il vous plaît...");
                pDialog.setIndeterminate(false);
                pDialog.setCancelable(false);
                pDialog.show();
             * getting All products from url
            protected String doInBackground(String... args) {
                // Building Parameters
                List<NameValuePair> params = new ArrayList<NameValuePair>();
                // getting JSON string from URL
                JSONObject json = jParser.makeHttpRequest(url_all_article, "GET", params);
                // Check your log cat for JSON reponse
                Log.d("Tous les articles: ", json.toString());
                try {
                    // Checking for SUCCESS TAG
                    int success = json.getInt(TAG_SUCCESS);
                    if (success == 1) {
                        // products found
                        // Getting Array of articles
                        articles = json.getJSONArray(TAG_ARTICLES);
                        // looping through All articles
                        for (int i = 0; i < articles.length(); i++) {
                            JSONObject c = articles.getJSONObject(i);
                            // Storing each json item in variable
                            String id = c.getString(TAG_ID);
                            String titre = c.getString(TAG_TITRE);
                            String dateArticle = c.getString(TAG_DATEARTICLE);
                            String heureArticle = c.getString(TAG_HEUREARTICLE);
                            // creating new HashMap
                            HashMap<String, String> map = new HashMap<String, String>();
                            // adding each child node to HashMap key => value
                            map.put(TAG_ID, id);
                            map.put(TAG_TITRE, titre);
                            map.put(TAG_DATEARTICLE, dateArticle);
                            map.put(TAG_HEUREARTICLE, heureArticle);
                            // adding HashList to ArrayList
                            articlesList.add(map);
                    } else {
                        // no products found
                        // Launch Add New product Activity
                        //Intent i = new Intent(getApplicationContext(),
                         //       NewProductActivity.class);
                        // Closing all previous activities
                        //i.addFlags(Intent.FLAG_ACTIVITY_CLEAR_TOP);
                        //startActivity(i);
                        //Afficher "Erreur, pas d'articles"
                } catch (JSONException e) {
                    e.printStackTrace();
                return null;
            protected void onPostExecute(String file_url) {
                // dismiss the dialog once product deleted
                pDialog.dismiss();
Ainsi que mon code php pour interagir avec la base :
// array for JSON response
$response = array();
// include db connect class
require_once __DIR__ . '/db_connect.php';
// connecting to db
$db = new DB_CONNECT();
    // get a product from products table
    $result = mysql_query("SELECT idArticle, titre, dateArticle, heureArticle FROM article ORDER BY idArticle DESC");
    if (!empty($result)) {
        // check for empty result
        if (mysql_num_rows($result) > 0) {
            $result = mysql_fetch_array($result);
            $article = array();
            $article["idArticle"] = $result["idArticle"];
            $article["titre"] = $result["titre"];
            $article["dateArticle"] = $result["dateArticle"];
   $article["heureArticle"] = $result["heureArticle"];
            // success
            $response["success"] = 1;
            // user node
            $response["article"] = array();
            array_push($response["article"], $article);
            // echoing JSON response
            echo json_encode($response);
        } else {
            // no article found
            $response["success"] = 0;
            $response["message"] = "No article found";
            // echo no users JSON
    } else {
        // no article found
} else {
    // required field is missing
    $response["message"] = "Required field(s) is missing";
Donc voilà, si quelqu'un peut m'aider à résoudre ce problème, je lui en serais très reconnaissant !
